Hello everyone,
my friend Joe has uploaded the two Sprocket Sets of 16 faster than expected and also sent me the screenshots of the related Support Material. cool.gif
Here is the support wax arrangement at the Flat set variant,
Source: shapeways.com (Crackerjazz)
and here at the Upright variant
I have now ordered the Set of 16-Flat Ori (FXD), and I'm curious if SW will print it without any trouble, what I expect, or if they will pull themself up again at the wall thicknesses (< 0,3 mm). up040577.gif
Lots of luck Manfred.
Thanks Rich, :worthy:
and Hello everybody,
my expectations of SW have been met, the Main Sprocket Set of 16-Flat Ori (FXD) was already let pass without hesitation and is In Production, speak_cool.gif wherewith also my 3D print projects would have been finished for now. yahoo.gif
Good morning, friends,
Hello everybody,
today came the Main Sprocket Set of 16-Flat Ori, which I have checked out closer, to see possibly, which side did lay below and therefore on the support wax. spiegel-smilies-0002.gif
I suspect that in the first picture one looks onto the bottom, which was lying on the wax and seems to be a bit rougher than the top in the second picture. top.gif
Under my LED lamp, the difference comes out a little better, therefore the same order of images, here is the view onto the bottom,
So well, I'll have to clean everything anyway in the ultrasonic bath, both the Track Shoes and the Sprockets. huh.gif
That's it now with the 3D printing but first, and I'm very satisfied with the result. up040577.gif
And my special thanks to my ARC friend Joe (crackerjazz), who did an amazing 3D job. lob3.gif
Top side/face out,  dose look better than the support wax side.  Very nice.  These are going to make your crawler look really good!
but now it's enough with the 3D show, the rest of the Crawler I'm going to scratch ... up040577.gif&key=327a20a361d18ad6d35cabf
and how are you satisfied, what did you order, 16 Flat Ori (FUD):hmmm:
Hello everyone,
maybe you already wondered about the break, but at the moment I am still busy completing the London Bus (1:24) of my best German Raumcon friend Thomas, who had gone much too early last year.
He wanted to gift this Routemaster to his wife as a reminder of her time in London, but whose completion he must have postponed again and again and therefoe unfortunately could not finish it anymore, since he was probably too busy with his beloved Launch Pad project ... default_hmmm.gif
Therefore, his wife had asked me if I could not complete the bus, because allegedly only the outer decals (advertisement, line, etc.) would be missing, which of course I could not refuse her. i5684_no2.gif
In the same sense I have also taken over parts of his awesome project Space Shuttle Launch Complex 39A with Discovery STS-41D, which I will integrate into my project keeping his legacy alive and in memory of him in this way ... up046595.gif
But it just was not only the missing decals, as his wife had meant at first, but the complete window set, etc. had to be installed, and also some small stuff then came to it, and so I also had to get a few spare parts from Revell ...
And this is how the bus looks right now, I hope for being able to send it next week, and finally fulfill my promise with the Routemaster's final Rollout. top.gif
So far from my intermediate stop at the London bus stop Route 76 Waterloo to Victoria ... default_hmmm.gif
Hello everyone,
after my longer stopover at the London bus stop of the Route 76 Waterloo-Victoria, as well as after the exhausting but ultimately successful 3D prints of the Track Shoes and Main Sprockets for the Crawler Trucks I want to turn once again to the Early LWT (ET-8). top.gif
After a long bickering in summer with Shapeways' service team, with whose print quality of the modified WSF Intertanks (right) I neither was satisfied, nor I wanted to accept that fact, smiley_worship.gif i5684_no2.gif
I had been fiddling even further together with Michael Key and at the same time still modified some so far missing details. up035091.gif
These concerned the so-called Flange Closeouts at the connections of the Intertank with the LH2/LO2 tanks, which were sprayed by hand.
Source: NASA
This photo shows such a Flange Closeout area after manual machining completed.
Source: facebook.com (Craig Capdepon)
These Closeout areas I've looked at in my photos of the ET-8 again closer and had marked them in the following images for a detailed discussion based on Michael Key's current 3D model. huh.gif
Source: forum.nasaspaceflight.com (Jester)
Source: retropaceimages.com (STS-6)
By comparison, this transitional area had not yet been differentiated enough in his model, what I have explained to him. cool.gif
While the flat area of the Closeout-2 is too narrow, the subsequent beveled area appears a bit too wide, which I have marked in this photo, and what one can see clearly on the right edge.
Source: georgesrockets.com (George Gassaway)
In the next image I've put the original photo and the 3D model directly next to each other for comparison. As one can see, the flat area of the front Closeout-2 should be widened to 2,5 mm, so that the remaining slope is only 1 mm wide, measured to the leading edge of the IT, i.e. 12 mm is the distance from the lower edge of the vent to the leading edge of the IT.
BTW, the Closeouts at the end of the IT require the same changes I've marked with tape to overview at this WSF-IT.
These changes were largely taken into account in the next model except for a small detail. rolleyes.gif In his model, however, there is no smooth transition from Closeout-2 to the 'normal' Closeout, but a step/staircase that is caused by the different inclinations of both areas, which is not correct. i5684_no2.gif However, by widening the flat area of Closeout-2 should allow a smooth transition with the same slope.
And even these transitions could finally still be adjusted, after which the 3D model looked perfect.  speak_cool.gif
And this is now definitely the final Early LWT Intertank for my STS-6 Shuttle Stack
Source: shapeways.com (The Aerospace Place)
but which I did not order it in WSF, but in FUD, that was delivered in the meantime too. Unfortunately, one can not see well the Closeout details on these FUD photos because of the transparency of the material. smiley_worship.gif
And the IT also fits well with the other two Airfix ET parts
but has now to be thoroughly cleaned again in the ChiliDent Laboratory, wherewith finally would be completed this stressful IT chapter. analintruder.gif And on this occasion, the Track Shoes and Main Sprockets will be patched up as well.  up040577.gif
Great work on finishing the bus Manfred. I have the same kit in my stash. I hope I can do half as good a job as you and Thomas did.
The new intertank looks great.
I look forward to seeing the legacy of Thomas’ launchpad and how you will integrate into your model. It’s a wonderful idea to preserve the work of a friend.
Thanks Mark for your heartfelt words of appreciation for my intention of keeping Thomas' Space Shuttle legacy alive in my Launch pad project, what I will now share with him. :worthy:
And if you've read his STS-41D thread to the end, you'll have seen that I've already taken over his awesome lighted Hammerhead Crane gut.gif and integrated it into the Tower, along with his beloved flashing beacon, up040439.gif which never had been installed on both Launch pads ... :hmmm:
