Greg B Posted June 20, 2008 Share Posted June 20, 2008 I think I will have a dabble with this! Just about to break it out of its wrapper and wash it ready for tomorrow. OOB Link to comment Share on other sites More sharing options...
daz greenwood Posted June 20, 2008 Share Posted June 20, 2008 Looks good mate. Link to comment Share on other sites More sharing options...
AnonymousA667 Posted June 20, 2008 Share Posted June 20, 2008 Hot damn, that box art is to die for! This 1/48 lark is gonna cost me a fortune! Will you be doing it as Gleed's machine? peebeep Link to comment Share on other sites More sharing options...
Greg B Posted June 21, 2008 Author Share Posted June 21, 2008 Hot damn, that box art is to die for! This 1/48 lark is gonna cost me a fortune!Will you be doing it as Gleed's machine? peebeep Yep, out of the box apart from the belts Link to comment Share on other sites More sharing options...
darson Posted June 21, 2008 Share Posted June 21, 2008 (edited) Great stuff Greg, btw have you built the Hase Hurricane before. Edited June 21, 2008 by darson Link to comment Share on other sites More sharing options...
Greg B Posted June 21, 2008 Author Share Posted June 21, 2008 Great stuff Greg, btw have you built the Hase Hurricane before. Nope, anything I should know about it? Link to comment Share on other sites More sharing options...
Guest Guest Posted June 21, 2008 Share Posted June 21, 2008 Hi Greg, I used this very kit when building my Hurricane over on the Previous Builds thread. Things to watch out for are the well publicised wing underside/fuselage joint. It leaves a step and occurs right across a section of the ribbing on the fuselage. I found that rolling wet and dry paper into narrow tubes and sanding lengthwise between the ribs was the only way to eliminate it, followed by rescribing in the area. Also, the wing leading edge has a lot of panels to insert, and a lot of them are tricky to fit flush. More sanding and rescribing needed there. The cowling pieces fitted well I found, but I attached them to the fuselage halves BEFORE closing up the fuselage as it made life that bit easier. I also replaced the moulded in navigation light on the rudder with a piece of rounded off clear sprue. If you're using the kit canopy, don't bother too much with cockpit detail - the canopy is moulded in one piece and nothing will be visible inside! If you intend to cut the canopy to open it, be aware that the sliding portion will NOT fit over the fuselage spine. The only option for an open canopy is vacform. Watch out for the ejector pin marks in the undercarriage bay too, if I remember correctly. Other than that, it's a nice little kit. I'm looking forward to seeing yours finished. Hope that's some use to you, Dean Link to comment Share on other sites More sharing options...
Azgaron Posted June 21, 2008 Share Posted June 21, 2008 Nice looking kit Greg! Nice to see a few Hurricanes being built! Cheers, Azgaron Link to comment Share on other sites More sharing options...
Greg B Posted June 21, 2008 Author Share Posted June 21, 2008 Thanks Dean, I'm tickling away on the wings at the moment as the fit of some of the panels are not the best to say the least! Link to comment Share on other sites More sharing options...
