rossm Posted April 19, 2012 Share Posted April 19, 2012 I've just got the Kiwi Resin 1/72 kit which is for G-AFAA, the slightly smaller span aircraft used by Percival himself. I found some plans on t'interweb, coincidentally the same ones in with the kit, which are for the longer span version as used by Henshaw. I have some wings in the spares box I can cut down and the fuselage is close enough not to notice so the model can be made to represent G-AEXF as it was in 1937 before it was heavily modified and eventually used for the Cape flight. I want to model it as used in the 1937 Devon Air Race per this Flight article page1 and Page 2 with Henshaw photo. Some questions, please, what was the interior colour (or most likely one if there is no hard information) and was the external colour white or off-white ? If off-white then with what tint ? Also, are there clear photos of the exhaust (?) under the cowling ? And one "wanted" - does anyone have the lettering for G-AEXF in the correct sizes please. A hi-res scan would be enough as they were in racing green for the 1937 season if I interpret "The Flight of the Mew Gull" correctly so I will almost certainly have to print my own. I can obviously swap G-AFAA decals if needed. Another "wanted" - one propeller from Aeroclub P008 2xMew Gull propellers if anyone has a spare please as the kit one is almost unusable. Thanks in advance, Ross Link to comment Share on other sites More sharing options...
John Aero Posted April 19, 2012 Share Posted April 19, 2012 (edited) I probably have the props in stock but note I am off ill. According to the drawings I have the interior was matt light green. John Edited April 19, 2012 by John Aero Link to comment Share on other sites More sharing options...
CarLos Posted April 19, 2012 Share Posted April 19, 2012 Hi Ross, Harry Robinson refers light green for the interior. You can get his very detailed drawings in Bent Throttles #39. Cheers, Carlos Link to comment Share on other sites More sharing options...
rossm Posted November 20, 2020 Author Share Posted November 20, 2020 Reviving this topic as the potential GB for racers and show offs has rekindled my interest. Over the intervening years I got hold of Bent Throttles 39 and reduced the plans from 1/48 to 1/72. I also got some Aeroclub bits including the prop but there remains a lot of work to get the fundamentals right. Measurement suggests the Kiwi fuselage is 3mm too short for G-AEXF in 1937, mostly in the engine area. I also have an Airframe vacform which is maybe 2.5mm too short. Both have the short wings of G-AFAA. Neither kit has the wing fillets and fairings. I have some Pioneer2 Yak-15 wings which have roughly the correct shape wingtips and ailerons but need the leading edge cutting back drastically as well as the span reducing. Alternatively the Kiwi wings could have new sections inserted at the root as they are the correct shape for the outer portion. So a lot of work for the wings and no obvious way to fix the fuselage. Has a new 1/72 kit come along in the last 8 years? (I haven't seen one but could easily have missed it). Link to comment Share on other sites More sharing options...
Dave Swindell Posted November 20, 2020 Share Posted November 20, 2020 15 minutes ago, rossm said: Has a new 1/72 kit come along in the last 8 years? (I haven't seen one but could easily have missed it). Dekno have a nice little resin kit of G-AFAA https://deknomodels.com/en/scale-model-kits-of-air-racing-aircraft/5-percival-p6-mew-gull-e3h.html Oldmodel Decals have done decals for G-AEXF in 1:48 and 1:72 https://www.scalemates.com/kits/oldmodels-decals-omd0522-percival-mew-gull-g-aexf-final-scheme--1260882 Link to comment Share on other sites More sharing options...
TEXANTOMCAT Posted November 20, 2020 Share Posted November 20, 2020 LDM Models did a white metal 1/48 kit IIRC back in the day - rare as hens teef! TT Link to comment Share on other sites More sharing options...
rossm Posted November 20, 2020 Author Share Posted November 20, 2020 1 hour ago, Dave Swindell said: Dekno have a nice little resin kit of G-AFAA https://deknomodels.com/en/scale-model-kits-of-air-racing-aircraft/5-percival-p6-mew-gull-e3h.html Oldmodel Decals have done decals for G-AEXF in 1:48 and 1:72 https://www.scalemates.com/kits/oldmodels-decals-omd0522-percival-mew-gull-g-aexf-final-scheme--1260882 Sadly the Dekno kit is the same later version (E3H) as the others. G-AEXF was a model E2H which was larger. Thanks for the note on the decals. Link to comment Share on other sites More sharing options...
rossm Posted November 20, 2020 Author Share Posted November 20, 2020 PS - the difference between G-AFAA and G-AEXF on the span is 8.5mm in 1/72, too much to ignore. Link to comment Share on other sites More sharing options...
