spike7451 Posted November 29, 2008 Share Posted November 29, 2008 Should have been one in your cell when you checked in Mike's borrowed it. Link to comment Share on other sites More sharing options...
peterm Posted November 30, 2008 Share Posted November 30, 2008 I would take the pitot things off, they just get in the way of the filling and sanding and are rubbish anyway. Better making your own... Just a thought... :-) Sort of progress.Filler on I'll get there. Link to comment Share on other sites More sharing options...
tornado64 Posted December 5, 2008 Share Posted December 5, 2008 I would take the pitot things off, they just get in the way of the filling and sanding and are rubbish anyway. Better making your own...Just a thought... :-) keep the pittots and throw the rest away !!!!!! Link to comment Share on other sites More sharing options...
GoonerChris Posted December 9, 2008 Share Posted December 9, 2008 Reading this build diary has brought back some bad memories. Seeing the fuselage and wing pics has sent shudders down my spine. Bad. Very Bad. Link to comment Share on other sites More sharing options...
AnonymousDFB1 Posted December 9, 2008 Author Share Posted December 9, 2008 I'm just about to start the sanding again Chris Link to comment Share on other sites More sharing options...
GoonerChris Posted December 9, 2008 Share Posted December 9, 2008 (edited) AAAAAARRRRRRRRGGGGGGGGGHHHHHHHHHH!!!!!!!!!!!!!!!!!!!!!!! Edited December 9, 2008 by GoonerChris Link to comment Share on other sites More sharing options...
tornado64 Posted December 9, 2008 Share Posted December 9, 2008 i received mine this morning and it is a considarably better fit than the last one i built ...can,t wait ....warble wuble quack gerbil donkey bang !!!!!!!!! Link to comment Share on other sites More sharing options...
Mike Posted December 9, 2008 Share Posted December 9, 2008 I'm so glad you put that second layer of putty on Mish.... One session just wasn't gonna cut it, was it? Once you've got it close to how you want it (no, not a miraculous transformation into an Italeri kit!), you could try smearing CA over the filler, which will make it stronger, less porous, and easier to feather at the edges. Do sand it immediately though, as it gets tougher & tougher as it cures. In fact, sometimes I sand while it's still damp(ish), as the dust created sticks to the wet glue & helps fill in the little pits that might still be there. Link to comment Share on other sites More sharing options...
Dads203 Posted December 9, 2008 Share Posted December 9, 2008 Looks like a lot of work Mish, good luck with the build Link to comment Share on other sites More sharing options...
spike7451 Posted December 9, 2008 Share Posted December 9, 2008 Loookin good ,Mish, I'm afraid mine has been consigned to the back room.... Link to comment Share on other sites More sharing options...
AnonymousDFB1 Posted December 9, 2008 Author Share Posted December 9, 2008 Just finished a session with the pile of I've sanded it down and it looks okay'ish. Put the tail on and filled the gaps around that. But and this is a big but I've dry fitted the air intakes and OMG the gaps I can deal with but the step on the lower edge I don't know how Im going to over come it. Photos in a bit as the camera battery is charging. Link to comment Share on other sites More sharing options...
Mike Posted December 9, 2008 Share Posted December 9, 2008 Don't forget that at the top rear of the intake join to the fuselage, there's actually supposed to be a step, with the smallest of gaps.... have a close look at some reference pics & you'll spot it Link to comment Share on other sites More sharing options...
tornado64 Posted December 9, 2008 Share Posted December 9, 2008 (edited) Don't forget that at the top rear of the intake join to the fuselage, there's actually supposed to be a step, with the smallest of gaps.... have a close look at some reference pics & you'll spot it this is true do not get rid of the gap at the top as he says it is meant to be there if you look at the german tornado on my banner it just shows..... Edited December 9, 2008 by tornado64 Link to comment Share on other sites More sharing options...
AnonymousDFB1 Posted December 9, 2008 Author Share Posted December 9, 2008 Right here we go with today's horror story that comes from the land of Airfix! I think I have the fuselage join under control now. Tail on and filled And now for the air intakes Top Bottom So what do you all think? More filler or sling it? Link to comment Share on other sites More sharing options...
avro683 Posted December 9, 2008 Share Posted December 9, 2008 More filler or sling it? Trouble is Mish if you sling it it might sneak up and bite you back when you#re not looking. Tony Link to comment Share on other sites More sharing options...
Mike Posted December 9, 2008 Share Posted December 9, 2008 Tha's'orrible! Gaps? Chasms! Link to comment Share on other sites More sharing options...
AnonymousDFB1 Posted December 9, 2008 Author Share Posted December 9, 2008 I think sawing off a couple of mm from the back might help line them up better? Link to comment Share on other sites More sharing options...
Fmk.6john Posted December 9, 2008 Share Posted December 9, 2008 Mish, I've got the perfect ccrimbo pressent for you.................... JB. Link to comment Share on other sites More sharing options...
John Laidlaw Posted December 9, 2008 Share Posted December 9, 2008 Blimey... I'd heard the kit was bad, but this??? Ask Sean for a hammer. Link to comment Share on other sites More sharing options...
avro683 Posted December 9, 2008 Share Posted December 9, 2008 Tha's'orrible! Gaps? Chasms! Now you know why they're called "Air Fix". Tony Link to comment Share on other sites More sharing options...
Notdoneyet Posted December 9, 2008 Share Posted December 9, 2008 Mish, I've just got my (abandoned) Airfix Tornado out and trial fitted the intakes to the fuselage and the fit is nowhere near as bad as yours. So perhaps you have done something wrong in assembling the intakes and/or misaligned them when fitting. Some things to check :- Do you have the "D" shape on the outside of the intake? This "D" shape mates against the fuselage side and buts against the vertical step created when the fuselage top & bottom are joined. Eliminate the bottom "step" by aligning the bottom of the intake with the bottom of the intake on the fuselage. There should now be a 1.5mm step at the top - this is correct it is where intake air "bleeds" out of the intake. If this isn't clear let me know and I'll post some pics. HTH, Ian Link to comment Share on other sites More sharing options...
AnonymousDFB1 Posted December 9, 2008 Author Share Posted December 9, 2008 John, thanks I need an industrial dremel. Ian let me go look and I'll get back to you. Link to comment Share on other sites More sharing options...
Alan P Posted December 9, 2008 Share Posted December 9, 2008 Ian's right, there is a bleed gap at the top side of the intake. If you get the bottom edge lined up, the top should be higher than the rest of the topside. If there is still a step I would use Milliput to smooth it off. Link to comment Share on other sites More sharing options...
AnonymousDFB1 Posted December 9, 2008 Author Share Posted December 9, 2008 Here we go Lined up at the bottom Some bleed gap And from overhead Thoughts? Link to comment Share on other sites More sharing options...
tornado64 Posted December 9, 2008 Share Posted December 9, 2008 CAN NARROW THE GAP A BIT BY HAVING A STEP AT THE BOTTOM SAND SOME OFF THICKNESS OF PLASTIC AND FILL A LITTLE TOO BUT YEP IT IS A TAD OVER SCALE Link to comment Share on other sites More sharing options...
