Pierre's Felixstowe F.2A, Roden 1/72
Madman
I cut out the cockpit frame and sand it down. A very delicate job indeed :)
Then I insert the frame into its plug on the mold. I can now start cutting lengths of styrene.
Edited by Madman
Part after part, still a long way to go! My eyes hurt and need to catch some zzz's...
In between I built the tables for the nav maps and the radio. The glossy shine is done on purpose, as is was the pride of the various building factories to deliver high quality craftmanship.
Scratchbuilding continues...
These little clamps are really fantastic :)
The bracings will consolidate the positions of the framing. The pins and the temporary bracing across the opening of the cockpit are to maintain all parts.
A light coat of "Desert Yellow" to check that everything is right... and it is :)
I glued both small tables behind the cockpit. The nav table received a reading lamp, maps and a home-made divider.
Building of the dashboard, which will now be quite visible. I kept the brass surface unpainted, as I like it very much, but gave the backside a wooden finish.
The backside, with the instrument housing. I drilled tiny holes to receive the wiring, and painted the stringers.
And here is what one can see when the model will be finished. Much better than to close up everything :)
Here comes my little sextant to go with the navigator's instruments :)
In the plane:
All right, sorry for the missing mirrors and angle scales... they will come on my next one, 1/144th :)
The entire assembly is soldered brass. The viewer is soldered last with a lower temperature solder.
Welcome to Cuckoo Land :)
This is NOT a stopwatch for navigation aboard the Felixstowe ;)
While I was attending the modelling exhibition, I had nothing better to do than to craft something free minded. I had with me some brass, a soldering station, scissors and a nail file.
Here is the result...
And to practice on smaller parts I soldered a couple of pulleys for the Felixstowe, like this one.
Well, I'm glad to see you are living up to your user name Pierre...!!! :wacko:
Those pulleys are just insane!! :blink: How on earth you can solder something that size totally & completely defeats me. I don't think I could even see to glue them....!!! :S
And that's a lovely little clock. Can't wait to see the cuckoo going in & out........ :whistle:
Keef
Here are the tools I use to solder
- a soldering station, with temperatures from 150°C to 400°C
- an insulation board
- liquid solder, bought somewhere on a flee market (I have no reference)
- various pliers or twizers.
Soldering happens at 275°C. I add a small drop of solder to the backside of thess MG ammo boxes, still on their PE fret, and stick the handle through the other side.
Now I close the hot soldering tip next to where the solder is, and wait for it to melt (it turns into a shiny silver color). When I remove the hot tip, the solder hardens very fast (it turns matte silver)
After soldering, the front side.
After bending, a lovely ammo box :)
