Homebee
1/72 - Short Sunderland Mk.V by Special Hobby - released
7 minutes ago, dalea said:
Hmm. Mk.1 gun hatches?
And also fuselage inserts without Mk.I gun hatches.
Special Hobby like to get the most out of their moulds, witness the recent P-40E/K/M/N series.  Likewise their Mirage F.1's have a lot on the sprues which are intended for different versions.
I'll be very happy with a proper Mk.5, I've always wanted to do a post war one.
Yes, At one point, a while ago, SH promised all marks of the Sunderland. Don’t know if Italeri’s release of two earlier marks have thrown cold water on those plans or not. Signs of Mk I parts gives hope. IMHO Italieri’s rather deep panel lines create an opening for a full line from SH.
Which mark should I aim for as a basis of a civil version? Quite fancy an overall white Sunderland sans shooting irons.
Tony
Tony
Either a Mk III or Mk V for conversion to Hythe or Sandringham, or for just a transport version of a Sunderland,
again either Mk III or V.
Just bear in mind that a one size fits all approach taken for the SH Sunderland will not give
you both.
The SH hobby has the engine nacelle mounting facings representing a Mk III/ Pegasus XVIII,
where as the Mk V had shorter mountings faces for the PW R1830 engine/engine bearers.
Regards
Alan
you both.
That's disappointing but there is hope, if you go to their homepage, there's a tab in the bottom RH corner of the page, I used it to inform them about the correct nose length of the Meteor NF.14 and for enquiries about their forthcoming Super Mystère and had pretty positive responses each time.  If you have useful information I'm sure they would want to hear it.
6 hours ago, dalea said:
Maybe it's just me but I can't find any sign or sight of the  actual engines.
It's not just you, that's what I looked for too, obviously on another sprue.  It would be nice to see the options.
That's what I was thinking but thankyou very much for clarifying things; it was all a bit vague and misty to me.
cheers
Tony
you both.
According to Kermit Weeks' Fantasy of Flight (where ML814 currently resides) website a large number of Pegasus engined aircraft were converted to PW engines because the PW engine gave propeller feathering capability. ML814 itself underwent this conversion. The PW engine installation was very similar to that on the PBY (again according to Weeks). So I question whether the mountings were really shorter because that would have made the conversion much more complicated.
Kermit Weeks "Sunderland" is no more a Sunderland than a AVRO Lancastrian is a Lancaster
Bomber
In 1963 RNZAF Mk V/MR5 Sunderland NZ4108 was sold to an Australian Airline, where it was
converted to a Sandringham. Because the work was not done at Shorts it could not be
called a Sandringham - Realistically the only real Sunderland parts are probably the floats.
Certainly some 88 Mk III's were converted to Mk V, but they did not retain the engine mounts
used for the Bristol Pegasus Mk XVIII engine - the mounting fairing is longer, you can see it in
these photo links
Pegasus XVIII Nacelle
Pegasus XVIII Nacelle 1
Pegasus XVIII Nacelle 2
MkV/MR5 Engine mount is quite different, as you can see in this photo link
Mk V Nacelle/Engine Mount fire wall
Sunderland NZ4108 (prev ML814) - Sandringham Conversion Rose Bay
NZ4108 landing Rose bay NSW Australia
NZ4108
Here you can see the actual Mk V Nacelle/Engine Mount retained - NOTE Not a Mk III mount
NZ4108 Conversion to Sandringham
As far as feathering Mk III propellers, from the Short Sunderland Mk III M&E manual
 the Sunderland III Aircraft Four Pegasus XVIII Engines manual (A.P. 1566C) Volume 1
Early Production Mk III Sunderland
D.H. 5/28, 3 bladed variable pitch (20 degree bracket type) with constant speed control.
Later Production Mk III Sunderland
D.H. DR. 2/345/2, 3 Bladed variable pitch, with constant speed control feathering.
Edited by LDSModeller
With Moson Model Show taking place on 27-28th April could it be an opportunity to get a few  Sunderlands fresh from the mould.
The price of the kit is one thing, and then you have the resin and p/e extras that double the total...
Not a huge fan of resin and don't use PE much at all (maybe the occasional seatbelt, but most of my canopies are closed). So maybe I can at least save on half of the price damage! :coat:
Given that the current Resin and PE for the current Sunderland models
is pure fiction, and I have no doubt that any aftermarket for the SH Mk V would be
just a s fictitious, you may as well save your money
16 hours ago, dalea said:
Oh, since I've just ordered some Mk 1 cowlings on spec., what's the matter with them?
Given that the Mk I had the inner Port Exhaust pipe goes through the leading edge
of the wing, and exit above the wing Then the Exhausts are wrong
 If you are trying to portray later Mk I, that may have had engine
upgrades then they should have really have the Porcupine Exhausts
Sunderland Mk I porcupine exhausts
4 minutes ago, occa said:
You tell us, or ?
Ignorance is bliss?
Thing is; when a model is sat on your shelf or a table at a model show or even a competition table does it really matter how accurate say a PE interior is given that nobody really cares or is knowledgeable to know otherwise but the builder has had the satisfaction of using said PE to refine his model however accurate and only you and a few other experts will know any better?
Mike
I am so looking forward to this kit and now that I`ve seen the decal options I know which one I will be building too.....nice one Special Hobby...... bring it on!!!
           Tony
2 hours ago, PhoenixII said:
@occa , @LDSModeller has to get some sleep, it was around 07:00 zulu in New Zealand when you posted..........:whistle:
Almost can't wait lol
