Il-62M 1980 Official Olympic Carrier
Pin
When Zvezda has revealed their plans to release Il-62M in 2013 the value of RusAir resin kit started to diminish. Therefore I got the box from my loft and decided to join this group build before this kit is completely of of season
The kit consists of a dozen finely casted high quality resin parts - no sign of bubbles and very little flash
There are several decal options, I've chosen "Aeroflot - Official Olympic Carrier" of Moscow 1980 Olympic Games.
Four massive engines make the model quite a tail sitter
First operation complete - closed the fuselage halves. Applied some Mr. Resin Surfacer to reveal seam problems
There is no Zvezda kit yet - only a declaration of intentions. When it is out I'm expecting the same quality and atten
tion to the details as with Tu-134 and Tu-154.
Said that I can tell you in advance the areas where Zvezda will be ahead of RusAir - transparent cabin and cockpit windows, better detailed landing gear, antennae (that simply are not provided in RusAir kit), possibly better engine exhaust, and, of course, affordability - being a resin kit RusAir is relatively expensive.
What Zvezda will not be able to achieve due to technology limitations - razor sharp trailing edges. Traditionally I expect crappy decals - RusAir's are printed by Begemot
ok then....I wonder how it will compare to the intended Zvezda kit :)
looking very smart - re the nose weight; the real one had an extending tail support when parked on the ramp.
Are you including this?
I will be doing the aircraft in parked position with engine plugs (red ones) inserted into intakes and exhausts. This means tail support is in fully extended position - wheels on the ground. I nevertheless prefer to add nose weight - tail strut should be quite thin, I don't want to put it to much stress
  • 3 weeks later...
Slowly moving forward (well, I must confess this is my background project)
Three more colours applied - we are ready for decaling
Wheelware is a disappointment - crudely mastered and badly casted. This is where Zvezda would easily outclass RusAir
Edited by Pin
Most decals are in place
I'm not quite happy with how windows came out - there is a strange approach when the cheatline is just a blue-white stripe with separate white outline and black window "bodies", i.e. there are three layer of decal. There are also a couple of nicks that I will either paint or hide with spare decals.
