Pascal Posted September 28, 2012 Share Posted September 28, 2012 I'm wondering if it's possible to do a conversion of a Revell Mk I/II or a Hase Mk Vb. Filling or sanding the panellines, modify the radiators, propellor and tailwheel. Finding somebody that can vacuform the canopy... But I've read somewhere that the shape of the wings is different. Does anybody have more info on that ? Link to comment Share on other sites More sharing options...
rs2man Posted September 28, 2012 Share Posted September 28, 2012 I think the mod to the wing involved shortening the wingtips a little rather than altering the main planform of the wing , so you should be able to reshape the wingtips to suit . Here's a link to a set of plans , which you may find helpful . http://www.the-blueprints.com/blueprints/modernplanes/modern-su-sz/18733/view/supermarine_high_speed_spitfire/ Link to comment Share on other sites More sharing options...
John Aero Posted October 4, 2012 Share Posted October 4, 2012 Those drawings have to be wrong. The span of the High speed spitfire was 33.67 feet (33'.8.04") which leaves a bare 7" after the normal wing tip break on which to put a reasonable radius. I suggest that the wing was re-designed outboard of the wheel bay and it had no normal tip break rib. John Link to comment Share on other sites More sharing options...
gingerbob Posted October 7, 2012 Share Posted October 7, 2012 (edited) Hmm, you've got me wondering, John. The Spec for the Mk.III ("Improved Spitfire") proposes the same wing shape as the Speed Spit, and gives the span as 33' 8" and (gross) wing area of 231 sq ft. It says this: 3. Wing surfaceThe wing area is slightly reduced without interfering with the main structural members, except at the tip where the area is removed. (It specifically links the reduced wing to the Speed Spit, and elsewhere:) The High Speed Development Spitfire incorporates a reduction in wing area which can be easily applied to production aircraft. That's a little vague, but seems to suggest that it does not affect the main wing structure. Also, if the change came farther inboard than the tip, it would immediately affect the aileron, and I am not aware that the aileron is any different in size on the Speed Spit. However, in the interest of confirming the aileron point, I looked at pictures, and now that I look it appears that the leading edge may start "rounding off" sooner than the normal Spit wing shape. This could also be interpreted to fit the description above! Also, it seems to me that there probably was some reason they could not stick a normal wingtip back on, or it likely would have been done. Egads, another assumption called into question; another direction for further investigation... I shoulda stuck to studying the Farleigh Fruitbat! bob p.s. This may be too amateur for usefulness, but I tried to get a side-by-side comparison. Flipped and scaled, but no proportions were harmed in the making of this picture... Note how when the wingtip is cropped at (hopefully) about the right place on the top, the curve seems less dramatic, while on the lower one it seems more "curvy" on the Speed Spit. Edited October 7, 2012 by gingerbob Link to comment Share on other sites More sharing options...
Edgar Posted October 7, 2012 Share Posted October 7, 2012 Remember that K5054 had no separate wingtips; if N.17 used a similar set, they could have been modified anywhere. Edgar Link to comment Share on other sites More sharing options...
Radalt Posted October 7, 2012 Share Posted October 7, 2012 If you find a canopy let me know as I would be interested in one as well. I have been looking for one for some time. Link to comment Share on other sites More sharing options...
Bengalensis Posted October 8, 2012 Share Posted October 8, 2012 This is interesting. One of my favourite aircraft subjects, probably the top one. About two years ago I finally (after many pretty crude attempts in 1/72 as a young kid in the early 70's...) pulled myself together and built the Speed Spitfire in 1/24 scale, using Trumpeter's MkVb as a base. Yes, it took a lot of modifications and studying to pull it through... Anyway, about the wing. When reducing the wing to correct span, I found it impossible to get a shape that looked even remotely correct if I only reworked the tips. I did some sketching with a pen first, but a reasonable curvature was simply not obtainable that way. Then I did some photo comparison similar to gingerbob's above and decided I had to start the reshaping further inward, also slightly affecting the ailerons. That's when it started to look right, probably not 100% though, I should have rounded even a little more inside of the tips. So I too think a larger part of the wing than only the tips was affected. Link to comment Share on other sites More sharing options...
gingerbob Posted October 9, 2012 Share Posted October 9, 2012 Wait a minute! Where's the photos of the finished build? We (I) want to see! Link to comment Share on other sites More sharing options...
