Dan Posted November 15, 2012 Share Posted November 15, 2012 Great work so far, your enhancements will no doubt turn this venerable kit into a beauty Link to comment Share on other sites More sharing options...
oldhouse Posted November 19, 2012 Share Posted November 19, 2012 Very nice progress !! keep it up !! Peter Link to comment Share on other sites More sharing options...
Doug Rogers Posted November 21, 2012 Author Share Posted November 21, 2012 Bit more done today, focussing on the undercarriage. Drilled out the spindles and made up some brake lines from 5A fusewire; Painted the legs with Xtracrylix RLM02, push fit the wheels onto the spindles and drilled the spindles so I could fit a split pin, just about visible from the end on; I've painted the cockpit interior too, not too much to see there. I'll get some pics of that up next. Link to comment Share on other sites More sharing options...
Duncan B Posted November 21, 2012 Share Posted November 21, 2012 No, they're moulded in, so I think I'l going to leave them alone. Pretty sure I read somewhere they can be in or out. They can be seen in either position on the ground, sometimes even one in and one out as they were sprung loaded and not interconnected so if someone pushed on one side it would stay in. Duncan B Link to comment Share on other sites More sharing options...
Doug Rogers Posted November 21, 2012 Author Share Posted November 21, 2012 That ties in with what I thought Duncan. Remember seeing a documentary where the guy doing the pre flight checks was demonstrating how sensitive the slats were, and how he could just push them back into the closed position with one finger. Link to comment Share on other sites More sharing options...
Spikelhund Posted November 21, 2012 Share Posted November 21, 2012 Excellent work on the undercarriage Doug. Cheers... Link to comment Share on other sites More sharing options...
Doug Rogers Posted November 22, 2012 Author Share Posted November 22, 2012 Pics of the fuselage sides, nothing too fancy as there's not a lot of detail and you won't be able to see much of it with Gerhard in there anyway; Made up a shroud for the exhaust stacks on the left hand side out of some spare PE. Why does the cover on the left extend further down than the one on the right? Pilot is pretty much painted up, just need to do a little more detailing on him. Link to comment Share on other sites More sharing options...
timmah Posted November 22, 2012 Share Posted November 22, 2012 Why does the cover on the left extend further down than the one on the right? Hi Doug I think its to stop any exhaust gases from going into the supercharger intake, but I could be completely wrong of course! Like what you've done so far, keep up the good work! Regards Tim. Link to comment Share on other sites More sharing options...
stoohoo Posted November 23, 2012 Share Posted November 23, 2012 Thats coming together great Doug, especially like your work on the undercarriage - looking forward to seeing Gerhard in his mount Stu Link to comment Share on other sites More sharing options...
smuts Posted November 23, 2012 Share Posted November 23, 2012 Very nice work Doug.. Andy. Link to comment Share on other sites More sharing options...
Doug Rogers Posted November 24, 2012 Author Share Posted November 24, 2012 (edited) Bit more done today, seperated the tailwheel so that I could turn it slightly. Just a small change that adds a bit more movement to the model; Drilled and pinned it with some .5mm brass rod; Here's Gerhard, not the best pilot I've ever painted but he'll do in the closed cockpit; Fuselage is together now so should be able to progress a bit more quickly now; Made a brass prop shaft and sleeve for the prop. Used the kit prop pin for the sleeve by snipping off the pin and drilling a hole for the tube. The good thing is it spins a lot more freely and is removeable for cleaning and moving; So here's where I'm up to at the moment, cowling and canopy are just placed in position at the moment. undercarriage legs are glued on, rudder is also glued on, again slightly deflected. Edited November 24, 2012 by Doug Rogers Link to comment Share on other sites More sharing options...
Duncan B Posted November 24, 2012 Share Posted November 24, 2012 Hi Doug I think its to stop any exhaust gases from going into the supercharger intake, but I could be completely wrong of course! Like what you've done so far, keep up the good work! Regards Tim. You got it right Tim, the cover is to deflect exhaust gases away from the intake. Duncan B Link to comment Share on other sites More sharing options...
Doug Rogers Posted December 20, 2012 Author Share Posted December 20, 2012 Got some painting done yesterday and today; Using Xtracrylix RLM 74/75/76, have to say they go on really nicely. Yellow is Humbrol 24. Can make a start on the mottling now!! Seems like an unusually random effect they had on the original machine, so I'm just going to try and copy whats on the decal sheet. Think I'll give it a coat of Klear first though, just in case. Link to comment Share on other sites More sharing options...
Doug Rogers Posted December 27, 2012 Author Share Posted December 27, 2012 Got the mottling done today; Just got the last few bits and bobs to go on, pitot tube, undercarriage covers, aerial etc. Link to comment Share on other sites More sharing options...
Spikelhund Posted December 28, 2012 Share Posted December 28, 2012 Looking very nice Doug, paintwork looks excellent. Do you use the xtracrylics thinners with your xtracrylics? I like the paints when I can get them to spray and not clog, wondered if the thinners Might help. Keep up the good work, looks like your nearing the finish line. Cheers... Link to comment Share on other sites More sharing options...
Radleigh Posted December 28, 2012 Share Posted December 28, 2012 Looking rather good that Link to comment Share on other sites More sharing options...
Doug Rogers Posted December 28, 2012 Author Share Posted December 28, 2012 Thanks guys, yes nearly there. Mike - No I didn't use thinners, just water with a drop of washing up liquid. Link to comment Share on other sites More sharing options...
stoohoo Posted December 28, 2012 Share Posted December 28, 2012 Looking great Doug, nice work on the mottling Might have to give the water and washing up liquid a go, usually use the xtracrylix thinners but looks like youve got a great result without Stu Link to comment Share on other sites More sharing options...
Spikelhund Posted December 28, 2012 Share Posted December 28, 2012 Thanks Doug, now I know how you achieve such clean paintwork :-/ Cheers... Link to comment Share on other sites More sharing options...
Doug Rogers Posted December 31, 2012 Author Share Posted December 31, 2012 (edited) Going to call this one finished, quite pleased with the result, although despite a few tweaks here and there I think the kit does have it's limits, or rather perhaps the limits were mine! Still for a 1978 kit I still think the shape looks great; More in the gallery. Edited December 31, 2012 by Doug Rogers Link to comment Share on other sites More sharing options...
PanzerPaulo Posted December 31, 2012 Share Posted December 31, 2012 ohhhhh excelent!! Link to comment Share on other sites More sharing options...
Doug Rogers Posted December 31, 2012 Author Share Posted December 31, 2012 Thanks Paulo, better get on with the other 109E-1 now. Link to comment Share on other sites More sharing options...
PanzerPaulo Posted December 31, 2012 Share Posted December 31, 2012 one down, one to go!! Link to comment Share on other sites More sharing options...
stoohoo Posted December 31, 2012 Share Posted December 31, 2012 Lovely work there Doug, youve made the old girl look great! Look forwards to seeing how you get on with the E-1 Link to comment Share on other sites More sharing options...
Artie Posted December 31, 2012 Share Posted December 31, 2012 (edited) It's certainly an oldie, but surely a goodie. The Airfix Bf109F is a very nice, simple to build, kit. The only issue (not for me at all) are the tiny raised panel lines. With some care and love, this kit can turn into a very good looking model, as you've achieved with yours.. Keep your good work, you'll find some old kits are really pleasant to build... Cheers.....!!!!!!! Edited December 31, 2012 by Artie Link to comment Share on other sites More sharing options...
