Eduard PE set for Trumpeter 1:35 BRDM-2
Shar2
Russian BRDM-2 (Early)
Eduard 1:35
Continuing they’re apparent takeover of the photo etched world Eduard have just released this set for the new Trumpeter BRDM-2 (Early).
The set includes a small fret for the external details which mainly cover the various handles for the hatches and clamps for the tools, lights and towing cable. The top hatches behind the turret are completely replaced with etched parts plus additional parts to make up the two pairs of gas struts that hold the hatches open. To the rear the water jets diverters/rudders are replaced and the outer covers latches are added. There is and additional cover on the top right hand side of the rear panel that is also replaced. The kits exhaust shrouds needs to be carefully removed from the outer cover which is replace with a very nicely detailed etched part. The rope/cable drum gets a new outer face and end piece. The turret receives a new mantel, wiper for the optical sight and support that fits beneath the 14.7mm machine gun.
There is also a very small pre-painted fret that has parts for internal use. These include the drivers instrument panel, including new switches, throttle and brake pedals, and selector knob.
Eduard have also released a very useful mask set for this kit. The masks, all die cut, are for the main windscreens, viewing ports, and headlights.
Conclusion
Another very nicely produced little set from Eduard that will add the finer detail that is missing from the kit. It would also be a good introduction to PE for those who may be reticent about using it. Recommended.
