Brandy Posted May 1, 2012 Share Posted May 1, 2012 (edited) Hi all, For those who don't follow the Great War in the Air forum, I thought I'd post my recently completed Blériot XI scratchbuild. It's my first scratchbuild, but was surprisingly straightforward, the only problems being working out a logical order for the construction. The engine and prop are Aeroclub, seatbelts and wheels are PE (the wheels came from a Meikraft Albatros which won't be needing them) and the decals are homemade (my first attempt!). Other than that it's all plastic stock, brass rod and beer can (all the body panels). I hope you like her! Ian Edit Sept 2018: Since the GWIA forum is now long defunct, here's a link to the build on WWIAircraftmodels. https://forum.ww1aircraftmodels.com/index.php?topic=2013.msg32690#msg32690 Edited September 7, 2018 by limeypilot 9 2 Link to comment Share on other sites More sharing options...
CarLos Posted May 1, 2012 Share Posted May 1, 2012 Great work! Can you elaborate some more on how you did the wings? Link to comment Share on other sites More sharing options...
Ray S Posted May 1, 2012 Share Posted May 1, 2012 Great work! Can you elaborate some more on how you did the wings? Yes please tell us! It is a great finish to the Bleriot, nice work. Kind regards, Ray Link to comment Share on other sites More sharing options...
grahamwalker Posted May 1, 2012 Share Posted May 1, 2012 Yes please tell us! It is a great finish to the Bleriot, nice work.Kind regards, Ray Fantasic work love the wheels they are a model by them selves Link to comment Share on other sites More sharing options...
Brandy Posted May 1, 2012 Author Share Posted May 1, 2012 Thanks for the comments! The wings were actually pretty simple. I used .030" plastic card and added the camber at the leading edge using a PE bending tool, starting behind the leading edge and working forward just gradually adding more curve until I had it as I wanted. The ribs/batons were very much trial and error. The ribs at the leading edge were added with plastic rod, sanded and smoothed in at the edges with Mr Surfacer. For the batons, I started by attaching strips of fishing line (the same as I use for rigging) and painting over it. It didn't look right though, too over-scale, so I pulled the rigging line off. Then I had the "Eureka" moment! Because I'd given it a few coats of paint there was a small lip either side of where the fishing line had been. A little filling in was required in places but not much. I smoothed it off with a little gentle sanding, and voila! The end result is one I'm very pleased with, and, as mentioned, is merely paint and a little liquid filler! The light sanding also darkened the paint a little so I didn't even add any highlighting, pre- or post-shading - just the base paint colour! The wheels were indeed a model on their own. As they came from Meikraft, each wheel was in 4 parts: 2 pieces of PE for spokes, and 2 tyre halves. The latter were a little thick so I sanded them down a bit. I shaped the spokes by just resting the PE on the tyre half and very gently pressing it down around the edge, slowly working around the outside until they had a slight dish to them. It's not much, but with the 2 pieces together the gap between them shows up much better. There's a small piece of plastic rod added for the hub which was then drilled to take the brass rod axle and give it a bit of strength. Ian Link to comment Share on other sites More sharing options...
Ray S Posted May 1, 2012 Share Posted May 1, 2012 Hello Ian, thanks for letting us know your technique on the wings, I will try that sometime soon I hope (I did a WW1 biplane scratchbuild but the wings were not quite right - the camber was not pronounced enough). I have plan... Regards, Ray Link to comment Share on other sites More sharing options...
Quentin Posted May 1, 2012 Share Posted May 1, 2012 That looks superb. There can never be enough scratchbuilt 1/72nd scale WWI aircraft in my opinion. Like the undercarriage! They certainly made them complicated on those early machines. Link to comment Share on other sites More sharing options...
stevehed Posted May 1, 2012 Share Posted May 1, 2012 Very impressive. Particularly like the engine panels. I was wondering how many cans had to be drunk in order to acquire the right amount of metal? Cheers, Steve Link to comment Share on other sites More sharing options...
Brandy Posted May 1, 2012 Author Share Posted May 1, 2012 Very impressive. Particularly like the engine panels. I was wondering how many cans had to be drunk in order to acquire the right amount of metal?Cheers, Steve Actually it hardly made a dent in the can (pun intended!) even after scrapping some! I "stole" the can from my local bar - I only drink draught! Ian Link to comment Share on other sites More sharing options...
CarLos Posted May 2, 2012 Share Posted May 2, 2012 Ian, many thanks for the explanation. Cheers Carlos Link to comment Share on other sites More sharing options...
Yankymodeler Posted May 2, 2012 Share Posted May 2, 2012 Now that is really nice! Well done, you've captured the 'built by hand' look perfectly. Just the right amount of scuffing and used look too! Eric aka The Yankymodeler Link to comment Share on other sites More sharing options...
Epeeman Posted May 2, 2012 Share Posted May 2, 2012 Great one! I admire you for this - I would not not where to begin! Dave Link to comment Share on other sites More sharing options...
merlin3945 Posted May 4, 2012 Share Posted May 4, 2012 Really like models of older pioneer aircraft. Superb work. Link to comment Share on other sites More sharing options...
merlin3945 Posted May 4, 2012 Share Posted May 4, 2012 (edited) Duplicate post. Edited May 4, 2012 by merlin3945 Link to comment Share on other sites More sharing options...
Martian Posted May 4, 2012 Share Posted May 4, 2012 Like it? Its a little gem! Martin Link to comment Share on other sites More sharing options...
Brandy Posted May 4, 2012 Author Share Posted May 4, 2012 Thanks for all the kind words! Here's a link to the build log for anyone who wants to see the entire process... http://www.greatwaraviation.com/forum/inde...pic,2145.0.html Ian 1 Link to comment Share on other sites More sharing options...
Viking Posted May 6, 2012 Share Posted May 6, 2012 Wow, that is lovely. You must have good eyesight to do that in 1/72! Cheers John Link to comment Share on other sites More sharing options...
Brandy Posted September 7, 2018 Author Share Posted September 7, 2018 Note to admin - Please move this to the RFI section, where it should be! Many thanks! Ian Link to comment Share on other sites More sharing options...
cngaero Posted September 8, 2018 Share Posted September 8, 2018 That's a beautiful Bleriot. 1 Link to comment Share on other sites More sharing options...
fjaweijfopi4j48 Posted September 8, 2018 Share Posted September 8, 2018 On 4/30/2012 at 7:20 PM, limeypilot said: Other than that it's all plastic stock, brass rod and beer can (all the body panels). Ian, that's the most elaborate (and laborious!) excuse to drink beer that I ever heard. Well done, sir, beautiful model! Link to comment Share on other sites More sharing options...
pheonix Posted September 8, 2018 Share Posted September 8, 2018 I have seen this already on other sites but I still think that this is a superb piece of scratch building and that you ought to do some more. I am sure that you could make some excellent WW1 or even pre-war subjects. P Link to comment Share on other sites More sharing options...
