Whare can i get, A-4 Falklands Argentinian decals
Mark M
Be aware that the Italeri release is the A-4E/F/G. The Argentine Air Force operated the A-4B ( local designation A-4P) and the A-4C while the Argentine Navy operated the A-4B (designated A-4Q). In the nineties they received the A-4M and OA-4M (local designations A-4AR and OA-4AR respectively).
Depending on how accurate you want your Skyhawk you may be up for some heavy modification work if you want it displayed correctly: the main differences between the A-4E/F/G and A-4B/C being around the intakes and the nose.
Just for your information.
Bjarne
thansk for that, but i sware blind its a a and B kit i may well be wrong
No, it's not an A/B kit. I did a fair bit of research on this very subject.
Apparently the best A4-B/C are the hasegawa kits. They even did a specific Falklands boxing with resin radomes. All unavailable. The Falklands boxing sells for way to much cash on evilbay...
Hobbycraft did A-4C 'Vietnam' and A4B 'Falklands' Skyhawks, both come with Argentine Falklands era decals, which are the decent type as well. Easier and cheaper to find.
Problem is Hobbycraft made the canopies the same width as the later A-4M, so they are too wide.
The HC kit is pretty good, not as refined as HAse, but has a lot of ordanance. There are a few reviews and previews on Modeling Madness if you have a look there, or just have a google about now you have some pointers.
HTH
T
Edited by Troy Smith
Luis is right on pointing to Aconcagua products, regarding the VLF Omega antenna, as hasegawa didn't do a good job on its Falklands A-4 Boxing.
Best way to go is to find an haseg A-4B/C, with aztec decals and Aconcagua resin, as Luis said.
allong the same lines where can i get Mirage iiiEa decals for a italeri kit, again relating to the Falklands war
Mark
have look at the Aerocalcas site, they do/did a Mirage III sheet. Condor do sheet with markings for a few Falklands planes, Skyhawk/SHAR, Dagger.
http://www.condordecals.com.ar/condordecal...=9∏=16#
another Argentine decal manufacturer is http://phoenixcalcomanias.blogspot.com/
The sheets are $10 and post, but payment is by Western Union..
HTH
T
Back in The dawn of days, Esoteric also did conversions to turn an A-4E into an A-4B/C. Of course these are long OOP while the Aconcagua products are still available from the manufacturer.
Speaking of Mirages, Carpena set 48-12 contains decals for a Fuerza Aerea Argentina Mirage III, but I don't know if it's correct for a falkland era aircraft.
we stock Condor decals
Blackbird Models
Intteresting as I have a Hasegawa A-4 I would like to do as an argentine one so the Condor sheet would be a useful one to get.
Sorry for going off topic but I live in Sheffield does Blackbird Models have a shop or is it an online business.
Mark
Mark
We are mail order but just dropped you an e-mail
Glenn
Mark
Glenn
Mark
Both sheets in 1/48th with A-4's are in stock
Glenn
Mark
Glenn
