What is the 'definitive' matt clearcoat?
desmojen
These days I mostly use Tamiya flat base mixed into Klear, before that I used to use Xtracolour XDFF. Now I like both of these but I find the XDFF is maybe too flat (for my preference) and the Flat Base mixture sometimes tips the colour off too much. A case in point is my nearly finished Sea King HC4, the flat base made the colour look really wrong, but the XDFF is too dull.
Answers on a postcard please............
Jen.
Humbrol MattKote for me.
Jen.
Generally Xtracrylics flat, though often add a little gloss to sheen it up a bit, spray highly thinned, give a light rub with polishing cloth when dry (almost immediately), but not enough to show up carrier film. Always on the look out for new products though.
:winkgrin:
Very good :lol:
I suppose adding some gloss to the XDFF is the obvious answer and I did do that with my last bottle. Since my near total switch to acrylics though, I don't have old tins of H22 kicking about to tip into it.
I knew MattKote would rear its ugly head, but I flat out refuse to accept that anything Humbrol make is any good! So there! :tease:
And I don't think we can get Polly Scale over here either :hmmm:
Any more for any more?
Jen.
Jen.
You're not gonna like the answer then :lol: .... it's the only matt I've found that will go over black without turning it grey.
I second the vote for Xtracrylics! I use all three of their clear finishes (flat, semi and gloss) depending on the application. I use the gloss instead of Klear for decal prep. Not as hard of a finish but still effective and my results spraying Klear have always been hit-or-miss. Xtracrylix is so forgiving that even if I over-spray an area and it looks milky when wet, it clears right up as it dries. I've only found it in one place here in the US but I swear by it!
Gunze "Mr Hobby- Top coat" ( Gunze reference B-501) comes in 88ml spray bombs and is almost foolproof in application ( Well I use it with no problems any way!) and the results are superb. Also comes in Gloss and Semi-gloss.
Take two bottles into the mattcoat shower? not me- I just spray and go!
Get yours from www.rainbowten.co.jp/english/ now!
Troffa (in no way affiliated with Rainbow ten or GSi)
Just to annoy you Jen.
Humbrol Mattcote is good, usually. I have had one duff bottle. Can you put it over acrylics though?
Yes. With no problems. Usually....!! (& it's not the putting it over acrylics that gives the problems, but the seemingly increasing frequency that bottles of it are duff)
Keef
I've tried a few different acrylic flat coats, but my favorite remains tamiya flat mixed with klear (future). I keep a very flat mix in a dropper bottle and just at a little more klear to the paint cup if I want a more satin finish.
Another vote for Xtracrylix here, but make sure you've got the right airbrush - it clogs my Badger Anthem before the proverbial dropped hat has hit the floor, but works fine in the Iwata.
That'd be my second choice but No.1 is Gunze Mr. Super Clear U.V. cut (B523-800) comes in a large rattle can, dunno why but this stuff is miles ahead of anything else I've ever used. It doesn't change any of the delicate tonal values like pastels and washes that I've had other products do. One quick swipe and your model is flatter than the flattest flat you can imagine. Also very expensive and hard to come by but it's well worth it.
So that's what happened to your hair Mark. . you sprayed and it went?
BTW you read "Apache Dawn" yet? A little bit OTT maybe, but a ripping yarn of the boys from 662 in Helmand last year. . . .
Vallejo- don't go out without it Jen.
It's acrylic, and will give you a great matt finish, and it dries matter (?) than it sprays, unlike some things like Microscale amtt which always dries to a weird shine even if you put on 1/4 inch
/\ what he said :)
I'm an Xtracylix fan.I use both their flat and satin coats through the brush,and i keep a bottle of gloss which i mix with the flat if i want a less matt finish.I find the gloss a bit too shiny in 1/72 but the satin coat is about right for most glossy finishes.A good range of topcoats all round. :D
