1/72 Tamiya Mosquito FB Mk.VI with 'Mollins' Conversion
I can't remember the last time a made a kit where the first stage in the instructions was the cockpit.
Have assemble the engine nacelles and removed the inboard flaps and replaced them with the resin version.
Build01_TamiyaMosquitoTseTse_zpsdc9b70b2
Next step is to start of the cockpit. Just need to buck up enough courage to take the saw to the nose.
Its been a productive weekend.
Cockpit finished. Went with the supplied seatbelt decals, as I don't think you will be able to see much detail through the cockpit canopy.
Build02_TamiyaMosquitoTseTse_zpsa5b5d445
Its a longtime since I built a Tamiya kit, it just seemed to fly together.
Build05_TamiyaMosquitoTseTse_zpsef3cb297
Build06_TamiyaMosquitoTseTse_zps4c7457ea
The resin replacement nose need a bit of work, had to hollow out the bottom section to get it to fit around the cockpit flooring.
  • 1 month later...
After a months inactivity, finally got a chance to make a bit of progress.
Airframe masked and primed. Glad I decided to buy precut mask for the canopy, otherwise I think I would still be masking it.
  • 3 weeks later...
Haven't posted for a while but progress has continued.
Build10_TamiyaMosquitTseTse_zps5287adac.
Still relatively new to using an airbrush, but reasonable pleased with the way it came out. All paints used are Vallejo Model Air.
Build12_TamiyaMosquitpTseTse_zpsc0875fd2
Decal and given a finish of Humbrol Matt Varnish from the can. The "Keep Off" wing marking are slightly out of register. Didn't notice until I had put them on.
Build17_TamiyaMosquitpTseTse_zps73e51cd4
Need to repaint the spinners as I am not happy with the white stripe
Calling this one finished. Will take some better photos for the gallery later this week
Build19_TamiyaMosquitoTseTse_zpsb037c069
Build22_TamiyaMosquitoTseTse_zps7d929eb9
It doesn't warrant close inspection, as the decals misbehaved. Were fine until I gave it a coat of matt varnish from a humbrol spray can, a couple then started to wrinkle around the edges,
Looks great mate, the bands round the spinners look really sharp, look forward to seeing the gallery pics - fancy doing a Tse Tse myself at some point, cant beat a honking great big gun :)
Cheers, Stu
Another beauty and well done on getting it built on time and to such a high standard. Those Tamiya Mossies really do go together well don't they? Like the look of the solid nose variant and your paintjob looks excellent.
Mark
