how to make tarps?
smuts
Guest snipersmudge
Andy there is as mentioned several methods for tarp making. the tissue method involves using tissue paper, the finer the better and how i do it is to cut the tissue to the size required then dab on some diluted pva or white glue. then you can position the tarp and add folds etc. Using milliput or any other putty etc is also easy. just roll out the putty to the thickness required, cut and position on the model the add folds etc, it helps if you roll the putty on a surface dusted with talc then it won't stick.
another method is to use lead foil, this can be placed on the vehicle, shaped then removed for painting and can be added later fixed with super glue or epoxy.
hope that helps
Pete
