Shar2 Posted January 26, 2013 Share Posted January 26, 2013 BT-7A Tank Detail Set S35-007ET Models 1:35 The release by the BT-7A by Tamiya was very welcome as it was a much nicer and more accurate kit to build than the other examples that had been released previously. That said, theres always room for improvement and ET Models have released this latest set in their repertoire to do just that. The set is packed in the usual thick poly bag with a stapled cardboard header card. The four main etched sheets are taped to two sheets of black card, in one small zip lock bag there is another small etch sheet and a sheet of acetate, whilst in a second zip locked bag there are a pair of resin lights. The instructions are printed on the usual green paper, two sheets of double sided A4 and one small, (A6) sized sheet. The instructions start with the construction of the replacement side footplates, which consist of the main plate, strengthening beams, crossbeams, rear mudguards and grab handles. The distinctive front mudguards need to be carefully folded to shape so that they fit snugly to the forward hull and the upper plate with its associated cross bracing. Moving to the engine decking the access hatch gets a new mounting ring and hinges. The engine intakes have new grilles secured with very small, but well etched wingnuts. On the left rear slanted deck a new storage bin with two lids and their associated hinges and locking catches whilst on the rear deck there is a new exhaust protection grille, bracing and handles. The rest of the set provides new grab handles, hinges for all the hatches and, catches and tool clamps. For the front of the turret there are two replacement combat lights, cast in beige resin and attached to the turret with etched supports and fitted with etched protective griller and acetate film.Conclusion This is a very nice set, that may not be as extensive as some ET Models have released, but it doesnt really need to as there is more than enough to keep even the most rabid detailer happy. Recommended.Review Sample courtesy of available in the UK from White Ensign Models Link to comment Share on other sites More sharing options...
