Here's my entry for the group build - a nice Eduard FW190-F8 Profipack. Not decided on which scheme to do yet, but it doesn't make a difference yet
So work starts with the cockpit - slotted all the plastic bits together, then added some of the PE (the non pre-printed bits)
Then added all the 'pre-printed' PE - ended up painting the PE anyway as Eduard have managed to get the RLM66 a different colour from the paint. Weathered the cockpit with some chipping, an oil wash and some dirt pigments.
Not a bad mornings work :winkgrin:
Peter
Edited by Peter Marshall
That PE looks the business Peter. If you don't mind me saying, I think the part behind the pilot's seat is the wrong way round though.It represents a hinged cover for an area the pilot to keep his 'stuff' in, so the hinge should be on the furthest edge from the seat. If I recall correctly from reading some of the STGB builds, the Eduard instructions for that part is wrong.
Chris
Started with the MG cowlings. As i'm building the 190 closed up there are a few shortcuts, one of which is that you can leave out the MG mountings
Then made up the wing and the wheel bays - RLM02 all round, followed by some oils
Then attach the wings - as is normal with Eduard 190's there's always a little gap, so some shims were required
Finally added the last of the cockpit combing and the gun sight
Peter
Onwards with the fun bit - this is the way I build Eduard 190's when not having the panels open.
First build up most of the cowling, then trim the exhaust stacks and glue to the inside of the cowling
Then build up the cooling fan, and front two banks of the engine, and glue into the front of the cowling
Then glue the whole lot in place - this avoids the alignment issues with the engine bearers
Some Mr Surface 500
Then wipe with IPA cotton bud to clean it up
Then finally i've masked the canopy, and fitted the front portion and masked off the rest - next weekend Paint !
Peter
As i've got the day off, i've got some more done on the 190
First up, masking off the wheel wells with tissue
Then on with Primer, and sanded back
On with a coat of Alclad Aluminium
Then Hairspray and salt for the chipping of the main camo
Then finally sprayed and post shaded the RLM-76 undersides, which needs to cure before I start on the RLM 83
Peter
Agh! Wish I'd thought of that simple route for attachment of an engine-less cowling when I was building my two for the 190 GB - simplicity
Today's work on the 190 - first the RLM 83 Green
Masked and sprayed the yellow nose band
Then using home made masks i sprayed the main markings - this is mainly so that the insignia can be chipped as well
Which gives this - also mottled the tail
Then the attack of the toothbrush - dissolves / knocks off the salt and chips paint
Finally a coat of Klear over the top ready for the decals tomorrow
Peter
Today's work on the Wurger - first the decals and stencils, nothing major.
Then the dreaded prop spiral and the landing gear. This is always 'interesting' to get aligned on eduard 190's, just takes some care
Then matt coat, and start the post shading - took photo's outside as it makes it easier to see in daylight
Nearly done now - should finish next weekend.
Peter
Simplicity in itself - wonderful build and finish Peter
