phat trev Posted January 15, 2012 Share Posted January 15, 2012 (edited) Would the 1/72 Airwaves cockpit etch set fit the Frog Fairey Firefly Mk.1? Anyone tried? Edited January 15, 2012 by phat trev Link to comment Share on other sites More sharing options...
venomvixen Posted January 16, 2012 Share Posted January 16, 2012 Not heard of this set. Where would one go to ease of with one? Link to comment Share on other sites More sharing options...
Paul Bradley Posted January 16, 2012 Share Posted January 16, 2012 (edited) Many parts can be used, but the Airwaves set is designed for the Airfix kit, which is much narrower, so the aft cockpit coaming won't fit - I scratchbuilt one on my builds. The seats are particularly nice, and I also used the sidewalls and assorted other small parts. It's worth considering, and currently available from Hannants: http://www.hannants.co.uk/product/AEC72164 Edited January 16, 2012 by Paul Bradley Link to comment Share on other sites More sharing options...
Giorgio N Posted January 16, 2012 Share Posted January 16, 2012 Many parts can be used, but the Airwaves set is designed for the Airfix kit, which is much narrower, so the aft cockpit coaming won't fit - I scratchbuilt one on my builds. The seats are particularly nice, and I also used the sidewalls and assorted other small parts. Which one do you believe is more correct ? Link to comment Share on other sites More sharing options...
Paul Bradley Posted January 16, 2012 Share Posted January 16, 2012 The Frog kit - the Airfix one is a bit underscale all round. Link to comment Share on other sites More sharing options...
Giorgio N Posted January 16, 2012 Share Posted January 16, 2012 Thanks Paul ! I have an airfix kit I'm thinking of trying to improve, but the more I look at it the more I think the challenge is too extreme for me Link to comment Share on other sites More sharing options...
Troy Smith Posted January 16, 2012 Share Posted January 16, 2012 Would the 1/72 Airwaves cockpit etch set fit the Frog Fairey Firefly Mk.1? Anyone tried? If you have a graphics program, save the image of the set, and then rescale it to a known dimension [might be tricky if the Airfix kit is underscale] suggest converting to a b/w image and then print out a copy on thin card, you can then cut out bits and see if they fit..... or use them as a template to scratch the items if you having a case of the "Nobby's" [see work in progress threads] though I suggest you'd find out why aftermarket was invented then..... HTH T Link to comment Share on other sites More sharing options...
phat trev Posted January 16, 2012 Author Share Posted January 16, 2012 If you have a graphics program, save the image of the set, and then rescale it to a known dimension [might be tricky if the Airfix kit is underscale] suggest converting to a b/w image and then print out a copy on thin card, you can then cut out bits and see if they fit..... or use them as a template to scratch the items if you having a case of the "Nobby's" [see work in progress threads] though I suggest you'd find out why aftermarket was invented then.....HTH T damn good idea! Link to comment Share on other sites More sharing options...
venomvixen Posted January 16, 2012 Share Posted January 16, 2012 The Frog kit - the Airfix one is a bit underscale all round. Really? I have a set of 1/72 scale plans that the Airfix kit seems to match quite well. Link to comment Share on other sites More sharing options...
Paul Bradley Posted January 16, 2012 Share Posted January 16, 2012 Depends on whose plans you use - I refer to the new ones created by our own Mark Gauntlett Link to comment Share on other sites More sharing options...
