Romeo Alpha Yankee Posted May 19, 2008 Share Posted May 19, 2008 (edited) Been working on this one on and off for a couple of years (or so it seems )I am using a Sasquatch resin fuselage conversion available from CBS Models in the USA. Up to the paint and decal stage at the moment.I started with the conversion. The hollow halves needed sanding to get a good join, The kit wings were added and the kits one piece tail plane had to be cut in half and glued into the slots below the tail.The -800 has a bulged engine nacelle, the kit parts had to be built up with strip and putty, at this stage I had started priming After a lot of sanding I eventually destroyed all the raised detail on the model, this was covered up with a few primer coats and a final coat of spray pack auto lacquer. RAAF Viscounts had slipper tanks fitted, I used a set of 1/72 Mosquito aftermarket long range tanks which were reshaped. I don't think the shape is 100% but close enough for govt work.Yesterday I dragged the model out again and commenced final paint and decaling, Still a few days work to go including adding some antennae and anti col beacons. I sprayed some blue onto the decals to cover up a badge that was there for a different scheme. I used what I thought was the right shade, obviously it was not. I ventured to the LHS at lunch time and got something that should match a little better.It will be finished as one of two Viscount -800s operated by the RAAF up until the late 60s. Hopefully it will be done by the weekend. Tonight I will be scratch building a few antennae and the anti cols. Edited April 26, 2013 by TrojanThunder Link to comment Share on other sites More sharing options...
Alan P Posted May 19, 2008 Share Posted May 19, 2008 Wow! Shiny! Keep it up, looks like an interesting and unusual subject. Al Link to comment Share on other sites More sharing options...
