small scale engine turbine fans..
Skii
Right you bright and resourceful lot :)
I have a problem with my B-2 Spirit build which has ground progress to a halt, whilst the air intakes are heavily shrouded, you can still easily see deep inside - where I need to show the turbine fans to 4 x F118 GE 100 engines.
Does anyone know any manufacturers of photo-etched / resin engine/turbine fans ? its pretty deep and dark down there so it doesn't have to be a perfect match , and each engine is barely a centimetre in diameter
any ideas ? I'm stumped..
I've used Bra.Z replacement engines a couple of times on different projects, check to see what's here, it's mostly 1/144.
http://www.hannants.co.uk/search/index.php...%5B%5D=code+asc
.you might be on to something there....
http://www.hannants.co.uk/search/?FULL=BZ4016
you get 4 of these and the fan diameter of the RB211 is 85", and the fan for the F118 is 46", so in 1/144 they should be roughly similar sized to a 1/72 F118....
hmmmmmm :pipe:
Here's the Braz sites resin section so you can see the fans on some of the engines. The 747 engines look like they have too many small blades but the RB211's for the 757 look like they have more modern, wider chord blades. http://www.brazmodels.com/Full%20kit%20list.htm
HTH Paul Harrison
HTH Paul Harrison
useful advice - thanks Paul :)
Contact Pierre (aka Madman) If memory serves correct he knocked up some etched fan blades for his A380 a while back, and he may be either able to make you a set, or give you the know how!
Now off to have a look at your build so far - haven't seen it yet!!
Eng
