Mike Posted January 29, 2013 Share Posted January 29, 2013 T-62 Mod.1972 Value Package (for Trumpeter)1:35 ET Model (S35-012) Trumpeter's T-62 is a bit of a tour de force, and this set is aimed squarely at the first edition, although most if not all of it could be applied to the kit with the ERA blocks added, which I'll incidentally be reviewing shortly.The "Value Package" from ET Model means exactly that, incorporating their Basic set, Stowage Bins set, Fender set, DShK Machinegun Set, Auxiliary Fuel Set, and DShK ammo can sets. Wow… that's quite a handful of sets in one! Arriving in ET Model's usual thick polythene outer with header card, the set contains three large card stiffener cards containing four sheets of Photo-Etch (PE) brass measuring 9.5cm x 14.5cm, 9.5cm x 17.5cm, 9.5cm x 7.1cm and 9.5cm x 6.2cm. In addition, there is a bag of nine (!!) smaller frets of PE brass, and one single piece of cream coloured resin. This is a very comprehensive set, and is not for the PE novice. You will need to be confident to bend pre-weakened shapes, as well as a limited amount of rolling, which although quite simple when you know how, or have the correct tools (Small Shop's Brass Assist being foremost in my mind), it can be a bit intimidating.The main set is intended for the basic model kit, and comprises of the two smaller of the large sheets, plus two of the small sheets, and the resin Antenna base. Work starts on the hatches, replacing the periscopes with entirely PE units that are hollow, as well as hinge, latch and edge detail, which extends to the hatch-mounted flood-light, for which you'll need a small supply of 0.5mm and 1.0mm rod to complete the job. Various assemblies, mounting brackets and tie-downs are then added to the turret, along with the antenna base, a plate that attaches to the top of the mantle cover, mount for the snorkel, and a mount for the coaxial flood-light. The DHsK ammo cans receive a set of PE tie-downs, and here you have the option of replacing or augmenting them with PE alternatives. The stowage boxes that sit on the fenders are then comprehensively accessorised, with additional retention plates between each one that attach to the small triangular bulkheads that separate them.The engine deck is covered with various mesh covers and detail parts, which transforms the look, improving it immensely. Aft of the deck are the two auxiliary fuel tanks, which are effectively a pair of large drums attached to the hull by strong brackets. Here you can either use the kit drums, or replace them entirely with the PE set, which you will need to roll into a cylinder and attach the end-caps to. These will take the knocks and dings that the real thing was subjected to mush easier, and will look more realistic if done well, but if you don't fancy the challenge, use the kit parts and just replace the shackles with the PE parts. The lashing points for the unditching beam that was often carried by the T-62 is also replaced with better looking PE parts, and the rear bulkhead is also spruced up with some scale-thickness brackets and detail parts, particularly those that hold a section of spare track link in place.Moving to the glacis plate, the driver's vision blocks are augmented with PE covers, the hatch is detailed with a bullet-splash lip and rotating hinge detail, while the running lights are all upgraded with detailed bracket parts, and bullet splash strip is added all around the base of the turret. The front mudguards are detailed with hinge parts, and a section of 0.5mm wire will be needed too, plus some 0.5mm rod to complete the job.The ancillary sets can be added to suit, and start with the stowage set, creating detailed bins to improve detail and give the option for damage and even open bins to the modeller. In total this covers six complete bins of varying shapes and sizes, with full latch and hinge detail, as well as mounting brackets.The fender set replaces the whole fender with PE parts, retaining only the exhaust section, which must have a 0.3mm extension at the rear to conform to the width of the fenders. Strengthening brackets are added down the length of each fender, and edging strips give the parts extra strength and realistic thickness.The final sets cover the DShK, adding a mass of tiny detail to the gun, its mount and replacing the kit ammo box with a more detailed and realistically thick PE assembly. There are enough parts on one sheet to make two boxes, and an extra sheet is included, permitting you to build up to four boxes, with ammo link that is folded over to produce a more three dimensional link, although that can't be bettered by available sets from Mission and others.ConclusionAs mentioned earlier, this is certainly comprehensive, and what I've come to expect from ET. Their attention to detail is excellent, and only their instructions could really be improved by adding some clarity of what parts you're working on for inquisitive modellers like myself.Very highly recommended. Available soon from White Ensign Models in the UK Review Sample courtesy of Link to comment Share on other sites More sharing options...
