cuprar Posted May 1, 2012 Share Posted May 1, 2012 I'm loving this build, keep up the good work Link to comment Share on other sites More sharing options...
Enzo the Magnificent Posted May 2, 2012 Author Share Posted May 2, 2012 the step might have something to do with original molding flaws.... So... not my bodgehandedness then? Link to comment Share on other sites More sharing options...
Kev1n Posted May 2, 2012 Share Posted May 2, 2012 well....... Link to comment Share on other sites More sharing options...
Enzo the Magnificent Posted May 12, 2012 Author Share Posted May 12, 2012 Time to work on the wing fences. Firstly I cut a groove in the top surface of the wing. Then I slid a piece of 15 thou plastic card into the groove. I cut the plastic card to shape. And here are the results for both wings. The model dry fitted together with the aid of blutak. I still need to work on the wings before final assembly. Most notably, I have to decide what I'm going to do with the wingtips. Link to comment Share on other sites More sharing options...
Martian Posted May 13, 2012 Share Posted May 13, 2012 Nice progress there! Martin Link to comment Share on other sites More sharing options...
Jabba Posted May 13, 2012 Share Posted May 13, 2012 Very nice work indeed. Did you know the dimensions of the wing fence or was it done on the back of a fag packet. Link to comment Share on other sites More sharing options...
Enzo the Magnificent Posted May 13, 2012 Author Share Posted May 13, 2012 Very nice work indeed. Did you know the dimensions of the wing fence or was it done on the back of a fag packet. It's an approximation, taken from photographs and memories of staring at them for hours on end. Link to comment Share on other sites More sharing options...
Kev1n Posted May 14, 2012 Share Posted May 14, 2012 probably the best way ^ (works for me so what can I say...?) the wing tips - dont forget the wings have that leading edge extension as well as the tips needing some work Link to comment Share on other sites More sharing options...
Enzo the Magnificent Posted May 14, 2012 Author Share Posted May 14, 2012 (edited) the wing tips - dont forget the wings have that leading edge extension as well as the tips needing some work Haven't forgotten. It looks to me as though the tips have a sort of cylindrical "pod" which hangs below the tips and extends slightly forwards. Comments? Edit: I've also noticed that the outer wing fence does not cover the full chord of the wing, as shown in the kit. So there's another modification which is required. Edit Edit: Would I be correct in saying that the Super VC10 wing had a 4% extension to the chord from the root to the outer wng fence, giving it a leading edge kink about three quarters of the way along? Edited May 14, 2012 by Enzo Matrix Link to comment Share on other sites More sharing options...
canberraman Posted May 14, 2012 Share Posted May 14, 2012 Enzo You would indeed be correct in that assertion. All the Supers and the RAF C.1s had the extended leading edge. Braz do these as a conversion. Good luck with your build Mark Haven't forgotten. It looks to me as though the tips have a sort of cylindrical "pod" which hangs below the tips and extends slightly forwards. Comments?Edit: I've also noticed that the outer wing fence does not cover the full chord of the wing, as shown in the kit. So there's another modification which is required. Edit Edit: Would I be correct in saying that the Super VC10 wing had a 4% extension to the chord from the root to the outer wng fence, giving it a leading edge kink about three quarters of the way along? Link to comment Share on other sites More sharing options...
Enzo the Magnificent Posted May 20, 2012 Author Share Posted May 20, 2012 Moving forward slowly. I cut down the outer wing fence so it is no longer full chord. I have split the wingtip and inserted a piece of 15 thou plastic card cut crudely to shape. The leading edge is a strip Microstrip. The leading edge and wingtip will be faired in with Milliput. I'm prepared for a lot of sanding to get the wingtip to a decently thin profile. Link to comment Share on other sites More sharing options...
Martian Posted May 20, 2012 Share Posted May 20, 2012 Nice work! Its quite confusing sorting out the various wing arrangements isn't it? Martin Link to comment Share on other sites More sharing options...
Enzo the Magnificent Posted May 20, 2012 Author Share Posted May 20, 2012 Nice work! Its quite confusing sorting out the various wing arrangements isn't it? You're telling me!!! I originally intended this to be a quick and simple build straight from the box. But I'm OCD enough to be unable to ignore things when I find out about them. I'm not complaining about the extra work though. It's fun. Link to comment Share on other sites More sharing options...
Kev1n Posted May 21, 2012 Share Posted May 21, 2012 Nice work! Its quite confusing sorting out the various wing arrangements isn't it?Martin Try sorting out the differences between Boeing 707 types and sub-types.............................. Fun is what it's all about - you can build the airfix kit oob, stick any markings on and it will still look like a VC10. That said, it is interesting to do the mods, and lets face it, the satisfaction from doing them is amazing. Airfix have given us a good blank canvas to work on, which does help Link to comment Share on other sites More sharing options...
Enzo the Magnificent Posted July 5, 2012 Author Share Posted July 5, 2012 Just a quick note to say that I haven't forgotten this build. I will have some pics at the weekend. Hopefully over the weekend, I should have it ready for the stickers. Link to comment Share on other sites More sharing options...
Kev1n Posted July 6, 2012 Share Posted July 6, 2012 Link to comment Share on other sites More sharing options...
Enzo the Magnificent Posted July 6, 2012 Author Share Posted July 6, 2012 I admit that it doesn't look very preposessing... but it's now all in one piece and for me it is coming alive. The white is Alclad2 white primer, which is superb as a top coat. Thanks for that recommendation, Mike! Of course, you can't see the white in this shot as it is all masked off! The grey is Lifecolor UA113 Grigio Azzurro Chiaro 1. Comments on the grey readily accepted. It needs a couple more squirts of grey with some minor touchups on the white and it will be ready for the Klear treatment. Hopefully I'll get the greeblies sorted over this weekend and then it will be ready for decals next weekend. Can't wait! Link to comment Share on other sites More sharing options...
Enzo the Magnificent Posted July 8, 2012 Author Share Posted July 8, 2012 Some minor touchups needed. A bit of detail painting and a quick squirt of Klear and it will be ready for the decals next weekend. Link to comment Share on other sites More sharing options...
Kev1n Posted July 9, 2012 Share Posted July 9, 2012 oooOO....it is coming alive!!....looks very neat and very nice Enzo. Link to comment Share on other sites More sharing options...
Jabba Posted July 9, 2012 Share Posted July 9, 2012 That is looking really good. Link to comment Share on other sites More sharing options...
Enzo the Magnificent Posted July 14, 2012 Author Share Posted July 14, 2012 Today's the day for the decals, when the model really comes alive. So here goes... Smoke me a kipper, I'll be back for breakfast Link to comment Share on other sites More sharing options...
Kev1n Posted July 14, 2012 Share Posted July 14, 2012 kipper lit....and it's after breakfast now.... Link to comment Share on other sites More sharing options...
Enzo the Magnificent Posted July 14, 2012 Author Share Posted July 14, 2012 Decals half done The main markings are on. Tomorrow it's time for the windows and doors. There is plenty of spare bits of blue and gold on the sheet, so I can patch up the area in front of the cockpit. Link to comment Share on other sites More sharing options...
Kev1n Posted July 15, 2012 Share Posted July 15, 2012 looking the biz!....dont stop now... Link to comment Share on other sites More sharing options...
Enzo the Magnificent Posted July 15, 2012 Author Share Posted July 15, 2012 looking the biz!....dont stop now... I can assure you, I have no intention of stopping. Having far too much fun! I still haven't finished applying the stickers. Link to comment Share on other sites More sharing options...
