Mark M Posted March 11, 2012 Share Posted March 11, 2012 ok i have got my hands on a RN bucc and it will be made into a RAF Gulf War bucc, so what do i need to change it over, is it just the belly / bomb bay? Link to comment Share on other sites More sharing options...
tedtaylor Posted March 11, 2012 Share Posted March 11, 2012 I have an article on these buccs on my site , some of it may be helpful to you, http://tedtaylor.hobbyvista.com/34-airfix-...er/page-34.html Ted Link to comment Share on other sites More sharing options...
AnonymousAA72 Posted March 11, 2012 Share Posted March 11, 2012 ok i have got my hands on a RN bucc and it will be made into a RAF Gulf War bucc, so what do i need to change it over, is it just the belly / bomb bay? Far from it Mark! There were many,many differences, some very noticeable and others not so. Take a look here.....Best Buccaneer site in the world - probably Link to comment Share on other sites More sharing options...
Mark M Posted March 11, 2012 Author Share Posted March 11, 2012 thanks TED Link to comment Share on other sites More sharing options...
Mark M Posted March 11, 2012 Author Share Posted March 11, 2012 thanks bill, looks like i need a raf kit, not a rn one Link to comment Share on other sites More sharing options...
Hawkkeeper Posted March 11, 2012 Share Posted March 11, 2012 ALL Raf S2B Bucc's had the bulged bomb door which was a fuel tank, wing tip fairings varied between airframes Link to comment Share on other sites More sharing options...
zero Posted March 11, 2012 Share Posted March 11, 2012 ALL Raf S2B Bucc's had the bulged bomb door which was a fuel tank, wing tip fairings varied between airframes Except when the reccy pos was in place, a simple solution to the problem mark! http://www.heritageaviationmodelsltd.com/b...e-pod-126-p.asp I'm pretty sure the other bits needed are in the kit, just the RN one doesn't have the RAF weapons, let me have a look I believe I have a few spares after my clear out, Dave Link to comment Share on other sites More sharing options...
Mark M Posted March 11, 2012 Author Share Posted March 11, 2012 ok help me out, if i was going to do xv863 sea witch, what would i need to change from the RN kit belly tank wing tips? dont know which are in the kit anything else Link to comment Share on other sites More sharing options...
Hawkkeeper Posted March 11, 2012 Share Posted March 11, 2012 (edited) Except when the reccy pos was in place, a simple solution to the problem mark!http://www.heritageaviationmodelsltd.com/b...e-pod-126-p.asp Dave recce pack attached to the inner face just as the 'special weapons' fairings & standard bomb fit did, the door rolled open to deploy weapons & give the recce pod access the tank was the the door itself, fuel tank top skin was the interior face & outer bulged skin was the lower skin of the tank. other 8 fuel tanks were integral to the fuselage centre section above the bomb bay Edited March 11, 2012 by Hawkkeeper Link to comment Share on other sites More sharing options...
Mark M Posted March 11, 2012 Author Share Posted March 11, 2012 so can i replace the belly bulge, with the recce pack for A GULF WAR bucc? Link to comment Share on other sites More sharing options...
Jabba Posted March 11, 2012 Share Posted March 11, 2012 so can i replace the belly bulge, with the recce pack for A GULF WAR bucc? Recce pack not used on Gulf war Buccs. Link to comment Share on other sites More sharing options...
zero Posted March 11, 2012 Share Posted March 11, 2012 (edited) recce pack attached to the inner face just as the 'special weapons' fairings & standard bomb fit did, the door rolled open to deploy weapons & give the recce pod access the tank was the the door itself, fuel tank top skin was the interior face & outer bulged skin was the lower skin of the tank. other 8 fuel tanks were integral to the fuselage centre section above the bomb bay Yep, but my point was if you used one of those, you don't need the bulged bay door. From what I can see the main different is the wingtip ie the RN ones are the same on the S2B unless your doing a Gulf war bird, then there different, I seem to have two RN kits myself, but with the RAF sprue included two, I don't seem to have the gulf war wingtips. However luck for you buddy I have two RAF sprues and only need the one, so that will save you some hastle (are I just found the Gulf war wing edging there on there two. I've only got two buck left now, onw to do a RAF camo bird, and one to do A RN one, so the RAF sprue is spare and yours mate, PM me your address Dave Edited March 11, 2012 by zero Link to comment Share on other sites More sharing options...
Mark M Posted March 11, 2012 Author Share Posted March 11, 2012 thanks dave pm on way has that got the belly? Link to comment Share on other sites More sharing options...
zero Posted March 11, 2012 Share Posted March 11, 2012 thanks dave pm on way has that got the belly? it the whole sprue from the kit mate, ie Belly tank Gulf war wing tips winder pylons an/alq 101 & pave spike Dave Link to comment Share on other sites More sharing options...
Mark M Posted March 11, 2012 Author Share Posted March 11, 2012 it the whole sprue from the kit mate, ieBelly tank Gulf war wing tips winder pylons an/alq 101 & pave spike Dave i love you Link to comment Share on other sites More sharing options...
zero Posted March 11, 2012 Share Posted March 11, 2012 i love you No tongues! Now no your luck I'm still sorting my stash, ie coming down to a reasonable amount to build, ie 1 of each item two of each in some cases, the bucks are right by my side, so hence I know I have all I need and this spare, so your welcome to it. It will probably be in the post tuesday morning Dave Link to comment Share on other sites More sharing options...
Hawkkeeper Posted March 11, 2012 Share Posted March 11, 2012 recce pack exposed if a/c posed in a flying state or parked on the flightline/HAS with ground crew under the a/c, the bomb door would be closed until the recce pod was required to do it's job. Link to comment Share on other sites More sharing options...
xvtonker Posted March 11, 2012 Share Posted March 11, 2012 Don't forget the RWR on the fwd and rear bullet fairings on the tail. The RAF Bucc's had this installed in the 1970's XVTonker Link to comment Share on other sites More sharing options...
zero Posted March 12, 2012 Share Posted March 12, 2012 recce pack exposed if a/c posed in a flying state or parked on the flightline/HAS with ground crew under the a/c, the bomb door would be closed until the recce pod was required to do it's job. Thanks for the info I do have a reccy pack but I dout I will use it now. Dave Link to comment Share on other sites More sharing options...
AnonymousAA72 Posted March 12, 2012 Share Posted March 12, 2012 ALL Raf S2B Bucc's had the bulged bomb door which was a fuel tank, wing tip fairings varied between airframes Not strictly true as some initial RAF S2B's had the standard un-bulged bomb door. These were modified later...XW530 being one such example.... Link to comment Share on other sites More sharing options...
