OOB 1/24 Airfix Hurricane
I just wanted to play around with some paint so I broke out an old Airfix 1/24 Hurricane and put it together in about a week over the Christmas break. The kit went together very easily and primed up quiet nicely not too shabby for a kit that's as old as this one.
Bit of pre shade.
And then on to the sky undersides.
Still a bit contrasty but it should weather down in the end. I've got to wait until the paint cures a bit more before I mask off for the roundels.
All paints are Tamiya acrylics thinned with Tamiya lacquer thinners.
Thanks for looking.
Dan
crobinsonh--Thank you for your encouragement. I'm glad you liked it.
I've spent much of the day scratching a replacement spinner. My kit was missing one when I opened it.
I stuck lots of pie shaped profiles of the spinner onto a round baseplate. Then used two part epoxy putty to fill the gaps, after a rough sand to shape. I covered the lot in a thin layer of superglue and talcum power.
Much sanding latter I have this;
I've still to add the middle joint and some other details but It's looking a bit like a spinner.
Working on other bits too. Didn't like the rubber tires and so i cast a replacement tailwheel in superglue from a open face mould.
With luck I'll get to work on the main gear legs tonight.
That's a good idea - casting replacements for those awful rubber tyres supplied with some kits must be cheaper and more fun than buying someone else's aftermarket. Thanks for the tip.
Don-- Thanks! Yep casting is a lot of fun and opens up a lot of possibilities.
Progress;
I don't like decals much so got out the Tamiya masking tape and the circle cutter. Whipped up some masks and airbrushed the roundels. Didn't do too badly and at least no silvering.
Dan
Can't beat actually painting something on to get that 'painted on' look, eh? Looking good, I must say..
So how is this old girl, detail-wise? I've got a project in mind using a 1:24 aircraft, but can't really decide if I want to go Trumpeter or Airfix.
What can be more fun than painting camo on a windy & rainy summer day in Melboourne ;)
Now I just have to keep my mits off it for a day so that it will dry and then I can mask off the upper side roundels and markings. I've ordered the dry transfer stencils for her but they won't be in for a week or so, sigh.
Mish--Thanks! Nice to know you like her.
Mochealvk-- I paint most of my markings because I can't get decals to work for the life of me... I do like how the painted ones look even if it's a bit of work. The Airfix kit is pretty good for as old as it is. I'm never too fussed about detail as long as it looks the part. the kit builds well but I don't know how well the removable cowls would fit if you put the detailed engine on display. I used a heap of superglue and a bit of brute force to get them to fit closed. Good solid kit and a base for detailing.
Smeds--Haven't seem the Trumpeter kit but one of Airfix best big kits along with the Stuka. In fact if you've built the Stuka then the detail and fit are very much the same.
Dan
Bit more on the markings.
I'm working on the masks for the four colour fuselage roundels. Now they will be fun, fun, fun.
Here's my latest workbench. I now have an area just to do masking/decaling and clean work. It doubles as a area to take photos.
Beautiful build! I have the kit from when it was first issued and haven't got around to building it – now I'm feeling inspired!
Doesn't the pre shading look a trifle, er… obvious, though? At least on the photos, to my eyes…
Best,
Joachim
Looking good, I like that worn look
I wasn't referring to a worn look per se – I like a realistic worn look, too. I just thought that the pre shading, to my eyes, looked a bit identifiable as, ahm… pre shading.
My personal taste, that's all.
Best,
Joachim
Optus mobile broadband is not my friend tonight....Computers & Internet Bah!
Progress;
Made some headway on the resin wheels. Cast in resin from half molds I made with Instant Mold.
Bit more clean up but should work okay
Off to work tomorrow.
Hope you like her so far.
Joachim--Fear not. The camoflage is very bright and contrasty but I'll be adding washes and oversprays to tone it way down before I'm finished.
That said I do like a bit more contrast than some in my paint finishes. Just a matter of personal taste.
Dan
Edited by ScanmanDan
Progress;
Other side serials done.
Real bugger getting that K in there without a ton of overspray. Looks as if they had to squeeze it in full size as well.
Received HobbyDecal dry transfers on Friday( Love the post!) Started applying them.
I have much better luck with dry transfers than waterside decals. A joy to use.
Spent much of the morning grinding out the resin wheels I cast to fit the rims. I hadn't thought that the rubber tires in the kit are stretchy and therefore slightly under size, hence the grinding.
A bit of paint and they are on their way.
Worked on the belly radiator and the main gear struts. Took off all the underside masking and had very little overspray to fix up. Need to mask off so I can spray the wheel wells( Silver or interior green?)
Having a ball and nearing completion. Now I have to find a spot to put her as I've just noted that she doesn't fit in my Ikea Deltof cases!
Thanks for looking in.
Dan
  • 3 weeks later...
Some more progress;
Radiator finished.
Got her up on her pins and most of the detail painting finished.
Roughed out a base.
Lots of little details to still apply but I can see the end from here.
Thanks for looking.
Dan
