Mr B Posted January 29, 2012 Share Posted January 29, 2012 Hello Folks Got cracking on this........... This is going to be a sweat and tears build............lots of work to do....and the plastic is brittle and soft......... Anyways always wanted a Mirage in 1/32 so........down to the grinde........if all goes well by end of Feb 2012 This is the build and the various aftermarket stuff going to be used Wish me luck guys Regards Mr b Link to comment Share on other sites More sharing options...
Romeo Alpha Yankee Posted January 30, 2012 Share Posted January 30, 2012 (edited) Nice! I hope you are doing the 77SQN aircraft I am biased of course have been at 77SQN and worked on these! Though I suspect it will be a Butterworth based aircraft, am I right? Edited January 30, 2012 by TrojanThunder Link to comment Share on other sites More sharing options...
Mr B Posted January 30, 2012 Author Share Posted January 30, 2012 Nice! I hope you are doing the 77SQN aircraft I am biased of course have been at 77SQN and worked on these!Though I suspect it will be a Butterworth based aircraft, am I right? Hi Trojan thunder.......... thanks ..........and you guessed it right............either 3 or 75 sqn Butterworth based............. Rgds Mr B Link to comment Share on other sites More sharing options...
spike7451 Posted January 30, 2012 Share Posted January 30, 2012 I have the same kit & the resin stuff as well,it's sort of half done but not,the plastic is that soft,the slightest preassure along the fusalage spine,once filled,cracks the filler & you're back to square one!... I'll get round to fininshing it someday.. Link to comment Share on other sites More sharing options...
Mr B Posted January 30, 2012 Author Share Posted January 30, 2012 Hi Spike Yes the plastic is very brittle..........and soft............a bit worried myself..........but my policy is once out on the table.........it has to be done.........good or bad......till done...........wish me luck and hope to see yours done up soon too.... Anyways had some progress done.............on the scribing ...........few days back..........as well as cutting the rudder out.........on closer inspection......missed a bit on the fin.......... Next Fuselage.....really dreading to scribe that..................wish me luck for straight lines......... Best to All Mr b Link to comment Share on other sites More sharing options...
spike7451 Posted January 31, 2012 Share Posted January 31, 2012 Good luck!! I snapped the nose off when cutting the area to fit the cockpit sides for the resin pit... Link to comment Share on other sites More sharing options...
Iain Ogilvie Posted February 1, 2012 Share Posted February 1, 2012 Brilliant subject - welcome aboard... Really interested to see how this one goes. Iain Link to comment Share on other sites More sharing options...
Mr B Posted February 5, 2012 Author Share Posted February 5, 2012 Thanks guys....the nose section was really put to the test....but did not snap Update All rescribed...........and when doing that.........notice somemore stuff needs to be done espically the air scoops........as one was molded almost flat.......??? Cut open the grills towards the rear of the plane ........ Got the molded cockpit bits out of the way............and test fitting the Fisher cockpit set........looks ok Tonight is study time..........need to look at the references and see ...... Rgds to all Mr b Link to comment Share on other sites More sharing options...
Mr B Posted February 6, 2012 Author Share Posted February 6, 2012 Double public holiday......... Update Got some minor work done....air scoops and the rear grill..........need to sand down and blend in....... Also glued the wings on...........to start work on the undercarrage bays......just for the fun of it the wonderful delta shape...........really sexy in 1/32 scale...... Back to the grinde.........still got loads to put together and do....... Rgds Mr B Link to comment Share on other sites More sharing options...
Mr B Posted February 9, 2012 Author Share Posted February 9, 2012 Update Manage to make the gear wells busy........ The front is a resin piece which I plan to stuff inthere from plane bits Cut the fuel cock window display too.... Need to get some paint on it which is delayed due to airbrush problems ......soon detailling the pit and then can buttom it all up and start the filling process........ Rgds Mr b Link to comment Share on other sites More sharing options...
Iain Ogilvie Posted February 11, 2012 Share Posted February 11, 2012 Having built a few of these I think you're doing a cracking job - and very fast! I can see I may have to get myself a couple of copies of that pit... Iain Link to comment Share on other sites More sharing options...
Mr B Posted February 19, 2012 Author Share Posted February 19, 2012 Thanks Ian............ Lots more to go Got the sides together Next is all the clean up and assembly........... The fisher cockpit set is a gem.........fitting is perfect............no need to take off any resin extras........... Till later Mr B Link to comment Share on other sites More sharing options...
Mr B Posted February 23, 2012 Author Share Posted February 23, 2012 (edited) Progress There are many gaps and they are big........... Managed to putty and clean all the seams ......well I hope........left the finer bits then off to paint.......... The front panel....needs to tone down with flat and clean off the additional oil...wash....this will be tackled once I paint the top area....and fit the canopy/windsheild....... Left to rewire a bit on the wells.......the gun bays, the intakes and final smooth sanding then clean the lines and windsheild........and then onto the paint shop...... Wish me luck to meet my Febuary end dateline..... Rgds Mr B Edited February 23, 2012 by Mr B Link to comment Share on other sites More sharing options...
Romeo Alpha Yankee Posted February 28, 2012 Share Posted February 28, 2012 Nice progress, the instrument panel looks great! Link to comment Share on other sites More sharing options...
Mr B Posted February 28, 2012 Author Share Posted February 28, 2012 Thanks Ray Got some progress Airframe ready for paint Painted futured and decalled Better pictures later ....decals were very good but no stencils ....had to impresive still got a bit to go.... Rgds Mr B Link to comment Share on other sites More sharing options...
Mr B Posted March 4, 2012 Author Share Posted March 4, 2012 Finished The decals were not as good as I first tought..........during the weathering process some were eated up lucky had extra........anyways completed......and some research points to this actual airframe which crashed on top another Mirage III in butterworth....A3-64 This is the link http://www.adf-serials.com/3a3.shtml And the final pictures........ Apologies for inaccuracies........before hand if time permits one more biggy will be started Rgds & Thank you Mr B Link to comment Share on other sites More sharing options...
Will Vale Posted March 4, 2012 Share Posted March 4, 2012 That looks utterly fantastic! Love the cockpit and the variation in tones on the wings. Link to comment Share on other sites More sharing options...
Parabat Posted March 4, 2012 Share Posted March 4, 2012 Awesome Mirage, love the Deltas, you've made a cracking job of it. Link to comment Share on other sites More sharing options...
Mr B Posted March 4, 2012 Author Share Posted March 4, 2012 Thanks guys Much obliged for the nice words Rgds mR b Link to comment Share on other sites More sharing options...
Metallicus Posted March 7, 2012 Share Posted March 7, 2012 Fantastic build!! Love the paint job!! Cheers Brenden Link to comment Share on other sites More sharing options...
Iain Ogilvie Posted May 27, 2012 Share Posted May 27, 2012 Hey Mr B - can you post some pix in the GB Gallery - http://www.britmodeller.com/forums/index.p...topic=234915976 Thanks, Iain Link to comment Share on other sites More sharing options...
