buttoncup Posted September 8, 2012 Share Posted September 8, 2012 Hello all, My first V bomber XH558 Cockpit thanks for looking 1 Link to comment Share on other sites More sharing options...
buttoncup Posted September 10, 2012 Author Share Posted September 10, 2012 hello, Not sure where to ask, but the fit of the wings to the body is very bad, big gaps, my mistake modeling skills or bad kit? Whats the best way to get the wings on? cheers Link to comment Share on other sites More sharing options...
Darth Vader Posted September 10, 2012 Share Posted September 10, 2012 Bad kit ! go to the Group Build and check out Robvulcans build . This will show you what to do Link to comment Share on other sites More sharing options...
buttoncup Posted September 10, 2012 Author Share Posted September 10, 2012 Bad kit ! go to the Group Build and check out Robvulcans build . This will show you what to do thank you, i had a look, but the vulcans body is alreadybuilt so filler and many cuss words it is! Link to comment Share on other sites More sharing options...
pigsty Posted September 10, 2012 Share Posted September 10, 2012 Well, if the fuselage is already in one piece, it's not a complete dead loss. Assemble your wings; test-fit; file away any proud bits. That will reduce the gaps by some way. Then - as this still leaves gaps you could fit your foot in - be prepared to fill with plastic strip, not just filler. It can make for a much stronger joint that way. Link to comment Share on other sites More sharing options...
buttoncup Posted September 10, 2012 Author Share Posted September 10, 2012 Well, if the fuselage is already in one piece, it's not a complete dead loss. Assemble your wings; test-fit; file away any proud bits. That will reduce the gaps by some way. Then - as this still leaves gaps you could fit your foot in - be prepared to fill with plastic strip, not just filler. It can make for a much stronger joint that way. thanks i will have to try that, never used plastic strip before. live and learn! Link to comment Share on other sites More sharing options...
garryrussell Posted September 11, 2012 Share Posted September 11, 2012 Yes the plastic strip is a sound idea What I do is heat some spare sprue and stretch it and that give some nice flexible strips to stuff into the gaps and using liquid cement it softens nicely One the glue melted plastic is set you will have a join that is probably stronger that the surrounding model, certainly it will make the fuse and wing effectively one piece. Link to comment Share on other sites More sharing options...
buttoncup Posted September 11, 2012 Author Share Posted September 11, 2012 Ok what I have done is mix filler with poly cement, and stuff in strips of sprue. Big gaps going away! Thank guys, will update with some photos later. Link to comment Share on other sites More sharing options...
buttoncup Posted September 18, 2012 Author Share Posted September 18, 2012 Hello all, so got quite a bit done over the weekend. wings on and started filling landing gear on and tail on 1 Link to comment Share on other sites More sharing options...
