Spitfire accident -oops!
HP42
Mooching about on Airliners.net and found this picture of a poorly Spitfire. I'm sure I saw this one at Duxford a few times last year. Not a nice sight to see. What's the prop made from? I would have expected the classic bending backwards if it was made from aluminium. Is this some form of composite?
http://www.airliners.net/photo/Supermarine...fire/1352635/M/
Phil
If the gear was inadvertently raised while the aircraft was stationary or moving slowly then that would explain why there is no bending. To answer your question about the blades, some types of prop had wooden blades.
I can hear all the professional jocks (and a few amateurs) saying to themselves 'there but for the grace of God go I'!
peebeep (tri gear fixed undercarriage rocks)
It's made from wood.
It certainly looks that way but I'm very surprised they're wooden, I thought they were alloy.........
....yer live and learn.... :gobsmacked:
Phil
You get the bad pun of the day award hands down!
I think most Spits (actually, I'll add a caveat - most Merlin powered Spits) fly with wooden blades now. The only one I know which certainly has metal blades is the Mk1 AR213 at Booker, which has the metal DH prop formerly on AR501 at Old Warden.
As for the incident, glad it happened at taxy speed.
Edited by Vickers McFunbus
Ouch.
"There are those who have and those who will" - you are so right peebeep, "There but for..."
Phil - I think a lot of Spitfire props were/are (?) composite - wood construction impregnated with a phenolic resin IIRC. I can't remember the name they gave that. Not sure if that is what is used now, but why change if it works.
Nice low revs etc and with the wooden prop they should get away without shock load damage to the engine, though I exepct a check still will have had to be done. Expensive.
I see someone at Perth tipped up a Gypsy Moth on its nose last weekend, forced landing in an oilseed rape field after engine problems. No injuries, just aircraft damage. Shame to have to damage a nice aircraft, as with the Spit, but again got away reasonably lightly.
Edited by John B (Sc)
Ouch.
The "improved wood compressed resin impregnated wooden props use the Jablo process IIRC.
John
John
Edited by John Aero
What a shame and a two seater to boot.
It looks like the one that was restored in Irish Air Corps finish (161?) and was repainted as a K.Lu. aircraft. I probably saw it performing at the seafront of Bray, Co. Wicklow, a couple of years back.
Joseph
Edited by JosephLalor
'Tis indeed. Formerly PV202, which was involved in a fatal accident in 2000 at Goodwood.
You will all be pleased to hear that he aircraft returned to Duxford this afternoon - by air, under its own power. :)
Quite right John, the prop material is Jablo - I have a file handle made from this stuff. It is basically very thin vaneers of wood with resin in between them, which is set under high tempreture and pressure. This Spit should be flying again very soon with a new prop.
Derek
John
John
IIRC even some of the Griffon engined Spits had wooden props. There is part of a late mark (22/24?) blade in the Fenton Flyer pub at Church Fenton which is definitely wood.
Hope the Merlin in that photo wasn't stressed; Merlin rebuilds are not cheap!!
