Universal Carrier Query
Paul Bradley
The RAF did not normally use the Universal Carrier but I've a feeling I've seen one in the distinctive Malta camouflage in RAF surroundings. I was going to say that it was dragging a belly-landed Beaufort off the runway but on reflection that would be a sight too heavy and I'm probably remembering a Matilda.
I suspect that Carriers were generally Army property; if the RAF Regiment blagged any then it was probably much later as the Regiment was only formed in February 1942.
As to Malta, I suspect that the defenders were soldiers for most of the war. The manpower situation was such that at some times it was down to all hands that were available, irrespective of badge or colour of uniform.
Now, there are two photographs that may interest you. Graham was absolutely correct about the Beaufort and the Matilda tank, see here about half way down the page:
http://www.ww2incolor.com/forum/showthread...e-desert./page4
However, there is this thread from Britmodeller, found lurking in the aircraft section, scroll down this to the end:
http://www.britmodeller.com/forums/index.p...77&hl=malta
A carrier, Malta 'dry stone wall' camouflage, towing loaded bomb trailers with a Wellington in the background. Winter with an unusually thick layer of mud on the ground.....
I think the crew are probably army, not RAF, despite the hats (which were in general Army use as the Field Service Cap despite the apparent adoption of the beret years before).
Note the 'Malta Cross' plate on the front of the carrier; this may just be a Malta Command badge but equally may indicate that the carrier is actually assigned to a Malta Defence Regiment unit. The serial number T28576 may be of some help (I will ask if anyone can help on the Missing Lynx site).
All the best,
John
Paul,
This thread may be of some help in terms of the badge on the Carrier and there is another image linked in the thread too.
http://www.network54.com/Forum/47208/threa...help%2C+please-
I don't know if you have noticed, but the Wellington shown in the original picture I found is a Mk II with Merlin engines....
Malta had a whole range of Wellingtons serving during the war, though, so you can do your own research but if you want to stick to the picture then try this for the MKII in 1/48th:
http://modelingmadness.com/reviews/allies/gb/earingwimpy.htm
http://www.britmodeller.com/forums/index.p...topic=234911647
The pilot story:
http://www.killifish.f9.co.uk/Malta%20WWII/North_Africa.htm
http://www.timesofmalta.com/articles/view/...d-war-ii.355726
And a few wrecked Malta Wellingtons:
http://www.killifish.f9.co.uk/Malta%20WWII/Wellington.htm
The Malta Wellington squadrons seem to have been 38 and 104 with a number of detachments from N Africa and transients 'borrowed' as they staged through the island.
Have fun,
John
  • 3 weeks later...
I have seen that picture, The Uni was pulling bomb trollies away from an aircraft, (might of been a Lancaster) I was thinking that would make a good diorama....
Ian M
