phat trev Posted August 29, 2012 Share Posted August 29, 2012 Considering gettng an SMER 1/72 Fairey Firefly FR1, is it good or not (raised or engraved lines, fit etc), whos moulding is it? Link to comment Share on other sites More sharing options...
Vulcanicity Posted August 29, 2012 Share Posted August 29, 2012 (edited) I have a suspicion that it's the old Frog mould. (you can probably imagine what that means in terms of detail etc...) EDIT: The first paragraph of this decal review would appear to confirm this... http://modelingmadness.com/scott/decals/aero/am72194.htm Edited August 29, 2012 by Vulcanicity Link to comment Share on other sites More sharing options...
Test Graham Posted August 29, 2012 Share Posted August 29, 2012 Yes, sadly for you, but it's not the only one as the review suggests. There is also the Special Hobby kit. The Frog kit is fairly accurate in outline although a blank of something will be needed in the intake, and a fair bit of work generally. I suspect Falcon transparencies will be required. Link to comment Share on other sites More sharing options...
The wooksta V2.0 Posted August 30, 2012 Share Posted August 30, 2012 There was a Smer hi tech boxing which gave vacform canopies and etch. Link to comment Share on other sites More sharing options...
phat trev Posted August 30, 2012 Author Share Posted August 30, 2012 cheers for the replies, pity as I was hoping for somthing as good as thier Il2 Link to comment Share on other sites More sharing options...
Test Graham Posted August 30, 2012 Share Posted August 30, 2012 The Il2 is pretty well unique in being a SMER tooling. Their range is almost completely reruns of older manufacturers, especially Heller but some Frog and others including Merit! Link to comment Share on other sites More sharing options...
