Italeri Panther 1/35 Kit No. 270
Rodders
Hi All,
First happy new year to all.
I wanted to ask about painting Zimmerit on the Italeri 1/35 Panther A. I've got a bit to do before i start painting, but is there anything i need to do differently. I'll be airbrushing it.
I've never done a zimmerit finish before, so wanted some advice before i started.
Thanks.
Hi Andrew
Heres a link for doin Zimmerit
http://www.armorama.com/modules.php?op=mod...d=30&page=5
Have done this on a Tamiya King Tiger many moons ago-looked great when finished. I used Miliput as the paste-but im pretty sure there are plenty heaps other puttys u could use.
Robert :D
Edited by robert26
Hi Andrew
Robert :D
Thanks for the help Robert, very kind. I don't think i explained myself very well. The Italeri Panther has Zimmerit moulded on already, i was after help with painting it. Is it done in a special way?, as using an airbrush might not cover properly. I don't know as i'm hopeless brush painting.
Cheers.
There shouldn't be any trouble unless the Zimmerit texture is horribly coarse. The best way to spray would be to hold the nozzle perpendicular to the surface (so at about 45o, nose-down), but it should cover reasonably well from just about any angle other than dead parallel. You may want to highlight the upper edge of each horizontal groove - either a gentle spray downwards, or dry-brushing.
It should just about be possible to introduce more relief by undercoating with dark brown (or similar) first and then applying the camouflage colours from above, so that they stay mainly on the outermost surface and miss the depth of the grooves. But I'd be surprised if the grooves were deep enough to make this reliable, and I'd be inclined to get that relief from washes instead.
Hi Andrew, and Happy New Year to you too ;)
You shouldn't have any trouble - just approach the painting from different angles to ensure that the various sides of the zimmerit blocks are covered. If you noodle it on lightly, by the time you've got a heavy enough coat on to hide the primer, you'll find very little touch up necessary. Leave the paint in your brush for a few minutes until the paint is touchdry on the model, and then go over any bits you've missed, as it's sometimes very easy to go "snowblind" when you've been looking at something for a while. :hypnotised:
Cheers.
Whoops-good luck with the Panther-lets see it when finished
Robert :)
