AnonymousDFB1 Posted September 3, 2012 Share Posted September 3, 2012 Nice work Dave Link to comment Share on other sites More sharing options...
DaveJL Posted September 5, 2012 Author Share Posted September 5, 2012 Thanks Mish. I'm just about to start the painting but have a question... What colour are the wheel bays and the airbrake well? Hasegawa call out for medium sea grey (same colour they call out for the undersides of the whole jet) while the out rigger wheel bays and all the landing gear are white. Is this correct? Dave Link to comment Share on other sites More sharing options...
SaintsPhil Posted September 5, 2012 Share Posted September 5, 2012 I'm here Dave! U/C bays are white with lots of dirt! The Airbrake bay is I think the same colour as the undersides, at least it is for the MSG jets, I have to admit I'm not 100% sure for the DSG/DCG jets, I think the airfix 1/72 kit instructions say white... I'll double check when I get home Link to comment Share on other sites More sharing options...
DaveJL Posted September 5, 2012 Author Share Posted September 5, 2012 I'm here Dave! U/C bays are white with lots of dirt! The Airbrake bay is I think the same colour as the undersides, at least it is for the MSG jets, I have to admit I'm not 100% sure for the DSG/DCG jets, I think the airfix 1/72 kit instructions say white... I'll double check when I get home Great, thanks Phil. I'll spray the lot grey and see what's what. When the gear goes in, not much of the fuselage bays can be seen anyway. The white landing gear legs cover them up, and they are definitely white! Dave Link to comment Share on other sites More sharing options...
SaintsPhil Posted September 5, 2012 Share Posted September 5, 2012 Sorry I think you miss understood the undercarridge bays are white, it's only the airbrake bay that I'm not sure about. You're right though, unless you open the nose gear bay, you can't see much as the kit is! Outriggers are the only obvious bits. If you haven't done so I would suggest fitting the outrigger doors before you paint, as the demarkation between white and underside colour isnt that obvious off the kit! Phil Link to comment Share on other sites More sharing options...
DaveJL Posted September 5, 2012 Author Share Posted September 5, 2012 More to show today. The jet itself is off for priming so here she is before that stage: Moved on and painted most of the sub assemblies. Weapons first: Just need to add decals to the BL755's and AIM-9's and give the TIALD pod a panel line wash. The Aires resin exhausts were next (lovely addition these- highly recommended!): Followed by the FOD guards: And finally the resin ejection seat: That's it for the moment.. Will hopefully have the majority of painting done by the weekend. More to come. Dave 1 Link to comment Share on other sites More sharing options...
DaveJL Posted September 5, 2012 Author Share Posted September 5, 2012 Sorry I think you miss understood the undercarridge bays are white, it's only the airbrake bay that I'm not sure about. You're right though, unless you open the nose gear bay, you can't see much as the kit is! Outriggers are the only obvious bits. If you haven't done so I would suggest fitting the outrigger doors before you paint, as the demarkation between white and underside colour isnt that obvious off the kit! Phil No no i understood Phil! I'm just leaving the 2 small locating points for the main landing gear grey, but the outriggers and bay aft of the front wheel will be white! I've her primed up so i'll just leave the outriggers off until final assembly. Dave Link to comment Share on other sites More sharing options...
Jim Starling Posted September 5, 2012 Share Posted September 5, 2012 Good job all 'round! Link to comment Share on other sites More sharing options...
DaveJL Posted September 5, 2012 Author Share Posted September 5, 2012 Good job all 'round! Thanks Jim Link to comment Share on other sites More sharing options...
SaintsPhil Posted September 6, 2012 Share Posted September 6, 2012 Ah ok fair enough Dave! Those resin exhausts are nice aren't they, might get some for my AV8B if I don't get on with seans on kit ones Link to comment Share on other sites More sharing options...
DaveJL Posted September 6, 2012 Author Share Posted September 6, 2012 Those resin exhausts are nice aren't they, might get some for my AV8B if I don't get on with seans on kit ones £6.50 well spent! Much better than the kit ones Dave Link to comment Share on other sites More sharing options...
DaveJL Posted September 9, 2012 Author Share Posted September 9, 2012 (edited) Not much of an update today but the paint is on: Quite hard to make out the de-marcation lines. I used Tamiya AS-10 Ocean grey for the undersides, front fuselage and tail then used Model Master Gunship grey for the upper surfaces. Think it's quite a good match to my reference pictures. Next up is to paint the wheel bays and add some details before glossing and getting a panel line wash on. More to come. Dave Edited September 9, 2012 by DaveJL 1 Link to comment Share on other sites More sharing options...
