stoohoo
Revell / ICM Bf 109 F-4 trop, Hans-Joachim Marseille - FINISHED
Incredible bit of work Stu, really worth the effort you've put in. The cowling panel is a work of art.
Pete
Crikey,that looks a real beaut,and I see the Revell instructions are far superior to the flimsy 2 page photocopy job you get with the I.C.M. kit(That's my excuse,and I'm sticking with it :)
Thanks for the kind comments guys :) This is probably the most time consuming build i have done yet, its been fun but really happy to see it coming together now ...finally!
Carts - probably not much use but if you need it i can scan and email you the Revell instructions, they are pretty straightforward apart from mentioning part numbers that arent shown anywhere on the sprues..
Cheers again, Stu
Thanks for the kind offer Stu, but its all built up now.
Nice one matey. With the extra time you should be able to romp it in. The flaps look good, in fact the whole thing is a treat. Well done!
Regards
Cheers Kent :) hoping to get the gloss coat on later and decalling done over the weekend then the end will finally be in sight!
Glad the mossie build runs on so long might still be able to get in on that...
Hi all,
Just a very quick update to say all decals on and futured ready for sludge wash later (hopefully)
couple of pics
Cheers, stu :)
And finally here she is, all the little bits finished and stuck on - thank god for the extra week. This must be the most delicate model i have done to date, i'm scared to fart near it in case something falls off (to be fair not necessarily a bad thing) :)
Anyway on with some pics and then will do the gallery post.
Thanks Andy for organising a great group build and everyone who has taken the time to comment - now time to dig out the Revell mosquito for the STGB,
Cheers, Stu
Nice one Stu. Great finish!
:goodjob: looks fantastic, glad I didnt do this Marseille one, mine would look shocking compared to yours :yikes:
:cheers: cheers, great job !
Absolutely beautiful,A real stunner.
Wow Stu you've turned out a beauty, I'm getting some bits together for a Bf-109 in a North African scheme, if it comes out anything like yours I'll be a happy boy. What did you use for the exhaust stains? Really like the stains on the underside too.
Cheers...
Thanks for the kind comments guys, they are greatly appreciated :) I've really enjoyed this group build and glad that i (just) managed to get in within the extended deadline.
Pabbi - i know thats not the case, i saw yours in the inspirational gallery and it looks great! Although the kit may not be the best one on the market out of the box, its certainly a good base for a few hours of modelling fun :)
Cheers...
Cheers Mike - your Emils the nuts so will be keeping an eye out for your North Africa 109.
I sprayed the exhaust stains with a really thin mix of brown / black at about 10 - 12 PSI. I took the nozzle shroud off the airbrush, held the tip really close to the model and pulled the trigger ever so slightly so you can just about see it making a pinhead size wet patch, keep it moving and just let it gradually build up to get the colour.
On the underside i had a go with some oil paints which i had been wanting to try for a while, just putting a couple of small dots on where i wanted it to start and then dragging them with a brush dipped in white spirit and then wiped dry. Its possibly a bit heavy but can see myself having a go at this again in the future :)
Anyway cheers all and hopefully see you in the 110GB when it happens, if not before :)
Edited by stoohoo
Hi Stoohoo, I was so impressed with your build I went to my stash and blew off the dust on this one. However, I noticed you have the obligatory swastika on the tail, but that is not included in the original decal sheet (I guess because a German company is not allowed to??). So did you get your swastika decals from another sheet?
Also, could you please, please tell me what you used for your antenna and the little white insulation thingy-me-bobs that are on it? Seems I have been looking for a good antenna product for years and now I see you have the perfect solution! Great job all round and I hope I can emulate your efforts!!
Hi Dano,
Thanks for the really kind comments :)
The swastika was one I robbed from the spares box, I dont think its necessarily the correct type for the theatre and time period but fills the space (actually i think it might even be for a 1:72 tamiya FW190 :) ) I know Hannants in the UK have quite a few options for swastika decal sheets, I can understand why Revell wouldnt have them on thier sheets given the laws in Germany but suprised that Airfix dont either...
Not sure if you saw the RFI post i did but theres a link here as someone else had asked about the aerial wire and insulators:
http://www.britmodeller.com/forums/index.php?/topic/234934709-revell-icm-148-bf109-f-4-trop-hans-joachim-marseille/#entry1239583
Basically though the wire is just low breaking strain (about 1lb) match fishing line, it has a little elasticity so can be tensioned nicely before it is glued. Unfortunately on this build the kit mast was a bit flexible (should have replaced it) and has lost a bit of the tension. I painted the line with a thin mix of Revell aqua anthracite to give it a little bit of colour as well. The roundish insulators were little blobs of PVA that i painted white when set and the conical things were made by smashmoulding a hot tungsten scriber (i'm sure anything metal and pointy would do the same) into a sheet of thin plasticard and cutting off the cone that is formed - it took a couple goes to get right but got something useable in the end.
Anyway - I hope this is of some use to you and will be looking out for your build - are you going to do a WIP thread?
Cheers, Stu
