Fascinated by some modellers’ commitment to the craft!
6 minutes ago, Bigdave22014 said:
Well, I never thought I'd be impressed by someone putting masking tape on a model...... :clap:
Sums it up perfectly 😄
Keep up the meticulous work,
Alan
Thanks Dave and Alan for your nice comments. :worthy:
I was surprised myself - how good that I asked the Lady in the supermarket. top.gif
Hello everybody,
here for comparison a small photomontage of the new SOFI Pattern structure in the original image of the ET-8 during the Roll-out, which shows that it looks not so bad, right? up040577.gif
Source: forum.nasaspaceflight.com (Jester)
Thanks Mark, :worthy:
I'm just a fiddler and make an effort as well as possible. up040577.gif&key=327a20a361d18ad6d35cabf
Hello everybody,
for masking before Flour coating, I need a stable and secure solution, either with masking paint or tape, smiley215.gif especially since I have the cover problem as with the Ramps even with the other ET add-on parts, such as with the ET/Orbiter Interface Attachment, this is the rear support structure of the orbiter with the different vertical and diagonal struts,
as well as the LH2/LO2 PAL Ramps, etc. rolleyes.gif
The Airfix solution of this Interface attachment, on the other hand, looks a bit more modest and therefore is not quite realistic, nono.gif
Pretty much every time I read your postings Manfred, I learn something about the shuttle, modelling or both. Whilst it would be nice to see a finished model at some point, at the same time I don't want this to end. :)
Thanks Kirk for your nice words. :worthy:
I'm also learning something new every time about this brilliant technique, which is why I firstly always make a detailed research before I'm building, which is meanwhile like a drug, in this sense I am a junkie ... eek.gif
Regarding your nice desire, the Admin of our German Raumcon Forum already had the same wish long time ago,  and maybe many others might think so too. up040577.gif&key=327a20a361d18ad6d35cabf
Don't hurry for anyone but yourself Manfred.
As a matter of interest, when the stack is completed, will you be able to separate the orbiter and boosters from the ET or will they be permanently fixed?
According to my opinion a pluggable solution would be too complicated. hmmm.gif
Actually, all Stack parts should be firmly connected together because of the necessary stability. That's why I have planned a brass rod that goes through the Intertank's SRB fittings, on the ends of which the two boosters will be plugged onto. top.gif
Also, I need a solution that keeps the balance of the upright standing stack, for which I've been considering a solution like this with support bars through the TSMs into the Orbiter's Umbilical Plates. up045518.gif
Source: NASA
Source: NASA
That's why the Stack parts should actually be fixed permanently. up040577.gif
Hello  Manfred...
Been following this for a while now... you are doing an IMPECCABLE meticulous job .
Having been to the NASA museum ,seeing your build excites ME.
Keep the EXCELLENT  workmanship.
:mike:
23 hours ago, roma847 said:
... for which I've been considering a solution like this with support bars through the TSMs into the Orbiter's Umbilical Plates. up045518.gif
Hmm. If you do this, I don't think it will be able to take off at the end of the countdown. :D
11 hours ago, HOUSTON said:
Hello  Manfred...
:mike:
Thanks Houston for your nice words, :worthy: I'm glad if you like it what I'm doing here.  up040577.gif&key=327a20a361d18ad6d35cabf
That's right my friend, but Safety firstup040577.gif&key=327a20a361d18ad6d35cabf
Hello everybody,
and since both Airfix and Revell did not consider these two Umbilicals in their kits, but at least should be hinted, therefore here another view showing the connection of all lines and cables between the ET and the Orbiter Doors. top.gif
Source: NASA
And who wants to follow all the details exactly, can look at this drawing and even find some dimensions, whereby it should be noted that the struts are shown here without TPS.  up045518.gif
Source: System Definition Handbook SLWT - Vol. II
For the further building process, it will become useful to model the ET/Orbiter Interface Attachment incl. Umbilicals separately and to glue it only after the Flour coating, priming and painting of the ET. Then I need to mask only the connecting areas of the two Longerons as well as the foot points of the vertical struts.  speak_cool.gif
Then follows the mounting of the LO2 Feedline as well as the Ice Frost Ramps with the two GH2/GO2 Press. Lines and the Cable Tray on the LH2 tank, as well as the installation of the GO2 Press. Line along with its Ramps and Cable Tray on the LO2 tank.
And only at the very end the complete and painted ET/Orbiter Interface Attachment are glued and the corresponding line connections adjusted at the interfaces.
So far to the theory, that wants to be well considered. I just hope that this can also be realized in practice. up040577.gif
Hello everybody,
to get in advance an idea of the size of the two Umbilicals, which I want to scratch, cant-believe-my-eyes-smiley-emoticon.gif I reduced the drawing to 1:144 and cut out the Crossbeam with the Umbilicals and Cable Trays and put it onto the Crossbeam of the Airfix ET.  top.gif
And now one can see how small these miniature parts are that always look so huge in the photos. eek.gif
And matching it I have a great photo of my friend Scott "Shuttleman" Phillips (see arrow), standing as young but then already about 1.80 m large greenhorn next to a Original LH2Umbilical, which shows the true size of this part. erschrocken3.gif
54210419_10157266814004171_8389093546052
Source: Scott Phillips
By the way, Scott Phillips has been busy for quite some time with two very interesting projects in honor of the 50th Anniversary of the first Moon landing, which is imminent.
