SaintsPhil Posted September 2, 2012 Share Posted September 2, 2012 Evening every one! I've been having some strange reactions when spraying Mr Color (the laquer based type) thinned with Mr color thinners, which I assume is ok given the instruction are in Japanese! I seemed to get what I can only describe as cob webs developed on the model! I was cleaning the airbrush between colours with cellulose thinners. Anyone had this happen or can shed any light on the issue? Link to comment Share on other sites More sharing options...
Scimitar F1 Posted September 2, 2012 Share Posted September 2, 2012 You haven't thinned the paint enough and it is drying mid-air. Ideally you should use the levelling thinner for a better finish as it has some form of flow enahancer. Will Link to comment Share on other sites More sharing options...
SaintsPhil Posted September 3, 2012 Author Share Posted September 3, 2012 Thanks, it was actually the levelling thinners I was using, I thought it was pretty thin but I guess not! It went away after a few sprays, so maybe the paint wasn't mixed with the thinner properly. Thanks for your help! Link to comment Share on other sites More sharing options...
c.smith10 Posted September 3, 2012 Share Posted September 3, 2012 (edited) Hi Im using mr color with there levelling thinners too and had similar problems. the way i have got round it is to mix the paint and thinners in the cheap plastic party cups that you can pick up 100 for £1. Once i started mixing paints this way i had no more problems. If you dont want to go down that route then make sure you put the thinners in the airbrush paint cup first and add the paint slowly this will stop the spiders web but you still end up with thicker,not properly thinned paint at the bottom of the cup. Other than that and the smell i found these the best paints i have ever used cheers Edited September 3, 2012 by c.smith10 Link to comment Share on other sites More sharing options...
SaintsPhil Posted September 3, 2012 Author Share Posted September 3, 2012 Thanks, I do normally mix externally but I was worried the hot thinners might melt the plastic shot glasses I use! Guess I'll test first... Incidently I saw a good tip for mixing paint in the paint cup, in an airbrush video. Loosen the nozzle so it blows air back into the cup, as if you're backflushing, just make sure you cover the top!! I agree fantastic paints Thanks again gents. Phil Link to comment Share on other sites More sharing options...
c.smith10 Posted September 3, 2012 Share Posted September 3, 2012 I've had no problem mixing Mr Color in Asda party cups. Although there thinners are hot i dont think they are hot enough to melt most plastics. I have used the levelling thinners on a Q tip to remove paint with no affect to the underlying plastic! Interesting idea on the blow back mixing! only problem for me is my H&S airbrush doesnt have a lid!! Link to comment Share on other sites More sharing options...
SaintsPhil Posted September 5, 2012 Author Share Posted September 5, 2012 Neither does mine, I just put a bit of kitchen roll over the top, or point it away from me, I spray in garage do doesnt really matter if it goes on floor! Link to comment Share on other sites More sharing options...
Scimitar F1 Posted September 5, 2012 Share Posted September 5, 2012 What pressure are you spraying at? I always put my finger over the opening and bubble the paint to mix it - more important with Alclad. It never leaves the cup or makes a mess. I always start with a quick blast of thinner before adding the paint Will Link to comment Share on other sites More sharing options...
SaintsPhil Posted September 5, 2012 Author Share Posted September 5, 2012 Usually somewhere around 15psi, but was a but lower as I was trying to do some minor touch ups. I find I can normally bubble in the cup, but the trigger on the H&S is a little loose so sometimes it spits over. I normally always start with thinners Link to comment Share on other sites More sharing options...
