DaveJL Posted August 2, 2012 Author Posted August 2, 2012 Close enough for the underneath! I was thinking the same Don Dave
DaveJL Posted August 2, 2012 Author Posted August 2, 2012 Quick question...as i've never used Scale Aircraft Conversions metal landing gear before, do the parts need a wash before priming or are they ok to paint without primer? Thanks Dave
Dads203 Posted August 2, 2012 Posted August 2, 2012 Quick question...as i've never used Scale Aircraft Conversions metal landing gear before, do the parts need a wash before priming or are they ok to paint without primer?Thanks Dave Personally i'd wash them, treat them the same as any other moulding Dave, they will have some form of A release agent on them that needs removing. Regards Dan
DaveJL Posted August 2, 2012 Author Posted August 2, 2012 Personally i'd wash them, treat them the same as any other moulding Dave, they will have some form of A release agent on them that needs removing. Regards Dan Thanks Dan. I'll send them off for a rinse! Dave
Bertie McBoatface Posted August 2, 2012 Posted August 2, 2012 Personally I'd give them a scrub with airbrush cleaner and a toothbrush. Outside!
DaveJL Posted August 2, 2012 Author Posted August 2, 2012 Personally I'd give them a scrub with airbrush cleaner and a toothbrush. Outside! Hmm, i was going to bath them in warm detergent with the resin burner cans. I'll try that first Dave
DaveJL Posted August 5, 2012 Author Posted August 5, 2012 Another good session today. I sprayed the scratch-built CWM yesterday: The GBU-38's painted, weathered and ready to go: Installed: CWM inside Bomb-bay number 3: All 3 bomb-bays attached to the lower fuselage: Size comparison: While that was drying, I returned to the cockpit section. Firstly, I masked off all the windows. Next, added the Structural Mode Control System (SMCS) vanes. These are designed to smooth the ride of the B-1 at low level. Next, i used some scrap etch to make the vent as seen on the cabin roof. I also added a lump of putty, flattened and rounded with a finger, to create the GPS receiver. The latter just needs a bit of a sand to smooth it off: Added the 3 Eduard vents on the underside: Then I moved on and attached the 6 Pitot tubes either side of the nose: Once this was done, I returned to the main fuselage and attached the upper and lower sections together (I'm leaving the wings off until the end, despite the instructions calling out that they be installed before closing the fuselage) The fit is not great and some serious sanding will be needed: That's all for today. It's starting to come together! Next up is to clean up the fuselage and finish work on the tail section. More to come. Dave
Chris W. Balmer Posted August 5, 2012 Posted August 5, 2012 Its looking really good mate... and getting BIGGER!
DaveJL Posted August 5, 2012 Author Posted August 5, 2012 Its looking really good mate... and getting BIGGER! Thanks mate. And yes, it is getting bigger! Starting to scare me sightly Dave
DaveJL Posted August 6, 2012 Author Posted August 6, 2012 Had a look today at the glued together fuselage....oh dear I said to myself. There's a massive step on either side of the forward section that joins to the cockpit. Going to be a lot of fun to sort that out. Anyone got any good tips for removing big 'steps'? Cheers Dave
IXGR1 Posted August 7, 2012 Posted August 7, 2012 Dave, Just found this thread. OMG ! you are creating a monster - magnificent work !! Esp - on the CWM bombay - I will be copying/following this for sure..........
DaveJL Posted August 7, 2012 Author Posted August 7, 2012 Dave, Just found this thread. OMG ! you are creating a monster - magnificent work !! Esp - on the CWM bombay - I will be copying/following this for sure.......... Thanks mate. It certainly is a bit of a monster, but enjoyable none the less! Dave
DaveJL Posted August 7, 2012 Author Posted August 7, 2012 Found a good video this evening, have a look!
DaveJL Posted August 8, 2012 Author Posted August 8, 2012 BIG update today (literally...read on!!) First thing I did today was add the Shull24 SNIPER pod pylon to the forward fuselage: Next, i sanded off the filler that was needed on the join lines between the two fuselage halves. Two applications were needed and there was a lot of work needed to smooth the areas off. I'm relatively happy with the outcome. I also started to tidy up the engine nacelles in preparation for the addition of the CE nozzles. Again, a s*** load of filler and sanding was needed. Smooth side: Not so smooth side: And that's just one! Also tidied up most of the tail section, but the DAS blister still looks like a dogs dinner. (Any tips on how to get this looking right would be most welcome!) Finally, the BIG update today....the main fuselage was attached to the cockpit section. To give an idea of size.... Yep, that's two 1/48 F-14's!!! The join of the two sections is awful in truth so my next job is to clean that up and hopefully sort out the mess I've made of the DAS blister and get the tail section attached. More to follow. Dave
DaveJL Posted August 9, 2012 Author Posted August 9, 2012 Another bit of progress to report. Firstly, I added the 22 vortex generators on the tail: 18 of these came from the Eduard set. The rest were made from bits of card. Made a slightly better attempt at the DAS blister. Still not 100% accurate, but it's the best I can do! Filled the considerable gaps in the forward/main fuselage join. I can already tell that this is going to be a bugger!! Also added some of the Eduard antennae to the top fuselage. Slightly regret this now as I know it will break off at least once Another big milestone was also reached....the tail section was attached to the fuselage. So I now have a full length Bone! Was so big, i had to leave my workbench/utility room and use the dining table! Will let it all dry until the weekend. My next task is to tidy up the join sections and begin work on the engine nacelles. More to come. Dave
Greased Lightning Posted August 9, 2012 Posted August 9, 2012 Fair play to you tackling this monster Dave, any idea where you'll put it once built???
DaveJL Posted August 9, 2012 Author Posted August 9, 2012 Fair play to you tackling this monster Dave, any idea where you'll put it once built??? Thanks mate....and not a clue where I will display it. Was sort of a 'have a go and hope some space appears' kind of build Dave
DaveJL Posted August 9, 2012 Author Posted August 9, 2012 Found another few cracking videos, giving me more inspiration to push on and finish it! (good bit near the end!) Some machine! Dave
smuts Posted August 11, 2012 Posted August 11, 2012 Hi Dave, that's great work mate, & I think you're doin a grand job ......dose the boss know how big this is Andy
Chris Jephcott Posted August 11, 2012 Posted August 11, 2012 That is very very impressive. Excellent work!
DaveJL Posted August 11, 2012 Author Posted August 11, 2012 That is very very impressive. Excellent work! Thank you, appreciate the kind words. Dave
