F/A-18E Weapons Loadout
Muzz
Folks, I was wondering if anyone can guide me on possible weapons loadouts for the F/A-18E during Op Enduring Freedom/Iraqi Freedom. I have nearly completed my build of a VFA- 115 Screamin Eagles machine and was planning on 3 external tanks, a GBU-16 on station 9 and a GBU-31 JDAM on station 3. Was also considering an option of putting a single GBU-12 on station 10. I wasn't sure if this is above the aircrafts payload as the only photo's I've seen is either 1 centerline tank and and smaller stores such as GBU-12's on the majority on the pylons or 3 tanks with a couple of what look like GBU-32 JDAMS. Any thoughts?
Your best bet is to ask on ARC - AFAIK Joe Hegedus over there was/involved in some of the testing for SH weapons, so he knows whats realistic and has been used operatioally. The one you mention sounds plausible to me though.
At this present time the available loadouts for the F/A-18 are rather odd if you ask me - with the Super Hornets 'unusual' underwing aerodynamics (hence the canted pylons) and large number of weapons stations the potential number of weapons combinations are dizzying! And there a lot of cool looking weapon configurations that could be hung on the jet (as in, the pylons are rated for that much weight and it will all fit on the wing) that aren't cleared for flight as exhaustive testing hasn't been done.
Most operational loads I've seen to date are a bit ugly if you ask me, though I appreciate looks aren't the driving factor to what gets carried! For current operations small PGMs are order of the day.
A typical OIF/OEF load would be 'goofy gas' with 2 fuel tanks, 1 being on the centreline and one under the right wing, and then say a GBU-31 on the left innermost wing pylon, and a mix of GBU-12 (500lb Paveway II), GBU-38 (500lb JDAM) and/or laser maverick (AGM-65E) on the remainder of the pylons. Assymetrical loads are very common indeed - not just in terms of weaponry, but sometimes an outboard pylon is left off one of the wings too!
Will
Thanks for the info, I've seen a few pictures with some random looking fits right enough. Assymetrical loads seem to be the trend with lots of aircraft types now. Pardon my ignorance but whats ARC (I'm assuming it stands for Aircraft Reference Centre or something like that?:undecided:
Edited by Muzz
Its soooo ugly a lot of the time as well, just looks completely unbalanced. Would be intrigued as to how such 'sweetheart loads' (as I have heard them described) effect the handling of the aircraft...
Muzz,
Stations 2 and 10 were used for Amraam carriage early on during OIF whilst there was still percieved to be an A2A threat with tanks on 4 and 8 but this seemed to be quickly dropped with extra weapons employed in place of the tanks and just AIM-9's on the wingtips for self defence. 2 and 10 don't seem to have been used much after that. GBU-12's weren't used until the 10th of April 2003 as they weren't cleared for use on the SH until then with VFA-115 using GBU-16's instead. If it was me I'd lose the two tanks, go with one on the centreline and fill 3,4,8 and 9 with a mix of GBU-12's and GBU-31's with AIM-9's on the wingtips, or for an early ops phase use tanks on 4,6and 8 with GBU-16's or GBU-31's on 3 and 9, AIM-120's on 2 and 10 and AIM-9's on 1 and 11. As far as the switched tanks config goes this is done on the legacy Hornets to allow the FLIR pod on the left intake cheek a line of sight which would otherwise be obscured by a drop tank. I don't think this is an issue with the SH. It seems other assymetric loads are otherwise carried mostly to allow flexibilty in striking a range of targets these days, CAS weapons such as the GBU-12 can be combined with the greater precision/penetrative power of JDAMS on the same aircraft. F-16's carry GBU-38's on a BRU-57 dual adapter on one side with GBU-12's slant mounted on a TER on the other at the moment. I thought it looked pretty cool ... :lol:
If want a list of what is cleared for what station have a look here
http://www.hannants.co.uk/search/?FULL=ABD48012&PIC_NO=4
Gary
Edited by Gary C
Guys, thanks for all the help (and links). I'm going to go with the 3 tanks, JDAM and GBU-16 with AIM-9's on the wingtips with the outboard pylons empty (well maybe a missile launch rail on one side.). I like my jets well hung :D !!
Edited by Muzz
