Chaotic Mike
1/32 Trumpeter Dauntless
Welcome back my friends, to the show that never ends...
Here we have Trumpeter's 1/32 SBD-3 Dauntless, which has been keeping me very happy for the past 3 months.  I have noticed a whole bunch of Trumpeter bashing going on relating to their prospective new Venom; all I can say is that this Dauntless, and the Me-262 that brought me back to the hobby, have been joys to build.
I used Montex masks for the first time, and was really happy with how they turned out... much more than I was with a set of Yellow Wings decals, which were basically the wrong size, and  too fragile to work with.  In the end, just a few stencils got used - for the major markings (aircraft identification) I cut my own masks out of Tamiya tape after scanning in the YW codes to get the basic size and shape right.
I had a bit of a mare with the paint job, which actually turned out good.  I mixed up my own upper surface blue using Tamiya acrylics, sprayed it, Klear-ed it, decalled it, and sprayed Tamiya flat base on that I thought was a matt varnish.    Nope.  Instead, as the flat base dried it turned opaque and a very pale grey.  Unsurprisingly, this caused a certain amount of wailing and gnashing of teeth on my part.  I discovered (panicking) that if I polished it using damp denim, I was able to remove most of the flat base, leaving highlights in the rivet holes and a general air of fading and dilapidation, such as might be experienced by a plane parked in the heat of the sun on a carrier somewhere in the Pacific.
Lets get started...
A general view, showing the accidental fading and rivet highlighting.  The 'B-10' is from a hand cut mask; the main insignia are Montex.  First time for me, I think they are tremendous.
Cor, look at the bright red flaps on that...  (I'll get me coat...)
A close up of the engine.  Because it came with transparent cowlings, I thought I would artistically leave part of one side clear, to show off some internals that otherwise would be lost for all time.
Front view.  I put in the ignition harness using the wire from a wine bottle... see, everything can be re-purposed.  I also used somebody's advice to anneal the wire first, which made bending it to shape an awful lot easier.
Close up of the driving seat.  You can't really see what's going on in there, but Trumpeter's moulding and detailing is beautiful, and looked a lot like the pictures I was using for references.
A close up of the gunner's position.  I replaced the gun barrels with brass... certainly look the part.
Just showing it's got an underside, too!
Fantastic job of weathering, even if it was accidental, a new technique that you can use again.
Dennis
That's a very nice looking Dauntless :goodjob:
Looking good, this ones now on my wish list. I reckon you've got the weathering spot on - sun and salt air = faded paintwork ! I'm not a fan of transparent panels, but your work looks classy and well finished - well done indeed.
Edited by ajaycad
i wish my cockups came out so well. thats really effective.
Well done on your dauntless it's very impressive.
Brody
Thanks everybody. Next up is the Trumpeter 1/32 Crusader, plus an Aires cockpit. New territory...
I think you may have just stumbled on a new weathering technique!!  The dauntless is one of trumpeters better kits.  You have filled me with confidence re the montex masks.  I have several sets to use and am impressed with your results on your first go at using them
Bruce
Bruce
Thanks! I think if you follow the instructions on Montex' web site (like I didn't...) you won't go far wrong. I didn't do the bit about white, then aircraft colour, then the dark blue for the star, which led to a tiny white border around the insignia. To be fair to Montex, they are quite explicit that this effect can be avoided by following their instructions!
Nicely done :clap:
Thanks again... Inspiration from your build of a couple of years back. I did the gunner's control column modification, just like you...!
Lovely build
I'm sure I have the same kit in my stash somewhere, so might give it a go
I really like your Dauntless. Looks good.
Nice paintwork and style.
Karen
