Mark Posted January 21, 2012 Posted January 21, 2012 (edited) Two GE F-110-GE-400 engines, swing-wing technology, twin vertical fins, Supersonic, oh, and a film star as well! Just some of the credentials that make the F-14 Tomcat one of my favourite aircraft and it was at the Dubai Airshow in 2005 that I first saw one fly. She came from nowhere, very low and very, very fast. The eerie silence that preceded her, which continued as the Tomcat shot across my field of view, to be followed by the roar from those afterburning GE F-110s after the aircraft was well out of sight, told me that she was transonic and almost at the edge of releasing a sonic boom. A display followed that could only have been bettered by the 1970s displays I saw of the Lightning and Vulcan. I have started many Group Builds and probably bitten off more than I could chew in joining a few at the same time, so this time I will join this one and try and do justice to the bits and pieces that I have to adorn Hasegawa’s 1/48th F-14D kit. Photos of what I have to start and (hopefully!) complete this Group Build will be up tomorrow, but in the meantime, let me start by showing you the aircraft that I will be modelling. I am way out of my depth with regards to my knowledge of US military aircraft, so be prepared for lot of questions! I'm off to clean up my new modelling desk, start organising the kit and accessories and I'll be starting tomorrow! Edited March 27, 2012 by Busdriver
AnonymousDFB1 Posted January 22, 2012 Posted January 22, 2012 You can't have too many Tomcatters builds
Mark Posted January 22, 2012 Author Posted January 22, 2012 (edited) The box has been opened, the parts photographed and the after-market sets all found within the stash of after-market bits and pieces. I love going into that drawer, I never know what I'm going to find! Anyway, the plan has been finalised and centres around Hasegawa's 1/48th F-14D in the VF-2 Bounty Hunters boxing. The kit is 09374 and I think that I must have picked it up in Japan when I worked for Emirates as their is an lot of Japanese text on the box! So far I have located the Black Box F-14D Cockpit set, number 48012, the Eduard etched detail set 48-304, a Verlinden Super Detail Set, 427. The decals are by AeroMaster, sheet number 48-526 Anytime Babe Pt.IV which includes the subject of my build, the CAG F-14D of VF-31, '200' USS Carl Vinson, October 1995. I have photos of what I have so far, but I've just had a bit of a spending spree and ordered the Aires wheel well and GE F-110 tailpipe sets, the SAC Undercarriage and Master Pitot / AoA probes and what looks like a beautiful set of gun barrels for the Vulcan cannon. All in all a project that will keep me very busy over the next two months! Here are the photos and wish me luck... There is an awful lot of plastic, resin and metal here! Edited January 22, 2012 by Busdriver
Bandwagon 106 Posted January 22, 2012 Posted January 22, 2012 Best of luck with this, it will look great. Looking forward to seeing all this going together! Joel
Mark Posted January 22, 2012 Author Posted January 22, 2012 (edited) Cheers for the encouragement! This is a BIG project and I've got a habit of starting, but not finishing these types of builds, but I'm determined to get this one done. I've made a flying start and washed the parts! I don't know if this is really needed, does anyone else do it every time? The plastic feels very 'squeaky clean' after being washed and less greasy, so maybe it is beneficial. The parts were all laid out and left to dry before I started looking at the major surgery needed on the nose halves! The Verlinden instructions clearly show which panels to cut out and these were marked off, checking over and over again to make sure I'd marked the right areas! The Black Box cockpit needs the base sanding down to a line scribed around the sides, and the instructions suggest that the two footwell recessed areas are cut out, leaving the resin itself to represent the wall of the footwell. The alternative is to carve out the resin in the appropriate areas, which is what I think I will do. Hopefully I'll have the boxes all painted up and installed, the cockpit completed and the nose halves joined by the end of February!! February 2013 that is!! When is the finish date again? Edited January 26, 2012 by Busdriver
jenshb Posted January 22, 2012 Posted January 22, 2012 Quite an ambitious project there Mark. Before you cut out the fuselage panels, I'd check the dimensions of the resin to make sure that it hasn't shrunk too much - otherwise you will have a scratchbuilding or a repair job on your hands. Jens Quite an ambitious project there Mark. Before you cut out the fuselage panels, I'd check the dimensions of the resin to make sure that it hasn't shrunk too much - otherwise you will have a scratchbuilding or a repair job on your hands. Jens
erikmuntz Posted January 22, 2012 Posted January 22, 2012 "Surely you can't be serious!" That's a lot of resin and aftermarket you have there that will require a lot of work, but I'm sure the finished product will be one for the record books! I always wash my parts, too, so you aren't alone. I read somewhere that the mold release agent can play funky tricks on you when painting so I've always washed my kits before starting. watching this one for sure. Erik
Mark Posted January 22, 2012 Author Posted January 22, 2012 Cheers for the comments! Yes, the resin has shrunk a bit but should be hidden behind the etched framework. As for the first stage of the build, I'm going with the nose gear bay. Hopefully it'll look like this!
