Su-27UB: Is it only a trainer?
Quick question that a strategic amount of googling could not determine the answer to: is the Su-27UB "merely" a trainer in Russian service, or does/would it see operational use as a normal combat airplane?
The UB stands for 'Uchebno Boyevoy' - which translates to 'Combat Trainer'.
The Su-27UB is fully combat capable - with the same radar and weapons as the 'fighter' Su-27.
Whether it is used as such by the RusAF is open to discussion - but it is capable of being used as a 'combat airplane'.
It has also been developed into the multi-role Su-30 - with the Su-30MKK and Su-30MKI/M/A variants - which are definitely used in that role.
Ken
PS - Variants of the multi-role Su-30MKK and Su-30MKI are just entering service with the RusAF - as the Su-30MK2 and Su-30SM respectively
Edited by Flankerman
Thanks! Re: the Su-30, can the extant Trumpeter Su-30 kit be used to build a Russian example, or only a PLAAF one?
The Trumpeter kit (1/72 & 1/32) is a Su-30MKK - so can be used to build a Russian AF Su-30MK2........
Note though that the 1/72 scale kit fins are too short (I can't speak for the 1/32 scale version - I never bought it)
I modded mine........
.... but Dream Model have now done resin replacements...... (ignore that it says 1/48 on the label - it is 1/72nd)
The Su-30MKI/M/A - and therefore the new RusAF Su-30SM - is a totally different machine - with canards and TVC nozzles.
HTH
Ken
The main differences of the Su-27UB and Su-30 (green markers) and Su-27 (red markers)
Optical-location station moved to the right (1)
Iinstalled flight refueling system (2)
Improved avionics and
operator cabin equipment (3)
Two-wheel nose landing gear (4)
Instructor cab converted into a operator station (5)
Increase the vertical tail (6)
Further to operational use of Su-27UB's.......
Kazakhstan has upgraded some of its UB's to UBM2's..... see Sebastijan's excellent 'conversion' of the 1/72 scale Trumpeter Su-27UB kit here
A fully tooled up Su-27UBM2 with A2G weaponry.
Ken
Say, Flankerman...all ALL Trumpy Su-27 fins too short, or just the Su-30MKK to Su-30MK2 fins?
Only the Su-30MKK kit in 1/72 scale (I don't know about the 1/32 scale version)
The three other Trumpeter Flanker kits - J-11B, Su-27UB and Su-27 (Early) kits - are all OK height-wise.
See my guide to Flanker fins here (a bit anoraky I know, but some find it useful....)
A minor point an ALL Flanker kits I have seen so far is the fact that on the real aircraft the intake at the base of the fin leading-edge is bigger on the port fin than it is on the starboard fin.
All the of Flanker kits have solid same-sized 'blobs' for intakes.
Ken
  • 4 years later...
Old but very helpful thread... Been hunting around for the differences between a Su-30 and the Su-27UB... just got the 1/32nd Su-30 but fancy doing it as a Su-27UB... but don't think I will bother now :)
On 2013-2-20 at 10:41 AM, Flankerman said:
(a bit anoraky I know)
You say that like it's a bad thing. ;)
Andre
Ken, except for the Zvezda Su-27SM and their Su-33, the vertical fin intakes are sized differently; YOU pointed that out in your review of the Su-27SM a few months back. I checked the Su-33 lit and noticed that they had sized them the same(or close) as their Su-27SM.
This thread is dated 2013.... not a few months. (See my last post)