MilneBay Posted October 11, 2012 Share Posted October 11, 2012 Wait a minute! Where's the photos of the finished build? We (I) want to see! I'll second that. Link to comment Share on other sites More sharing options...
Bengalensis Posted October 11, 2012 Share Posted October 11, 2012 I discovered I actually didn't have any photos of the finished model, just a few pictures during progress, so I took a few yesterday. Will put a thread under the "Ready for inspection" tonight. Here is one for the time being. 2 Link to comment Share on other sites More sharing options...
gingerbob Posted October 11, 2012 Share Posted October 11, 2012 Oh mama! Please include the during-construction shots, too- looking forward to it... bob Link to comment Share on other sites More sharing options...
Col. Posted October 11, 2012 Share Posted October 11, 2012 That looks a bit stunning! Look forward to seeing the Ready for Inspection thread. Link to comment Share on other sites More sharing options...
Dave Swindell Posted October 11, 2012 Share Posted October 11, 2012 Tasty! Please post more! Link to comment Share on other sites More sharing options...
gingerbob Posted October 11, 2012 Share Posted October 11, 2012 (edited) FYI, Jörgen's thread is up: http://www.britmodel...topic=234927724 Edited October 11, 2012 by gingerbob Link to comment Share on other sites More sharing options...
Andrew Jones Posted October 12, 2012 Share Posted October 12, 2012 (edited) Those drawings have to be wrong. The span of the High speed spitfire was 33.67 feet (33'.8.04") which leaves a bare 7" after the normal wing tip break on which to put a reasonable radius. I suggest that the wing was re-designed outboard of the wheel bay and it had no normal tip break rib. John I believe John is quite right here in his suggestion of the wing re-design. From the Minutes of a meeting held at Eastleigh on 7th september 1937, chaired by E H Mansbridge, " The question of wing area was raised and it was agreed that the easiest way of reducing area would be to use a standard wing from the fuselage out to the wheel housings , leaving the chassis and glycol cooling system untouched . A new wing tip would be designed .It was estimated that maximum speed could be increased by 10-15 mph by such a reduction. " [ source Spitfire the History ]. It would also appear that only the starboard flap was shortened by the removal of the inboard section, due to the larger coolant radiator, because the removed section was close the the aircraft centre line, no serious rolling problem was expected when the flaps were lowered due to asymmetry. Andrew Edited October 12, 2012 by Andrew Jones Link to comment Share on other sites More sharing options...
JOAN Posted October 12, 2012 Share Posted October 12, 2012 (edited) Jörgen, your model is stunning ! I wonder what kind of paints was used for this so smooth glossy finish ????? I have no pic of this N17 in my collection today and it is certainly a big lack....but I have the K9834 : cheers Olivier Edited December 16, 2012 by JOAN Link to comment Share on other sites More sharing options...
Pascal Posted December 9, 2012 Author Share Posted December 9, 2012 (edited) Does anybody have more pictures of this aircraft whe she was displayed in Brussels ? Like this one : Or pictures of N17 with the prop that's on the picture ? Sincerely Pascal Edited December 9, 2012 by Pascal Link to comment Share on other sites More sharing options...
Pascal Posted January 23, 2013 Author Share Posted January 23, 2013 Well it seems that pictures of the Speed Spitfire at the Brussels Airshow are very hard to find. Did she fly with the 3-bladed prop that's on the picture above ? And would the colour of the prop-blades have been black ?  Sincerely  Pascal Link to comment Share on other sites More sharing options...
Giorgio N Posted January 23, 2013 Share Posted January 23, 2013 (edited) I believe she flew with the propeller shown above as Spitfire the History mentions the aircraft flying with the DH propeller, and the one in the picture is a DH propeller modified with metal fairings at the spinner (the 4-blade prop was a Fairey Reed) Edited January 23, 2013 by Giorgio N Link to comment Share on other sites More sharing options...
