* Supermarine Spitfire Mk Ia/II
timraven1992
Thanks GGC and Mish ;),
Quite a fair bit of progress has been made,
The fuselage has been fillered and sanded a few times, and also rescribed.
The door hinge has been reduced down a bit as well.
The wings were thinned a LOT from the inside, with the ailerons being removed and thinned, and the flaps as well. (thanks for the tips Dave G)
Me being clumsy as usual I created a bit more work for myself in the process! :banghead2:
Nothing copius amounts of Milliput can't sort out though! :)
The wings are far thinner than before and should look fine after the filling and sanding hopefully :)
Thanks for looking!
Comments/constructive critisism welcomed!
Tim
Cheers peeps ;),
I made a silly error with the Spit :oops:,
I attached the wings, but forgot to paint the bottom of the wing section interior green, so it is light grey!
Its fairly obvious if you look straight into the cockpit, but It should tone down with some paint on the outside to stop light shining through.
I may have to do it with the pit closed now :(
I've milliputted the wings, then sanded and black painted them. After more sanding I have applied tippex which shows more filling needed :(,
I've also separated the elevators and repositioned them dropped.
This was achieved by 0.5mm wire and a 0.5mm drill bit in a pin vice.
I'm also happy because I got good GCSE results, and as a treat my mum contributed towards a Harder und Steenback Evolution airbrush :D, from Everything Airbrush!
Can't wait till I can give it a try ;),
Tim
P.S. All my modelling seems to have knackered out Bramble! :rolleyes:
Shouldn't be a big problem Tim. You need a long-nosed dropping pipette (see Science teacher) and some well thinned interior green. Add the paint using the pipette and swirl it around. It should make all the difference.
Dave.
Handy tip there, getting paint into tiny spots can be a real chore.
Well done with the exams (and on having a cat! (I so miss mine)), the spits coming along nice, I'll have to try out this tippex lark myself sometime.
A fair bit of progress,
I had a spray round with my new H+S Evo to check the seams, more filling was necessary :(
After that I squirted some thinned Hu 78 (new acrylic type) onto the pit floor with a syringe. However I may have forgotten about the hole for the landing light, landing gear (all three!!) and the eight machine gun ejector ports. Luckily I was wearing old trousers :laugh:!
I then blocked off these holes with car masking tape, and tried again:
As this dried the paint separated and dried very pitted and with varying greens. However this can only be seen if looked at VERY closely, so I'll leave it :)
I attached the horizontal stabs and fillered them:
I then test fitted the Radiator bath and Oil cooler, which both have the mating faces a bit to thick, after sanding them down and gluing, and then fillering I was left with this:
I have also dipped the canopies in klear but the main canopy is unuseable due to a moulding defect :(
I emailed airfix a while ago but am still waiting :(
Tim
