Silverstone 2 Posted July 16, 2012 Share Posted July 16, 2012 Here is the start of an exciting project for me. I really enjoy making Tamiya aircraft, everything goes together without any problems. A real treat after the 32nd scale Revell/Monogram AH-64 Apache! the fit is like a glove, I also like the use of self tapping screws to secure pieces. Cockpit assembley: Should have taken more photos of the interior before it was closed up:-( Few other sub asssemblies on the go: Link to comment Share on other sites More sharing options...
Silverstone 2 Posted July 17, 2012 Author Share Posted July 17, 2012 Exhaust nozzles, the biggest fault with this kit, when it comes to seem lines. How to defeat the internal join which is has always been obvious:-( Think this has done the trick to 90% And sanding away those ejector pin marks on the intake ducts: Link to comment Share on other sites More sharing options...
phildagreek Posted July 17, 2012 Share Posted July 17, 2012 Looks good so far, I know this is a beast of a kit, is it totally oob? Link to comment Share on other sites More sharing options...
Frank Fontaine Posted July 17, 2012 Share Posted July 17, 2012 the detail in the cockpit is astonishing! Good luck, I'm sure you'll do it justice! Link to comment Share on other sites More sharing options...
jacksdad Posted July 19, 2012 Share Posted July 19, 2012 Looks good so far. I have a second one in production and there are two areas you need to watch. The front section to main fuselage join and wings to fuselage require patience to get them right. In my second one I attached the wings to the top fuselage piece first, which allowed a bit more wiggle to reduce the possibility of a bad fit. Can't wait to see how you get one. Steve Link to comment Share on other sites More sharing options...
Alan P Posted July 19, 2012 Share Posted July 19, 2012 Very nice work so far, looks like an imposing kit. Al Link to comment Share on other sites More sharing options...
Daywalker Posted July 20, 2012 Share Posted July 20, 2012 Off to a great start! I have this kit in the queue, and will be watching your progress here. Link to comment Share on other sites More sharing options...
Modelarczyk Posted July 20, 2012 Share Posted July 20, 2012 Great start. Looking good. Hope to see more soon. Link to comment Share on other sites More sharing options...
Silverstone 2 Posted July 24, 2012 Author Share Posted July 24, 2012 Body halves are together along with the intake ducts inside. Shame really because all the hard work to see the almost seemless ducts, have been mostly hidden Wings and body went together very easily with extra help from the self tappers: Vallejo Putty does wondes for gap filling! Made what historically would have been a large job....very small 2 x 600 Gallon drop tanks were rescribed to bring back the detail on the join: Canopy glue (PVA) is absolutely brilliant for large clear parts, one of the best finds: Undercarriage, Radar & HUD with green edged glass: The radom will be extendable as well as closed. I've used a small amount of PVA in the clip so that when it's shut it remains snugg without drooping! More updates to come. Link to comment Share on other sites More sharing options...
Silverstone 2 Posted July 24, 2012 Author Share Posted July 24, 2012 Soon to be attaching the nose section......See what the fit is like? Not as bad on the bottom surface as i've seen. Used CA glue to really strengthen the join & leave no gaps. Only other in the process was some slight offset lateral alignment: So some fine sanding required: Engine nozzles, first Alclad 2 Jet Exhaust: Too Dark! My own mix: Next another mix for the bi-metalic finish: more to come in the next few days. Link to comment Share on other sites More sharing options...
colin ritchie Posted July 25, 2012 Share Posted July 25, 2012 Like Jacksdad, I've built 2 of these beasts , and a C for good measure, but this is one of the nicest builds I've seen , superb attention to detai, A clean and precise- build excellent work Link to comment Share on other sites More sharing options...
Silverstone 2 Posted July 31, 2012 Author Share Posted July 31, 2012 Looks like those filled ejector pin marks have too much sink in them. Another go with the filler looks required, too obvious still :shithappens: Link to comment Share on other sites More sharing options...
Silverstone 2 Posted July 31, 2012 Author Share Posted July 31, 2012 Quite alot of spraying was done yesterday. first the Alclad 2 primer (GLOSS BLACK 305). This was then masked for the US Dark grey and then reverse masked for my own Alclad 2 verious layers to create the desired Engine panel effects. Photos to follow... Link to comment Share on other sites More sharing options...
Silverstone 2 Posted July 31, 2012 Author Share Posted July 31, 2012 Spraying complete on both underside and topside + Weapons on: Lantern pods, still needs it's lense.... The F-15E is finished in satin but will another gloss coat before decals. Radar on too: Avionics bay: Link to comment Share on other sites More sharing options...
Silverstone 2 Posted July 31, 2012 Author Share Posted July 31, 2012 Alclad 2, 3layers with post shading. The underside loks even better, never mixed alclads before but it's worked well and the post shading with "Jet Exhaust" has worked very well Link to comment Share on other sites More sharing options...
Silverstone 2 Posted July 31, 2012 Author Share Posted July 31, 2012 Still working on those ejector pin marks, which will be flush before the end! the Ejector seat: The Crew Ladder: The Canopy sections, I used Displex to polish out the seem line after using Micromesh. And now the gloss coat in preperation for the decals: Decals are now on but i've run out of light for a good photo, Weathering then...Matt coat next! Link to comment Share on other sites More sharing options...
Silverstone 2 Posted July 31, 2012 Author Share Posted July 31, 2012 Best shots i could make in this light: Tamiya Decals were quite difficult to use, very fragile to say the least, but after almost a full day of decal aplication the results are worth it! Still a lot more work to do however, more shots of the underside and the finshed article hopefully very soon This is a hard model to work on due to the assembly order. I normally like to put the landing gear on last but this was never going to be the case due to the nose leg. I have to say though it's very sturdy indead with no weekness when standing on the U/C. Goes together very well and is very impressive & Heavey! Link to comment Share on other sites More sharing options...
Silverstone 2 Posted August 3, 2012 Author Share Posted August 3, 2012 Will be back to work on this tomorrow All the lenses for the nav lights still to do + the Lantern lense. After i'm working on a commision build of the 1/72 Airfix Stirling, the build will be posted on here too. Completed F-15E will be up for sale on the SELL forum as i've not got the space to keep it The fun for me is all in the making, maybe one day I'll have room? Link to comment Share on other sites More sharing options...
theclay Posted August 3, 2012 Share Posted August 3, 2012 looking excellent mate Link to comment Share on other sites More sharing options...
Alan P Posted August 3, 2012 Share Posted August 3, 2012 Excellent, clean work all round :-) Can't believe how quickly you work as well! Fully sympathise with the space problem, I love 1/32, but where to keep them all? Al Link to comment Share on other sites More sharing options...
Silverstone 2 Posted August 5, 2012 Author Share Posted August 5, 2012 Almost Finished! Just Nav & Position lights to go......... Vulcan 20mm cannon: Retractable Airbrake: Radar with Avionics bay with retractable nose and access panel: The underside: 3 X LGBs Link to comment Share on other sites More sharing options...
Silverstone 2 Posted August 5, 2012 Author Share Posted August 5, 2012 Sorry for the out of focus shots of the 20mm: Link to comment Share on other sites More sharing options...
PsyQuad Posted August 23, 2012 Share Posted August 23, 2012 Awesome work man Link to comment Share on other sites More sharing options...
Riggers Posted August 23, 2012 Share Posted August 23, 2012 Bluddy stonking Sir! Awesome job............ Link to comment Share on other sites More sharing options...