Giorgio N Posted January 23, 2012 Posted January 23, 2012 Great project Mark, looking forward to see the fuselage cut and the details inserted. Hope you manage to finish this one. Nice picture of the nose wheel well BTW, will help all those who want to add some more details
Andy Mullen Posted January 23, 2012 Posted January 23, 2012 A lot of work you have here Mark, but looking forward to seeing this scheme (another tasty scheme to add to my todo list)
Mark Posted January 24, 2012 Author Posted January 24, 2012 Cheers guys, as for being a 'good 'un' Kev1n, hmmmm, I've only just painted the interior of the nose wheel bay, only to find that the Aires set includes the nose gear bay as well as the mains! I thought it was just the mains... So mistake number one already! Just seen that the Hannants order is on the way and cannot wait to get this gorgeous set!
Giorgio N Posted January 24, 2012 Posted January 24, 2012 Cheers guys, as for being a 'good 'un' Kev1n, hmmmm, I've only just painted the interior of the nose wheel bay, only to find that the Aires set includes the nose gear bay as well as the mains! I thought it was just the mains... So mistake number one already!Just seen that the Hannants order is on the way and cannot wait to get this gorgeous set! Wow, the Master Vulcan barrels set ! That company works really well, these barrels will add a lot to the finished model !
Kev1n Posted January 24, 2012 Posted January 24, 2012 Cheers guys, as for being a 'good 'un' Kev1n, hmmmm,....mistake number one already! Well, since I'm also amongst those who have never built a tomcat before, you think I'm perfect? (ok I know I am, but thats not the point...) But I have faith in you, I will fly on a bus driven by you and I know your a good builder so you will carry this one off admirably.
Mark Posted January 24, 2012 Author Posted January 24, 2012 (edited) Yes, there's been progress! Thanks for your faith Kev1n, now, let's see if it was worthwhile. Today, in between walking the dog and amusing Oliver whilst Mum is learning French, I have been mostly getting my fingers stuck together with thin CA. I've made a start on the nose area and the first thing that was needed was to cut out the panels that would allow the lovely Verlinden resin inserts to be exposed. Having already marked the panels out with a fine marker pen, I chain drilled around the edge and then cut the panels out. A long process but after the panels were cut out and cleaned up, the real work began! Those Verlinden frames are incredibly fine and need very careful handling, otherwise they just end up as a mass of bent etched metal. They were carefully adhered in place and then the resulting mess of Cyano-Acrylate was cleaned off of my fingers and where it had ended up on the model surface, that was also cleaned up with various grades of abrasives. Can you believe that it took me over six hours just to achieve this?!! But I'm quite happy with it and the gaps at the top, where the framework doesn't quite meet the plastic, will be hidden by the edges of the raised panels. It's all rather weak and fragile at the moment and I can just see accidents happening in the future! The various kinks and 'unstraightness' (is that a word?) will be sorted once the other bits and pieces are added... I hope! As for the resin inserts, here´s the starboard one having received a coat of Xtracolour Zinc Chromate yellow before the detail painting begins. It's shown approximately four times the size of the actual one, so magnifying goggles are at the ready! I'm off to have a relaxing evening now and I've promised myself that tonight will be the night I sit down and watch Paranormal Activity! Edited January 26, 2012 by Busdriver
Bandwagon 106 Posted January 24, 2012 Posted January 24, 2012 What patience! Great work here Mark Joel
Mark Posted January 24, 2012 Author Posted January 24, 2012 Just shown Zuzana my afternoon's work.... "That's lovely darling, is that the luggage space?" I do love her!
easyAl Posted January 25, 2012 Posted January 25, 2012 Six hours!? You must have far more patience than me, but it looks like it's going to be worth it. Looking good so far
Mark Posted January 25, 2012 Author Posted January 25, 2012 (edited) Thanks Mish, although when I get in real close with the macro lens, I always regret it! It shows up every flaw and mistake; there's no hiding from the lens of macro!! Right, new dawn, new day, I'm feeling good, so off to the bench! Edited January 25, 2012 by Busdriver
AnonymousDFB1 Posted January 25, 2012 Posted January 25, 2012 Digital camera+macro setting+high quality photos= your best friend or your worst enemy
Kev1n Posted January 25, 2012 Posted January 25, 2012 this is true ^ the number of times I look at something I've just built and think "yeah...cool..." then I see a pic of it and change my mind.
Mark Posted January 25, 2012 Author Posted January 25, 2012 (edited) I'm really enjoying this one! Finished detailing the avionics bays today, a bit of poetic licence as the Verlinden set is for the F-14A (I think) and this is a -D model, so I'm certain that there will be differences. Anyway, here's my afternoon's work. Edited January 26, 2012 by Busdriver
