Romeo Alpha Yankee Posted September 20, 2012 Share Posted September 20, 2012 You make it look so easy Tom. I am tempted to have a go at one of my vacs..... Link to comment Share on other sites More sharing options...
RNoAF Aerobatic Team Posted September 20, 2012 Share Posted September 20, 2012 (edited) I dread vacform. I have a Welsh 737... Afraid to try... But this is looking good! Edited September 20, 2012 by RNoAF Aerobatic Team Link to comment Share on other sites More sharing options...
tomprobert Posted September 20, 2012 Author Share Posted September 20, 2012 I dread vacform. I have a Welsh 737... Afraid to try... But this is looking good! Welsh vacs are , in my opinion at least, the best vacs to get started on. The fit is sually excellent, and once removed from the backing plastic build just like an injection kit. Give it a go! Link to comment Share on other sites More sharing options...
Kev1n Posted September 20, 2012 Share Posted September 20, 2012 as usual I expect the spectacular from you Tom,,,,, by the way - if your doing this in QF livery, can I persuade you to part with the Pan Am decal sheet? Link to comment Share on other sites More sharing options...
tomprobert Posted September 20, 2012 Author Share Posted September 20, 2012 as usual I expect the spectacular from you Tom,,,,, by the way - if your doing this in QF livery, can I persuade you to part with the Pan Am decal sheet? Yup - pm me your address and it's yours. Link to comment Share on other sites More sharing options...
Viking Posted September 20, 2012 Share Posted September 20, 2012 Fast work Tom, and very neat too ! You are tempting me to try and get one. Cheers John Link to comment Share on other sites More sharing options...
RNoAF Aerobatic Team Posted September 20, 2012 Share Posted September 20, 2012 I have to take out my Welsh sometime... But not for this build:-) Link to comment Share on other sites More sharing options...
cuprar Posted September 20, 2012 Share Posted September 20, 2012 Great start Tom Link to comment Share on other sites More sharing options...
Kev1n Posted September 21, 2012 Share Posted September 21, 2012 pm sent Link to comment Share on other sites More sharing options...
tomprobert Posted September 23, 2012 Author Share Posted September 23, 2012 This build has been progressing nicely over the weekend. I have filled the joins on the fuselage and sanded them - there were no issues at all here and I'm pleased with the result: I've also cut the wings out, sanded them so they are the correct thickness and glued them together. Again there were no fit issues at all, and just a quick lick of filler will be needed along the leading edges. The wheel bays will be made form plasticard in due course: So far so good! Tom Link to comment Share on other sites More sharing options...
cuprar Posted September 23, 2012 Share Posted September 23, 2012 I'm WATCHING close Link to comment Share on other sites More sharing options...
living legend Posted September 23, 2012 Share Posted September 23, 2012 Very nice work. Fantastic job on the wings! Link to comment Share on other sites More sharing options...
Romeo Alpha Yankee Posted September 23, 2012 Share Posted September 23, 2012 Looks like you have this vac form stuff worked out. How to do you know how far to sand the wings. My first attempt wa sa disaster! Link to comment Share on other sites More sharing options...
Jessica Posted September 24, 2012 Share Posted September 24, 2012 The best trick I ever learned for sanding the wings is to spray the whole sheet with primer before snapping out the parts. This leaves a white edge of raw plastic below the primered part. Then sand, and when you can't see any more white, you're done. 1 Link to comment Share on other sites More sharing options...
Romeo Alpha Yankee Posted September 24, 2012 Share Posted September 24, 2012 The best trick I ever learned for sanding the wings is to spray the whole sheet with primer before snapping out the parts. This leaves a white edge of raw plastic below the primered part. Then sand, and when you can't see any more white, you're done. Thanks Jessica, I think I will have a go at that. Link to comment Share on other sites More sharing options...
tomprobert Posted September 24, 2012 Author Share Posted September 24, 2012 Looks like you have this vac form stuff worked out. How to do you know how far to sand the wings. My first attempt wa sa disaster! I've tried a number of ways, including something similar what Jessica has suggested, but the one that works best for me is when removing the part from the plastic sheet, leave approximately 2-3mm of the backing sheet around the part. Then I sand away until this backing plastic falls away, and when this occurs you know you are at the correct tickness. A little final thinning is needed on the trailing edges, and then you'll be done. Tom Link to comment Share on other sites More sharing options...
JFCB89 Posted September 24, 2012 Share Posted September 24, 2012 Great work! This is going to be a very nice built Still got an Welsh MD-11 in the stash, but I think i'm not skilled enough to built it. I just need to keep a close eye on your build Link to comment Share on other sites More sharing options...
living legend Posted September 25, 2012 Share Posted September 25, 2012 Thx for the tip on the wings. Ive got a few vacs in the stash and will use that when I get around to building some. So far the only vac kit Ive done had resin wings and bits. Link to comment Share on other sites More sharing options...
tomprobert Posted September 29, 2012 Author Share Posted September 29, 2012 I've got plenty more done on this build over the last week. The wings were attached and the joints filled: Then when everything was sanded in nicely I got the Braz RB211s together and attached them to the wings: I've also added the nose and body gear, as I needed to check that everything sat nice and level: The wing tip aerials were made from stretched sprue, and have been added to the wing tips and blended in with filler. Next job will be the stabilisers... Link to comment Share on other sites More sharing options...
jenshb Posted September 29, 2012 Share Posted September 29, 2012 You make it look so easy Tom... Jens Link to comment Share on other sites More sharing options...
Marcos Borges Posted September 29, 2012 Share Posted September 29, 2012 Following with great interest. Nice job!! Cheers, Marcos. Link to comment Share on other sites More sharing options...
living legend Posted September 30, 2012 Share Posted September 30, 2012 Fantastic job! Link to comment Share on other sites More sharing options...
Romeo Alpha Yankee Posted September 30, 2012 Share Posted September 30, 2012 (edited) Nice progress Tom, I always seem to break those tip HF antennae and try to pin them with varying degrees of success. Edited October 26, 2012 by TrojanThunder Link to comment Share on other sites More sharing options...
Kev1n Posted September 30, 2012 Share Posted September 30, 2012 ...I always seem to break those tip HF antennae and try to pin thme with varying degrees of success. Tom is Tom. He is different from normal mortal people. He is probably from another planet. Where they have very big houses and are all brilliant model makers. Link to comment Share on other sites More sharing options...
JFCB89 Posted September 30, 2012 Share Posted September 30, 2012 Going great so far! Got to agree that you make it look like it's an easy built! Link to comment Share on other sites More sharing options...
