Phartycr0c Posted July 15, 2008 Share Posted July 15, 2008 (edited) I recently procured a vote from you guys and gals as to what I should get stuck into next from my 1/32 stash and the GR4 won. BUT Iv'e hit a dead end before iv'e even started. The build was to be based on a Tigermeet kit which I was looking to convert however researching the net for bits, the only conversion i can find are the Paragon flaps and slats kit. NOW I did find that Paragon used to produce various bits and bobs to carry out this conversion in the shape of the FLIR pod and Hindenburger tanks (although these wouldnt go anywhere near my build) but none of these parts are out there any longer. Ive emailed Revell in an attempt to see if they could supply the additional sprue from the GR1 kit but ive not received a reply. It appears therefore, that I am somewhat stuck. I was looking forward to a GR4 but its now looking more and more like this kit will become an ebay refugee or the like unless I can get hold of some bits. I note that Paragon are releasing some JP 233's therefore is it likely that the other Tornado bits will make a re appearence in which case should I wait? Can anyone offer any advice P.s Im no good at scratchbuild! no sense of proportion you see! Edited July 15, 2008 by Phartycr0c Link to comment Share on other sites More sharing options...
Stephen Posted July 15, 2008 Share Posted July 15, 2008 Contact Neil directly,he's a member of BM and may be able to help you out. There's also this: http://www.djparkins.clara.net/fltpath/fp32pw_grib.htm HTH Stephen Link to comment Share on other sites More sharing options...
Phartycr0c Posted July 15, 2008 Author Share Posted July 15, 2008 OH OH! looks like my Tornado build is back on and my bank balance will be taking a BIG HIT! Thanks ever so much for the information, obviously my internet research capability is rubbish. I feel a Diroama coming on! Link to comment Share on other sites More sharing options...
atdb27 Posted July 15, 2008 Share Posted July 15, 2008 Hi there For Decals you might want to check these out http://www.fantasyprintshop.co.uk/Telic-Tornados_B216LS.aspx NOT listed on Hannants so you may have missed them? I have a set myself for a 'future' project. They have small selection of good stencils as well, on a very well filled A4 decal sheet. HTH Adrian Link to comment Share on other sites More sharing options...
