Ok now I AM confused!
Phartycr0c
Im currently building an 1 32 GR4 Op Telic bird ZG 714 "truffle snufflers" BUT Im now totally confused as to the colour scheme.
During my "research" I tracked down a book Tornado by Peter Foster, in which there is a chapter dedicated to op Telic birds.
I am aware that during Op Granby the GR1's were painted in ARTF desert pink, but in this chapter there is a passage which states
"these [Tornado GR4A's ZG 710 713 &714 ] and all further departures to the Gulf were painted in the 'ARTF' baby blue temporary finish, although all of the jets retained their individual squadron code allocations".
From the (few) images I have been able to track down of this bird it definately looks standard grey although the actual markings are a sort of powder / light blue and faded pink ish type stuff.
Is it the marks that the ARTF baby blue is referring to or am I missing sommat. Could someone shed some light?
It's a temporary finish that can be washed off with alkali based soap however it's not a definative colour as it will fade & change slightly when applied & also in the hot climate.It's also sprayed on over a darker grey so it will look 'funny'.If you look at some photo's you can see where the markings have been blanked off before spraying as you can see the darker colour thru the stencil.
Check my sticky;
My sticky
Edited by spike7451
Very Many thanks for that quick reply. I have seen your sticky but the term Baby Blue really threw a spanner in the works.
Now the next question is arouns stencilling. It appears from many topside shots that I can find, that the dotted walkway and no step stencils are missing from the GR4 and 4A's and in fact stencilling is kept to a minimum throughout the aircraft with the exception of the major warning marks, ejectior seat jet blast lift points etc. is this right?