Source: NASA
Since I've supported him a bit, I was also let in on, but I had to promise him not to reveal anything, as it should become a surprise. up045518.gif
Here one can see Scott and his wife Dianne in the workshop of the creators before the internal unveiling of the "Corpus Delicti". cant-believe-my-eyes-smiley-emoticon.gif
Only so much in advance, it has something to do with historic wood ... smiley215.gif
Hello everybody,
in the meantime, I went into more detail to find out where the interface between the LH2 Cable Tray and the Aft ET/Orbiter Attachments is, or how the cables out of the the LO2 Cable Tray get there, especially since this is a pretty tricky affair and there are hardly any direct photos of this interface. smiley_worship.gif
One also should know how the cables run out of the cable tray onto the LH2 Tank from point A via B and C respectively D to the LO2/LH2 Umbilicals and wherefore this gray box (?) is used, which could possibly be a kind of distribution box? up047089.gif
Source: NASA
Maybe there are useful hints from the forum, if so, then always ago with it. up040577.gif
Hello folks,
to this question I also consulted my friend DaveS (forum.nasaspaceflight.com), who also had some interesting photos in stock, like this one.
Source: NASA
on which unfortunately one can not see this interface of the LH2 Cable Tray that interests me, as it is obscured by the Vertical Strut as in most photos. rolleyes.gif But at least one can see more of the arrangement of this gray 'distribution box', which apparently has such a function. huh.gif
Afterwards, I've continued to search for the interface myself, and as one could already see in this photo,
Source: NASA
the LH2 Cable Tray seems to run diagonally upwards at the point A, possibly to this 'distribution box', up047089.gif as it also appears in this photo of the ET-8 (STS-6).
Source: forum.nasaspaceflight.com (woods170)
The matter got a bit clearer to me when I saw this photo of the ET-119 (STS-121) zoomed in,
Source: NASA
on which one can see at the point A the continuation of the gray LH2 Cable Tray, but which not directly leads to the 'distribution box' but apparently to the Vertical strut. hmmm.gif
And then suddenly the penny dropped, idea1_2.gif when I've again checked this photo again and asked DaveS for it.
And on this image detail of ET-122 (STS-134) one can see this interface almost even better.  up046118.gif
And finally, DaveS confirmed my guess and sent me this detail photo of the ET-125 (STS-122), whereat the orientation is a bit difficult to see at first glance.  cant-believe-my-eyes-smiley-emoticon.gif
Who wants, can first try to find one's way before it goes on with the further course of the LH2 Cables, as they still did not arrive at the LH2 Umbilical ... up040577.gif
Hello everybody,
okay, I admit that this photo by DaveS takes some getting used to, and I also took some time to find my way, although I've already seen many similar photos, but not yet with opened cable tray.  top.gif
Source: forum.nasaspaceflight.com (DaveS)
What strikes all these photos is this ominous 'distribution box', huh.gif who initially looked orange-brown, as here at the mission STS-6
or here at STS-47
Source: georgesrockets.com (George Gassaway)
Only with the later missions he looked then gray, as in the following picture. As one can see, from this 'distribution box' the yellow marked LH2 Cable Tray seems to branch off, which then on the front of the Crossbeam runs to the other side to the LH2 Umbilical. hmmm.gif
Source: forum.nasaspaceflight.com (DDG40)
The confirmation for my guess came then with this great photo by Scott Phillips, speak_cool.gif whom I've also consulted, here with the front TPS covering removed.
And with that the hitherto searched interface of the LH2 Cable Tray gradually becomes clearer, which I have circled here yellow, which discharges into the TPS cladding of the Vertical Strut. top.gif
And, as I've learned by now, not only the LH2 cables run inside the LH2 cable tray, but also the LO2 cables, which was not clear to me yet. huh.gif But as I learned from DaveS too, the cable trays that time were named after the ET tanks (LH2/LO2) and say nothing about the cables running in it, but what one has to know. smiley215.gif
And by this picture-in-picture montage will hopefully become clear, where this place is located, whereby this image is rotated 90° and the TPS cladding on the front of the Vertical Strut is open (blue arrows). cant-believe-my-eyes-smiley-emoticon.gif
In the next photo one can see the opened LH2 Cable Tray in front of the crossbeam with the cables running into it, which lead to the LH2 Umbilical,
as well as here the cable harnesses laid in the opened knee of the LO2 Cable Tray. up045518.gif
And so I now know about how the cable trays and other lines run, and thus can try to scratch this ET/Orbiter Attachments accordingly. up040577.gif
Thanks my friend, :worthy: but that is illusory, as you know. But they can have a look at my thread in forum.nasaspaceflight.comcant-believe-my-eyes-smiley-emoticon.gif
And at the end, I'll make a video of the diorama so one can see the entire Launch Complex from all sides. up040577.gif&key=327a20a361d18ad6d35cabf
