winter white wash.
smuts
hi guys any tips on applying a winter white wash, I was thinking about using tamiya's weathering sets white in streaks also would SPG's with
open fighting compartments been washed on the exposed faces.
Thanks Andy. :cheers:
The one time I tried this effect on a Panzer III I used some ground up white chalk, mixed with IPA ( Isopropyl alcohol ).
Lathered on liberally with a brush then rubbed down with a cloth lightly. The more you rub, the more grey comes through, but does seem to give a nice mottled effect. rubbing down with just IPA will let you remove the white in specific sections.
Once you are happy seal with a thin coat of matt varnish. -
I will post a photo of the finished model when I get home so you can see what it looked like ( dont worry about the quality of the build, it was a quick saturday afternoon blast for fun, I have a small stash of 1/72nd armour for quick fun builds with no worry about the look ).
I saw a really effective white wash technique in TMMI, used on tanks and aircraft. I've been experimenting with the method and did a short write up here ... http://www.britmodeller.com/forums/index.php?showtopic=13512
I only used the method to produce chips and scratches, but the originator of the method used it for a weathered white wash effect. Essentially, you just keep wetting the top coat and remove as much of the white wash as you want, revealing the paint underneath.
I tried to replicate the "real thing" on a Tamiya KV1 a few years ago. As whitewash / distemper would have been applied in the field I used thinned poster paint airbrushed on, when it was dry I used an old toothbrush to wear the poster paint away - was quite pleased with the result. I might try this on my Dragon Panther A & will post the results.
Somewhere I have some pics of of a whitewash technique I tried out on a Fujimi Su 85. Long story short, I sprayed the model olive green then gave it a coat of gloss and let that harden off for a few days. Then I took a very watery mix off Tamiya flat white and airbrushed that in in patches. Left that until it was touch dry (literally a few minutes) then went over the model with a wad of Scotchbrite type-material - as the thinned-white paint was very fragile it didn't stick to the gloss surface and started to wear away on the edges or surfaces.
Best to practise on a junked model, but it has possibilities - and I'll try and dig out those pics.
