harvy5 Posted June 19, 2013 Share Posted June 19, 2013 Link to comment Share on other sites More sharing options...
Sarcococca Posted July 11, 2013 Share Posted July 11, 2013 I like your eye for the details! Nice improvements you did on this old kit! 1 Link to comment Share on other sites More sharing options...
exdraken Posted August 8, 2013 Author Share Posted August 8, 2013 some small heat related delayed updates: had to change the position of the aerial fairing on top of the fuselage... me or instructions?? flaps provisionally installed, more or less satisfied with their outcome cockpit closed for exterior painting I am quite satisfied with the small change of the droop angle of the front windscreen! chaff and flare dispensers mounted, hopefullly correctly (hardly and designated location on the fuselage visible....) more to follow soon! Link to comment Share on other sites More sharing options...
trickyrich Posted August 8, 2013 Share Posted August 8, 2013 had to change the position of the aerial fairing on top of the fuselage... me or instructions?? This give me issues as well, logic would suggest that it goes the other way around and the instructions arn't to clear on this or a couple of other things!! Just wait to you have to assemble the main landing gear a fit doors!!!! chaff and flare dispensers mounted, hopefullly correctly (hardly and designated location on the fuselage visible....) another item that raised concerns for me, just checked ref photos/drawings I have, looks spot on! Can't wait to see it finished, am actually a bit sad watching this but, sort of missing all the fun I had with mine! May just have to build me self a 17M4 to go with the M3!!! Link to comment Share on other sites More sharing options...
LT Motta Posted August 13, 2013 Share Posted August 13, 2013 (edited) Nice job up to here! I do like Su-22. How did you make that metallic part close to the guns? Edited August 13, 2013 by LT Motta Link to comment Share on other sites More sharing options...
exdraken Posted August 16, 2013 Author Share Posted August 16, 2013 How did you make that metallic part close to the guns? is is made of self adhesive aluminum tape. cut directly on the model along the appropriate panel lines. Rivets are done with a riveting tool. (not too accurate by the way...) Link to comment Share on other sites More sharing options...
LT Motta Posted August 17, 2013 Share Posted August 17, 2013 Many thanks! Link to comment Share on other sites More sharing options...
exdraken Posted August 28, 2013 Author Share Posted August 28, 2013 (edited) while paint is drying, camouflage is beeing masked of, etc I also found some time for doing landing gears, weapons...... I could not resist is also using some additional PE parts from PART. Namely their exterior set for the Su-22M4 which provides some very nice improvements (necessities actually!!!) for the KKR recce pod, wheels, front wheelbay doors, etc. weapons : North Star KH-29T, Aerobonus KH-25, Eduard R-60s Feedback appreciated! Edited August 29, 2013 by exdraken Link to comment Share on other sites More sharing options...
Arkady72 Posted August 28, 2013 Share Posted August 28, 2013 while paint is drying, camouflage is beeing masked of, etc I also found some time for doing landing gears, weapons...... I could not resist is also using some additional PE parts from PART. Namely their exterior set for the Su-22M4 which provides some very nice improvements (necessities actually!!!) for the KKR recce pod, wheels, front wheelbay doors, etc. weapons : KH-29T, KH-25, R-60s Feedback appreciated! Only one kind of guided missiles could be used as I remember. 1 Link to comment Share on other sites More sharing options...
exdraken Posted August 29, 2013 Author Share Posted August 29, 2013 thanks for the additional info Arcady! the missiles are so nice I simply had to do them! Not going to put on all the external stores at once! KKR pod. external tanks, KH-29, Kh-25.... simply not enough pylons available sadly... Link to comment Share on other sites More sharing options...
LT Motta Posted August 29, 2013 Share Posted August 29, 2013 Man... I am "in love" for this bird... first of all because I've seen many built Su-22 by Arkady... but now, after I've seem yours... I have to practice a lot before I touch in mine! After I've seen many Arkady's Su-22 I've convinced myself: "I need one" and I've bought one Eduard one ebay (and i've paid with "my eyes"), but after I've seen your thread I've concluded: "I need to grow up before try it" (or as we say in Brazil: "I need drink a lot of milk") So I've decided put mine back in the stash and screw up with another model before any attempt... This is a awesome aircraft... and awesome thread!!! Link to comment Share on other sites More sharing options...
Tom Cooper Posted August 30, 2013 Share Posted August 30, 2013 (edited) Few tips (or 'pleas', if you prefer)... Please, do not hang all of this stuff, not even a mix of it, on the plane 'at once'. On Iraqi Su-22s, it was either 'KKR + SPS-141MVG + drop tanks', or 'Kh-28 + Myetel + drop tanks', or 'Kh-29 + SPS-141MVG + drop tanks' or 'Kh-25 + drop tanks' (over Kuwait in August 1990 only), or 'different loads of bombs, but usually 4-6 FAB-500M62s + drop tanks' - but never a mix including two different types of weapons (not even a mix of two different calibres of bombs). If you add the SPS-141MVG (usually on the left inboard underwing pylon), don't add the Myetel pod: they were jamming each other. And take care to remove all the antennas pointing in rear directions (as delivered to Iraq, the SPS-141MVG was operating 'in front aspect only'). Instead, add a UV-16-57 as 'counterweight' on the other side of the plane (that was indeed necessary). Re. gun-pods... sorry, but a strict 'no-no' on Iraqi Su-22s. (And thanks in advance for at least considering anything of this...) Edited August 30, 2013 by Tom Cooper Link to comment Share on other sites More sharing options...
