  • 3 weeks later...
Looks like it will be a good build, Tamiya always builds great kits form my experience with them, also love how their instructions include a lot of extra info. Will be watching this build! :popcorn:
well made a start :)
Main color of cockpit is RLM-Grey.
The masking sticker is not pree-cut and is difficult to use :( (windows behing pilot)
I didnt use the seat belt decals because i am going to use the pilot and gunner figur.
and.... :bangin: one upside-down error
Sprayed the interior with "black thinner". The cockpit / fuel tank/ gunner was pushed up after joining fuselages.
Used a little Tipp-ex to fill joints but not much was needed, everything fits "almost perfectly", you can even hear "snap" sometime when it falls together.
Edited by pabbi
Looks great. What's upside down though?
thanks Don,
upside down - the decals with 6 instruments :banghead: didnt see it until I looked at the photo
Pabbi
what brand of paint are you using? The interior colour is A-14 'Steel grey' I presume Tamiya have specified a 'near match' from their paint range?
If you check Robert's build there are links about colours, also he asked about AKAN paint [Russian paint company, thought to be the best VSS paint matches]
http://www.britmodeller.com/forums/index.p...topic=234922340
which has links to Humbrol matches of VVS colours.
The paints specified by Tamiya have breifly been discussed, in this thread
http://sovietwarplanes.com/board/index.php?topic=1330.0
I don't have all the Tamiya paints specified so I can't help. [i bought some AKAN a while back]
also some discussion and pictures of the rear gun fitted here
http://sovietwarplanes.com/board/index.php?topic=1383.0
There's a lot more info on the Il-2 and other VVS types on the site.
I hope this is of some help.
cheers
T
Pabbi
Thanks T, I am using Tamiya paint, the interior color I use is Tamiya XF-22 RLM-Grey, following the Tamiya instruction.
Great start, I'll be watching this. Don't fret over the upside down decal, seriously who would notice (if you hadn't mentioned it!)?
ready for some paint :)
no problems to report
the main landing gear has a great fit, not possible to do them not level, I was going to add them after painting but they need to be on before the "landing gear front cover".
the instuction for camouflage paints are
xf-23 light blue
XF-24 dark green, XF-25 olive green, XF-52 earth with a little XF-59 desert yellow
Looking good, you should finish before I have my paint on order
Before anybody comments, XF-24 is dark grey ;) grey / green / earth sounds reasonable for an arrow
Edited by Robert Stuart
Looking good, pabbi! Remember that the "earth" colour is actually a tan colour, not a brown colour, as it appears on the Tamiya box. One thing also; although it may be too late to rectify this, the lever on the round object on the starboard side of the pilot's seat should be resting on the aft spar, next to where the seat is attached. On this kit (and seemingly every other kit) it is too far forward. Another point - the square ejection opening on the underside of the wings underneath the cannon should both be pointing towards the port wingtip (AM got this right so if you have the AM kit, look at how they did it - or take a look at Dr.Jellyfingers' build, which uses the AM kit). The opening on the port wing is on the wrong side of the long rectangular opening, which is for the shell casing ejector chute. I hope this makes sense. I really need to do a thread discussing the pros and cons of this kit (definitely mostly pros - this is the best kit of the Shturmovik that anyone has produced so far).
Regards,
Jason
Edited by Learstang
thanks Jason, yes the earth color looks diffrent then on he Tamiya box.
camouflage paint is on, tried to paintchip with salt on the walking path, maby it is too much chiping ?
I pre shaded with nato-black.
Edited by pabbi
That looks very good, pabbi! It's hard to overdo the paint chipping on the port wingroot; they were often very worn down. What you've done looks realistic.
Regards,
Jason
ready for klear and decals :)
I will do the antenna last....
Edited by pabbi
Very nice, pabbi! I can't wait to see your Ilyusha with the decals on. It will be great to see one of these Tamiya Il-2's finished.
Regards,
Jason
