TAMIYA JGSDF ARMOURED VEHICLE
Guest snipersmudge
Guest snipersmudge
well I have made a small start today filling sink holes. The lower chassis in this kit is actually cast in metal
lots more sink holes to fill especially on the insides of ALL the doors
Pete
  • 4 weeks later...
Guest snipersmudge
Hi all I've actually got some more done on this one after a quite hectic time at home lately. The sink holes on this kit are very annoying especially on the inside of the doors. I have yet to use the voyager etched set but will be getting stuck into that soon
next up will be sorting the interior out and painting it
Pete
Guest snipersmudge
After tackling all those sink holes I've cracked on with the doors today adding the new handles etc from the etched set
also added the hydraulic dampers for the windows using plastic rod and etch
Started to get into this kit, it's taken some time but I can see what the finished item will look like.
cheers
pete
Guest snipersmudge
cheers guys, yes the sink holes are a total pain and there are loads more I have to deal with, anyway been cracking on with the etched......
Added the handles from brass rod as they are missing in the kit,
not much more to add really to the exterior. Most of the bits will be finished in sub assemblies for painting and brought together before weathering
cheers
Pete
Edited by snipersmudge
Guest snipersmudge
Hi all here is a further update, construction is now complete and the model is in it's various sub assemblies. I replaced the molded detail around the side indicators and used fine brass wire for the guards. The voyager front light guards would not fit correctly and where also flat in profile so once again out came the wire and new ones where made using the voyager ones as a pattern. The seat belt assemblies inside the body are made from tamiya tape and plastic card.
The model is now going for a bath in preparation for an undercoat
cheers
Pete
Guest snipersmudge
Well today I managed to get the bones of the model primed and painted. for the main colour I used Tamiya XF 74 olive drab JGSDF and for the interior colour I mixed up a custom sky colour. The seats are painted in NATO black. I've just got to paint all the little bits and pieces next then give it a good coat of klear.
The sharp eyed among you will notice that I have had to remove the rear seatbelt bottom mounts. This is because they where fowling the body so I will re-position then on the rear wheel arch once the bodywork is fixed on.
Pete
Guest snipersmudge
couple of pics for you, dashboard and fire extinguisher painted and waiting for decals. today I will be spraying the klear on the model ready for decals
Pete
