Mike Posted March 7, 2012 Share Posted March 7, 2012 Early Soviet Jet Instrument Dial Decals 1:48, 1:32 Airscale Model Aircraft Enhancements Photo quality intentionally low to protect copyright material Anyone that likes to improve their kit cockpit and instrument panels can't have missed the Airscale range of decals that give your instrument panels that authentic look that would be otherwise impossible unless you printed your own decals. These new sets available in the two main scales contain a raft of instrument faces, some in colour, for your early Soviet jets. Each instrument decal is incredibly well detailed, and numbered for cross-referencing with a key that tells you the function of each one. It's quite a list, but I've laid it out below for information: Attack Angle Fuel Gauge Homing Indicator Oxygen Pressure Gyro Compass Oil/Fuel Temperature Attitude Indicator Gyro Magnetic Compass Altimeter Turn & Slip Indicator Airspeed Indicator Clock/Chronograph Clock/Chronograph Exhaust Gas Temperature G-meter Altitude Indicator Hydraulic Pressure Gauge Attitude Indicator Turn & Bank Indicator Tachometer Voltmeter Cockpit Pressure Gauge Wheel Pressure Gauge Oil Pressure Gauge Oil/Fuel Capacity/Temp Fuel Pressure Gauge Temperature Indicator EGT Acceleration Gauge Hydraulic Pressure Gauge Tachometer Each set comes with a small sheet of clear acetate for you to use as glass in front of each decal, which can be punched out individually, or laminated between the decals and the instrument panel front. conclusion Yet another addition to the growing set of instrument decals, placards and complete instrument panel sets available from Peter @ Airscale. Having used some of Peter's decals on various builds, I can confirm that they settle down well with Mr Mark Setter, and the carrier film becomes invisible once set. You can punch the individual decals from the sheet, but I just cut them out into a vaguely circular shape with a scalpel, because the carrier film is so pliable. I can't recommend these highly enough for improving your cockpits. Review sample courtesy of Peter at Link to comment Share on other sites More sharing options...
