1/48 OA-10A Thunderbolt II callsign Sandy
The fuselage sides have a slight line up problem, probably why Eduard made these hatches to cover them..
Drilled some holes and covered them with mesh..
slimelights on the side are present but labelled 150 iso 17..
Eduard made two similar slimelights, but that's wrong. Crossdelta is shaped differently, so..
out with the side cutters..
still stuff missing..
slimelights, antenna base, missing exhaust (not one boxing has them strangely enough), antenna, covert lights and another base for a nav light..
  • 1 month later...
After a month of inactivity due to everything else needed to be done.. some progress.
The Italeri exhausts weathered..
The fan installed and some masking started with some kabuki tape..
fixed the Italeri exhausts..
not a perfect fit for Sierra Hotel Models intakes..
to have a little more flesh to sand things smooth later..
just a little filler required..
Thanks! I do not get a lot of response on this build, so it's more than welcome.
The Pave Penny, Penny, Penny according HB, Revell and Italeri.
HB is too short and skinny..
after a lot of sanding..
Outboard pylons according HB (top) and with some more detail, including the base for the refuelling light..
color of a home made mix of Gunze clear..
canopy sides tinted (HB is left, right is a test piece)..
ALQ-131 according HB (top) and according Hasegawa Weapon set B..
Edited by Sid de Koning
have been lurking but should really have chipped in. keep going mate this is a real eyeopener.
Thanks for all the support gentlemen! Good to see you.. ;)
Engraved missing lines on the resin intakes..
something of a hinge?
reinforcement plates or part of the hinges?
primed and before they go on..
making sure everything will be glued at the right angles..
vertical stabs and my homemade jig so I can work easily on the underside..
I wanted to protect the canopy with an extra layer of Future, in stead it all melted off.. nothing damaged, something learned..
On the ground the slats were up. Remember both HB and Eduard didn't have the right idea about this, so I made some improvements..
nice see through, I think this is much better..
from below, the fence wraps around the leading edge..
with flap track rails..
after some Mr.Surfacer 1200..
With some old rockets I made the FMU-113 detonators..
Mk.82 with FMU-113 airburst, something like it at least..
once again..
AIM-9M Brassin style..
nosegear at about 90 degrees, whilst about 80 is more correct..
HB original..
and after..
Eduard doors..
stripped the main gear, left has been milled?..
turned into something like this..
rain/gun gas residue removal vents just in front of the windshield..
made a different and correct panelline, the forward part of the canopy hinges forward at this line..
almost ready for Mr.Color, but first some more primer..
This is truly one of the best 'in progress' builds I have ever read on this (or any other) site. The phrases "attention to detail", "incredible workmanship" and "museum quality" can all be overused in this hobby - but in reference to this project, I believe those phrases and so many more similar, cannot be used enough.
Simply inspiring.
Ian
  • 4 weeks later...
Got the dust off this A-10 and continued some more. The windshield is a bit too narrow for the hull, but with just a little pressure this will fit and it was glued together with Tamiya's Extra Thin Cement for a good joint.
Everything is primed and in theory ready for a color coat of Mr.Color 307 and 308.
Italeri nose as testpiece for the refuel boom dents..
the 4th try.. windshield sides tinted on bare plastic worked for me, albeit slightly too yellow.. (this will not work once the canopy has been in Future btw)
windshield primed..