DaveJL Posted September 19, 2012 Author Share Posted September 19, 2012 After a brief delay, i've some more progress to show. Kit was glossed in preparation for decals, and without further ado: Weapons also decaled and fuel tanks glossed: After sealing the decals in and letting them dry for a few hours, i applied a coat of Flory models wash to highlight the panel lines. On: And off again after 30 minutes: Will hopefully get a flat coat on this evening then the next stage is to start adding the detail parts. More to come. Dave 1 Link to comment Share on other sites More sharing options...
SaintsPhil Posted September 19, 2012 Share Posted September 19, 2012 Great work Dave! Hate to say it though but I'm pretty sure the LID dam bay should be same colour as the underside, not white (that's the bay just in front of gun pod). If you don't want to repaint just filthy it up a lot, they get really messy anyway! Link to comment Share on other sites More sharing options...
DaveJL Posted September 19, 2012 Author Share Posted September 19, 2012 Great work Dave! Hate to say it though but I'm pretty sure the LID dam bay should be same colour as the underside, not white (that's the bay just in front of gun pod). If you don't want to repaint just filthy it up a lot, they get really messy anyway! Ah bugger, I thought it was white! A quick spray will sort it out. Dave Link to comment Share on other sites More sharing options...
wellzy Posted September 22, 2012 Share Posted September 22, 2012 It happens to us all Dave ,but good build mate Les Link to comment Share on other sites More sharing options...
DaveJL Posted September 22, 2012 Author Share Posted September 22, 2012 It happens to us all Dave ,but good build mate Les Thanks Les. It's come together nicely after my early calamities! Dave Link to comment Share on other sites More sharing options...
DaveJL Posted September 23, 2012 Author Share Posted September 23, 2012 (edited) A bit more to show today. Matt coat went was applied on Thursday so today i was able to start adding all the little bits, starting with the landing gear and doors, along with the exhausts and TIALD pod: You can probably see some of the heavy(ish) weathering I have applied to the undersides, with more to be done. Once all that was dry, I added the FOD covers (to which i added thin strips of masking tape to replicate the black 'pulls' on the real thing), the various antennae and the extended refuelling probe: Ejection seat also went in. Finally for today, i sanded away the mould seam on the canopy with micromesh, starting with the 3200 grit working all the way up to 12000. After the canopy was polished, I added the Flying Leathernecks det cord. Despite mine being slightly lopsided, this is a great addition to any Harrier kit, and so easy to apply. You firstly remove the excess vinyl around the det cord, then place the clear applicator tape on it to remove it from the backing, place it onto the canopy, press down and remove the tape. Job done! Next up is to add all the ordnance, canopy and give it a final tidy up. More to come. Dave Edited September 23, 2012 by DaveJL 1 Link to comment Share on other sites More sharing options...
noeyedears Posted September 23, 2012 Share Posted September 23, 2012 damn that looks nice Link to comment Share on other sites More sharing options...
DaveJL Posted September 23, 2012 Author Share Posted September 23, 2012 damn that looks nice Thanks mate, glad you like it. I'm tempted to get another one Dave Link to comment Share on other sites More sharing options...
DaveJL Posted September 26, 2012 Author Share Posted September 26, 2012 Managed to get this finished off earlier today. The finished build is in the gallery and RFI here Have to say, despite my early calamities with things cracking and not fitting, I enjoyed building this Iconic jet, so much so that I might be tempted to get another one and an AV-8B! Thanks to all who followed and commented. I hope I've done this great jet the justice it deserves, and, as the title of the GB says, it is dedictated to all those who flew it and those whom it helped on the ground. Help our Heroes. Onward to Build 2... Dave 1 Link to comment Share on other sites More sharing options...
AnonymousDFB1 Posted September 27, 2012 Share Posted September 27, 2012 Nicely done Dave Link to comment Share on other sites More sharing options...
Neal Posted September 27, 2012 Share Posted September 27, 2012 Another GB belter Link to comment Share on other sites More sharing options...
DaveJL Posted September 27, 2012 Author Share Posted September 27, 2012 Thanks guys! Link to comment Share on other sites More sharing options...
wellzy Posted October 26, 2012 Share Posted October 26, 2012 nice one Dave she looks great Les Link to comment Share on other sites More sharing options...