exdraken Posted August 30, 2013 Author Share Posted August 30, 2013 (edited) don't do that just build it! I like your Mustang egg plane - very nice paint work! a lot more fun doing one yourself than only watching others battling! please post your progress if you decide to start! Thanks Tom Cooper for your qualified and valuable input! I can really understand your caution with regards to operational load outs! and appreciate it! (sadly - as there are hardly any decals) this is supposed to be in Polish colors. As it looks at the moment at least with a with a "possible" camouflage pattern. as stated above, the weapons are really nice and I wanted to build them for that reason. my plan is to put from left to right external tank PTB-800 -R-60 - maybe SPS-141 jammer - on 1R and 2R the KH-29s - than an empty B-8M as counter weight - R-60 - PTB-800 the KH-25 will be for display only (or can I put them as well on the canted fuselage pylons?) the KKR-1 pod should go well with this load out, apart from the guided KH-29s of course. maybe I will do a photo session in this outfit... but don't panic, I will not put up everything at once!!! I have no Myetel to put on... maybe I will scratch one for a future SEAD bird Edited August 30, 2013 by exdraken Link to comment Share on other sites More sharing options...
foxbat155 Posted September 2, 2013 Share Posted September 2, 2013 Hi, In this thread you can find almost all external stores variants for Su-17/22M4. Pages from original military technical instruction devoted this aircraft. Everything in polish language, but is easy understandable due to use original russian designations. http://il2forum.pl/index.php/topic,10787.210.html?PHPSESSID=64753b77ed946847f4e731d266f45844 One more note: you can't suspend under M4 H-28 anti-radar missile and Myetel pod. These were used only with older Fitter variants up to M3. Iraqi Su-22M and Su-22M3 used them but not the M4. Regards. 1 Link to comment Share on other sites More sharing options...
exdraken Posted September 2, 2013 Author Share Posted September 2, 2013 thanks a lot foxbat155! :) a very helpful and interesting forum (although google translate could do better in my opinion!) Link to comment Share on other sites More sharing options...
James G Posted September 3, 2013 Share Posted September 3, 2013 Very nice progress...it's great to see so many Soviet models on BM, inspires me to make a start on my many Soviet kits. I just need to find some time! Link to comment Share on other sites More sharing options...
exdraken Posted September 9, 2013 Author Share Posted September 9, 2013 more weapons pictures: decals next! Link to comment Share on other sites More sharing options...
Uncle Uncool Posted September 11, 2013 Share Posted September 11, 2013 Hey there, exdraken, mate! Terrific job ya're doin' here. Say whut brand are the resin sweep wings, flaps 'n' slats...? Thanks a lot; keep up with the good work, bloke! Cheers Unc² 1 Link to comment Share on other sites More sharing options...
exdraken Posted September 12, 2013 Author Share Posted September 12, 2013 Hey there, exdraken, mate! Terrific job ya're doin' here. Say whut brand are the resin sweep wings, flaps 'n' slats...? Thanks a lot; keep up with the good work, bloke! Cheers Unc² Thanks for compliments they seem to be sold now from the new webpage: http://www.newtmd.com/SU-22-Slats-and-Flaps had a conversation with thes guy behind tigermodels, Joe Bakanivic on hyperscale some time ago, he seems really concerned about people's opinion on his product! Great guy! http://www.network54.com/Forum/47751/thread/1367670773/Su-22M4+1-48+in+the+making have a go on them! definitely the best at the market at the moment! cheers, Werner hope to be able to show some paintwork later.... after processing some pictures! Link to comment Share on other sites More sharing options...
exdraken Posted September 13, 2013 Author Share Posted September 13, 2013 (edited) finally some major paint work to report! over the past several wheels I aülied the camouflage colours. bottom: silver/metal section on the rear fuselage, main green on top, some dark green areas, some brown and black areas, especially around the gun exhaust and the front cockpit the exhaust area consists of 2 rings of different metal paints. pylons and chaff dispensers in metal/silver /grey bottom: some shade of blue: and some pre shading and with provisional mounted belly pylons for the big missiles 1R and 2R: top:main camouflage green: second green, brown and black colours: open cockpit: some painted warning stripes: sorry for the amount of photos, now decal work will follow! thanks for looking and all the kind feedback this build recieved! Cheers, Werner Edited September 13, 2013 by exdraken 2 Link to comment Share on other sites More sharing options...
Mozzy19 Posted September 13, 2013 Share Posted September 13, 2013 Starting to take shape now! Looking good. It's a big beasty too looking at it compared your hand. Sean Link to comment Share on other sites More sharing options...
LT Motta Posted September 13, 2013 Share Posted September 13, 2013 Really nice!!! Link to comment Share on other sites More sharing options...
harvy5 Posted September 16, 2013 Share Posted September 16, 2013 Very nice work! These new Polish colors are very nice. Link to comment Share on other sites More sharing options...
exdraken Posted October 3, 2013 Author Share Posted October 3, 2013 thanks everybody! hope to have some updates soon, was on holiday Link to comment Share on other sites More sharing options...
exdraken Posted October 15, 2013 Author Share Posted October 15, 2013 (edited) stencils on... just stumbled on a new? polish decal maker with great subjects! Hopefully they produce something for my Su-22 soon! http://www.ebay.pl/sch/modelmakerdecals/m.html?item=111190055161&ssPageName=STRK%3AMEWAX%3AIT&rt=nc&_trksid=p2047675.l2562 regards, Edited October 15, 2013 by exdraken Link to comment Share on other sites More sharing options...
